Start C2 got stuck
If the first start C2 got stuck, and it doesn’t run any more after I gave it the security code, what can I do?
Check this page: Jolla C2 first time use instructions
You can also try Fastboot flashing of Jolla C2
My phone is stuck and can’t anything.
What can i do in this case, how can i reboot?
That is my problem
Just hold power button for 10 seconds. You’ll feel vibra as a sign of a restart.
No function. It’s just a restart.
It’s a bit more clear now. So your C2 doesn’t even boot fully?
In that case reflash as patoll mentioned above or turn for support on Zendesk.
