Sound in Telegram with wired headset often also thrue speaker
REPRODUCIBILITY: 75% (often)
OSVERSION: 5.0.0.70
HARDWARE: Jolla C2 - s19mps - s19mps - 1.0.0.50 - aarch64
UI LANGUAGE: Slovenščina (user: sl_SI, os: sl_SI.utf8)
REGRESSION: not specified
Often listening for bubbles or audio in Telegram with wired headset sound come both thrue headset and speaker
Connected headset (headphones)
  1. Tap on bubble or audio in Telegram
EXPECTED RESULTS:
Sound comes only on headset
ACTUAL RESULTS:
Sound comes on both headset and speaker
  • Patchmanager: yes
  • OpenRepos: yes
  • Chum: yes
  • Other: none specified
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.16+git2
Is that really exclusive to Telegram, have you tried other sources of sound?
Do you keep the phone in a case?
I believe that’s the same as Double the Sound [fixed]
No, I know that one. The second hack of my bumper is because of that. Right after the Flash bleed one and before charging port fix for a specific charger. CSD is great for HW tests.
OTOH I haven’t tried sound service restart from Settings from the topic you linked. Thx.
No. And it seems a regression coming with 5.0.0.70 or the version before this. Maybe this is a result of fixing
That was never fixed and is still an issue.
I always have the other party call me because of it.
