I have problems by logging into the App. If I swipe down to select “login” the login-Page from Jolla-account appears. But the Desktop version and not the mobile one. After login a new page “Authorize application access” is shown.
After logout an Re-login the “Authorize application access” Is shown and not the Real login page. Is logit no more possible? All this pages in Desktop versions instead of mobile. And the tex and buttons are very small.
You can clear your webview cache if you want to access the login prompt again (just delete ~/.local/share/harbour-sfos-forum-viewer/* ), but you should be able to just click the authorize button to get a new auth key
Tanks a lot for this app, I particularily appreciate the recently added possibility to reply within the app.
However the UI for this is a bit cumbersome, since the latest comment to which you probably would like to reply is at the bottom of the list, while the reply action is placed in the top pulley. Possible improvements would be to invert the order of the comments to newest on top, or move the reply action to a bottom pulley
When logging in, after giving username and password, and pressing Authorize, I get error
Oops!
The software powering this discussion forum encountered an unexpected error.
Detailed information about the error was logged, and an automatic notification generated. We’ll take a look at it.
No further action is needed. However, if the error condition persists, you can provide additional details, including steps to reproduce the error by posting a discussion topic in the sites feedback category.
Few times already on few days. Perhaps I should follow the advice in the message, and post in a new thread.
Weird, if it happened once it could’ve been you hitting an already used clientID (it’s not being generated very long but that should still be less than 1 in 10k chance), someone on OR mentioned he needed first to login in browser for the login in app to work, wasn’t aware of that so maybe this? If that doesn’t help could you drop a timestamp here after a failed attempt, someone from the forum staff could maybe dig out the actual error from logs (no idea why discourse always has cryptic errors clientside)
Every time I touch the screen to scroll a little further, the whole post and automatically the whole screen flashes as if selecting the article even though I’m just trying to scroll, not selecting anything.
It is not such a big deal when I’m scrolling a list of small posts, because only the post under my finger flashes.
But when trying to read and scrolling long posts, a large part of the whole screen flashes every time I scroll a little.
The flashing is most likely related to the context menu available on long-press of a post (active elements behave that way, and the whole post is the active element). I would suggest using the margin to scroll, as the active area of each post leaves some space to the left and right.
