I didn’t try it before, so I don’t know if it would work from the start.
Didn’t tinker with anything, just installed packages from 10mk3.
PS I’m not sure there are any new connectivity related options in a new kernel by @vlagged. I’ve checked /proc/config.gz for those kernel options mentioned in a thread and they’re still not there.
Hmmm, not sure why mpv was muted on your device, it wasn’t on mine….
As for the video playback in e.g. SFOS Camera preview, did you have to disable the avc codec in /etc/gst-droid/gstdroidcodec.conf in order to get smooth video playback, or was it working OK?
Hmmm, so it’s really interesting what made it work. Maybe the needed changes were actually in the new LOS21 base for the 5 IV? @vlagged, could you please shed some light on what actually could have made AAS mobile data work (so wonderfully well) on @remote’s 5 IV in your recent updates?
Oh, so it takes updating the LOS base for the 1 IV to make it work…. Well, sadly too big of a task for me, so it looks that sometime in May is the soonest we can see it on the 1 IV
@vlagged I’ve flash the last LOS build (20260307) and my xperia 5IV didn’t start. I see the LOS boot animation and after some time phone reboots. But if I flash SFOS on it - SFOS is able to boot and works. Have you tried to boot last LOS build on xperia 5IV?
I guess that for LOS to correctly boot up you need to wipe / format the data partition in LOS recovery. At least that’s what worked for me. Sadly, it’ll wipe your SFOS data, too.
I faced this problem first time when I had issue in SFOS with airplane mode (I couldn’t turn off it) and decided to try run LOS and check if LOS has the same issue. I’ve flashed LOS boot and vendor_boot partitions and after that wiped/formatted data partition in LOS recovery.
After that I decided to flash LOS from scratch and went through all steps in LOS installing instruction from rinigus’ SFOS Nagara repository, but used the last LOS build (20260307). Unfortunately, got the same result as in the first try - bootloop on LOS loading indicator.
But it interesting when I flash SFOS on top of this LOS - SFOS boots and works.
P.S. Didn’t check the airplane mode issue in the new installation
Well, the CPU is the same and the folder name mentions it, so I assumed it might be the same for the two devices. Though the rest of the hardware is not really the same.
They share the same source, but I don’t think they’re the same binary kernel. There are two configs set differently and then the kernel image packaging which also adds cmdline parameters - which are concatenated with bootloader ones, which also differ - so better wait for the tested build.
Thanks for reporting this - I have published an updated lineage build. You might get away with only flashing product.img (an updated Euicc app from google caused this, weirdly). Backing out that apk update is the only change I’ve done, and would explain the fact that it did not impact Sailfish. Let me know how this goes.
I bought my 3rd X 5 IV today. This time, if the seller sent me a true screenshot, it should work…
Motivation : still 100%.
(I hope it will last at least a decade!)
Looks like yet another come back of very old SFOS bug
I haven’t checked but I bet that also in this case it’s a general SFOS bug, not Nagara port specific. If so, it should be reported to Jolla using a general bug report form….
