Tried on a Dell Latitude E7450 with touchscreen, and works really well! Congratulations!
WLAN is ok
apps can be installed with Storeman
can not log in with existing Jolla account due to no IMEI found, although there is a WWAN card installed, and seems to be detected by ifconfig (no SIM was inserted though)
no audio from the speakers (didn’t test with headphones)
Thanks for the feedback! I didn’t get Jolla store working yet because it needs registration and appears to be device-oriented. Speakers don’t work because the sound system is configured like android and not desktop Linux…I’ll fix that soon. Webcam…I need to change some modules around to use uvcvideo.
Can you please help test with a SIM card in the WWAN slot if that’s possible?
