Ok, please try again with the packages here.
For a long press you need to hit the play button. But it should take only about 1 sec and timer screen should open up. “Works at least for me ;)”
Anyway, I was hasty so put the current version to Harbour review (which however might take months) just moments ago.
So any further fixes will come there later…
No change. I still get error. ![]()
I first tapped play button to activate situation and after that hold stop button to set timer, but no matter how long I hold, I don’t get timer.
Ok, thanks! In Harbour there is actually this sort of field:
Detected OS versions compatibility
5.1.0.*
So it might play a role…
I noticed using both the Jolla store and release 325 versiona an issue when using ‘bluetooth devices’ as a when condition.
I used the search button but it always says ‘turn on bluetooth’ (‘activer bluetooth’ in French) while bluetooth is already on.
A workaround was to enter device name amd address manually. Then it works as expected.
(this is for JP2 on latest 5.2)
Thanks
Thanks. That happens likely because you have AppSupport Bluetooth installed(?). I haven’t yet checked if or what is possible to do about it. But will.
In my case that is correct.
No I did not activate the bluetooth in Android app support
By “activating” you mean what? Installing it is enough to break it.
I think it is available by default in SFOS 5.2 as I never installed it
Ahh, ok. That explains. But yeah, unfortunately that currently breaks the “old” dbus interface somehow. I will have a look at it at some point.
Would it be possible to get function “Location” not only as “When”, but also as “What”, to be able to enable or disable location service? Or is this function somewhere?
