I checked a bit what could be causing those coredumps and I suspect both udisksd and pulseaudio (and android.hardware.audio.service-fp5) only happen when those services exit. I included all of the so far done fixes for ngfd in my build which could help with those ngfd a bit but might not fix all of those yet. Not sure about those others yet but at least I will do some bluetooth testing to see if I can see those crashes myself.
Regarding my unability to connect to WiFi: I visited three cafes offering free WiFi during the last time. One had a WiFi with a captive portal and I was able to connect, in the other two I couldnāt connect (donāt know if the had a captive portal).
Missing flashlight support for FP5 will be included in next release, one package was just missing so I included it to be installed.
jolla-settings-system-flashlight ? Can it just be installed today manually?
Yes, it can be installed manually if already needed
How would you feel about the black camera spot on the upper end of screen (of FP5)?
I guess it doesnāt bother so much with the notifications and so onā¦
Itās not particularly pretty, but it hasnāt bothered me so far. Nowadays, most websites have headers, and I just donāt push the content all the way up on those that donāt (or on apps without headers). Iāve never had a situation where critical information was hidden. Of course, that doesnāt mean that these situations canāt occur.
EDIT: notifications are shown below the hole.
Hello!
Iām testing Sailfish on Fairphone 4.
Installation script on Windows failed miserabily because it claims my device is not unlocked, even if it is.
Looking at the code in flash-on-windows.bat the instruction is:
:: Check that device has been unlocked
@call :getvar secure
findstr /R /C:"secure: no" %tmpflashfile% >NUL 2>NUL
if not errorlevel 1 GOTO no_error_unlock
On my unlocked phone:
fastboot getvar all
(bootloader) unlocked:yes
(bootloader) secure:yes
So I modified the script to look at unlocked instead of secure, as it is already done in the linux script flash-config.sh
"getvar_fail_if unlocked no"
Corrected code is:
@call :getvar unlocked
findstr /R /C:"unlocked: yes" %tmpflashfile% >NUL 2>NUL
Thanks for finding that issue, it seems I had forgotten to fix the windows flashing scripts on both fp4 and fp5. I fixed those now and the fix will be included in next release.
Hello!
I made a try for Waydroid on Fairphone 4 (SFOS installed onto Android 13 factory).
I followed the guide you mentioned, then I had waydroid-runner which closed the Android session as soon as it opened it.
I connected my PC with SSH (easier for me to debug) and typed waydroid log, it gave me the error
dnsmasq: failed to create listening socket for 192.168.240.1: Address already in use
which corresponds to the last section of the guide (Troubleshooting):
devel-su systemctl disable --now dnsmasq
devel-su systemctl restart waydroid-container
The solution worked.
Now the waydroid-runner is stuck at āWaiting for Android UIā.
Log are reporting in loop:
(010469) [12:53:44] Failed to get service waydroidplatform, trying again...
(010469) [12:53:45] Failed to get service waydroidplatform, trying again...
Iāve done some research on the web (1,2,3,4,5,6,7ā¦), but havenāt found a working solution yet.
There is a kernel fix in 5.0.0 build for FP4 related to containers, not sure if that affects also waydroid.
Did anyone succeed in running waydroid on FP5?
Sailfish OS 5.0.0.62 alpha2 releases are now available for FP4 and FP5. Update instructions and changelog added to the initial post in the thread. FP2 will get the update later after I fix the broken WLAN in it when using 5.0.0.62. I will try to finally get the VoLTE issues solved soon, and also the WPA2/WPA3 mixed mode WLAN issue still needs fixing.
It works like a charm, so smooth and all works very well! 1+ mal
And thank you.
The only thing that doesnāt work is Waydroid. Maybe one day youāll fix this or have an solution.
Waydrod Lineage version is 18.
In case someone wants to test VoLTE support (which might still have issues) then install package ofono-binder-plugin-ext-qti and report how it works, at least sms seemed to work correctly but in my tests it ended up dropping to 2g during calls but since sms was causing issues on some operators hopefully this helps.
Hello @mal, thank you very much for the package ![]()
I have mixed results: I can now receive SMS when my FP5 is on 4G
What doesnāt work: sending.
This worked before when I switched back to 2G and turned flight mode on and off once.
However, I donāt know if this issue might be related to another problem: since 3 days the phone starts in a somewhat undefined state: the flight mode is on, my data connection is also on according to the icon, and when I deactivate the flight mode, nothing happens at first and the second click indicates that the process is in progress⦠Only restarting networks via Utilities helps.
[EDIT]: my provider is Wetell in Germany, which uses the Vodafone network.
Hello @mal, on FP4 SMS works both ways using ā5G preferredā.
On my phone it shows ā4G-Telefonie (VoLTE) ā registeredā.
Also mobile data and phone calls (both ways) works :-).
Many thanks Gabs
Oh, Iād like to add that I am also registered for VoLTE. Donāt know how to check if it is really using it, but the fact that I donāt hear the ring tone when I call somebody makes me think that it uses it.
That SMS sending issue is strange, that ringback tone issue does suggest it is trying to do VoLTE call, you should see if VoLTE is used during call from top status bar, if it has 4G or 5G there next to signal strength indicator then itās using VoLTE.
It seems that it really works in 4G, I have not been able to test 5G. I rarely have 5G in a larger German Cityā¦
