Situations application feedback
Ahh, probably because those are currently simply not translated at all. Feel free to provide some :wink: All existing translations are here: GitHub - pastillilabs/situations-translations: Situations translation sources · GitHub
At some point I might look into do some AI translations for the missing parts at least, but not yet…
Br,
Heikki
It seems that the problem still persists that after restarting the phone, the ambience and the ambience color are both wrong.
Please don’t! They might work for some ‘big’ languages, but definitely not for all.
I’ve started to update my Swedish one. :wink:
Could have been easier though, if I had a script or something to extract the sv files from the downloaded packet. Tok some time to manually remove the others.
:stuck_out_tongue:
The thing is, there have been lots of small strings untranslated for many languages for a looong time. So I’ve been considering some sort of update for those. But will still reconsider :wink:
In the meanwhile, I updated the beta version. Available here:
Now updating from old version & import / export should work. And also some other small issues were fixed. On the other hand, data from previous beta will be lost.
Didn’t test going back to previous app version from here. But if I remember correctly, shouldn’t be an issue since the data hasn’t really changed.
Br,
Heikki
That hasn’t been touched indeed. I will have a look again, but not sure what to do. Situations basically just sets current ambience via dbus (com.jolla.ambienced). Perhaps something else could be done also…
PR for Swedish update sent! :relieved_face:
I have two quite recent translations (Italian and Norwegian bokmål) for my Fast Chess application. I tested AI ability to translate my strings and it seems that about 50% of strings are translated similar way. I would recommend to use real translator if possible.
Thanks! I will release the translations to the app on next update. If no big issues found with the latest app, perhaps to Jolla store also.
Br,
Heikki
By the way, I have Situations version v3.2.281 on my other phone and in that version the ambience and the ambience color are correct between reboots.
Okay ?
Where can i get this version?
Ok, interesting, thanks! I’ll try to check what was different there.
Br,
Heikki
Link to Release Beta release 316 · pastillilabs/packages · GitHub is up there.
Actually, I built a new version that is now available here:
Updated Swedish translations, made a fix for ambience action - and added possibility to run command action as root (yet again new translation that is missing from the Swedish translations :wink: @eson).
@Pasik2 Can you please check if this fixes any ambience stuff between reboots - or if the problem is still there?
And all: As I now added a possibility to run command also as a root user, it basically gives anyone installing the daemon possibility to run commands as root from Situations app. So basically adds some sort of attack vector. Right now I can imagine someone importing application data from an untrusted source and that way the source can then execute arbitrary commands as root. So requires user action certainly. Anyway, I wonder if this is acceptable or not?
Br,
Heikki
Thx, hhaveri. Run things as root is great for the aware ones. So I guess an unchecked config option for that is safer.
I’m pretty sure I’ll think of at least two uses for root mode.
BTW, I think Jolla mentioned the store wait time is now 4 weeks.
PR done! …and 20 chars
It seems that now the ambience and color change correctly after a reboots!
I noticed another thing, I use the “daylight” situation to open the Nightish application when the situation ends. The location update interval is 120 minutes. It seems that when I enable this situation, the gps keeps trying to get a location and after getting the location information, the gps still stays on. This was not the case in the previous version.
Yes, used Gemini a bit as I am no Chess player (the Norwegian bokmål).
Looks awesome.
i’m going to test it.. :face_savoring_food:
And that’s why there are no Swedish translation. :wink:
Thanks! I’ll check what can be done about this one next.
Br,
Heikki
