[AppSupport] Whatsapp outgoing videocall volume much lower than incoming calls
REPRODUCIBILITY:
OS VERSION: 4.5/4.6
HARDWARE: Xperia 10II
UI LANGUAGE: English
REGRESSION:
When I (video) call someone on whatsapp on speaker I can barely hear them (and I maximize the volume on my phone), when they call me instead volume is fine.
Whatsapp
  1. Videocall someone
  2. Have them videocall you
Speaker volume should be the same on both (and preferably at the level of the incoming call).
Outgoing calls have very low speaker volume, incoming calls have OK volume.
This is on speaker, on a bluetooth headset it’s fine.
I have the same problem with 4.5/4.6 Version on XA2.
Hi i think its all Android app wich crashed.
The problem I think its from the the api Android ApSupport wich stop and restart any way you run an Android app
I don’t know if this is relevant, but my phone is on silent most of the time, I’ll try to put it not on silent later to see if it is any different.
The problem seems to be that outgoing calls only let the sound come from the top speaker (like in a normal phone call), whereas incoming calls let the sound come from the much more powerful bottom speaker.
I run WhatsApp on Jolla C2. Sound is good for 10 seconds, after that it turns silent.
Same happens with Signal on C2 - I need a ear trumpet!
Still happens on latest 5.0/xperia 10ii.
