Thanks for confirmation, that’s what I thought too.
I’ve got the feeling - but can’t prove - that it happens since 4.2.0 more often than before (on my XA2).
I mostly have max. 4 apps running at the same time so it very rarely happened that an app was closed automatically. Now it seems to happen more often. But yeah, I don’t have real proof.
Neither in my Xperia 10. There’s manufacturer, device, imei, os- & drivers-versions, mac- & bluetooth-addresses, and encryption. But in Xperia X serial number is shown.
After a few days of use in 10 II (Dual SIM) I would say that 4.1 was operating more smoothly. Battery life is significantly reduced, loosing 40% overnight and phone barely lasts 24hrs (before it would easily survive 2 days). The text prediction as other mentioned takes for ever and freezes the phone once you select a word from the proposed ones. When on WiFi most of the Android apps think that there’s no internet connection. When walking outside the house, the phone keeps looking for the WiFi instead of switching to mobile data.
After flashing I had to do several reboots to get things working and at least once the phone was stuck with green LED on and no way to light up the screen. Exchange didn’t sync until after serveral reboots.
Tried all steps, no updates found. But seemes problem was fixed, at least from last night till this moment everything is fine. Maybe it was somehow related with post_sfos-upgrade command.
I updated my X10II to 4.2, but the gui method failed repeatedly, the download didn’t even start. I ended up installing sfos-upgrade and using it. The download went ok, but RPM script segfaulted on two packages: sailfish-ca and popt, so I had to try it three times. In the end everyting went fine and device works smoothly
bluetooth keyboard still doesn’t work properly on android apps. layout is always english, shift key does nothing. SFOS side works fine.
Bluetooth audio control buttons work for next/prev/pause, but not for play. See comment above. I’ll open a new bug report for this. Edit: Logitech keyboard media buttons don’t work, but JBL headphone buttons still work as before. No issue after all!
Bluetooth button on top menu desyncs on reboot (Bluetooth is on, button says it’s off. I think this is a known issue… Existed in 4.1 too.)
Triple camera works great!
Strikethrough over SMS bubbles on XA2 Ultra is still there
Edit: JBL bt headset works, except for calls. This was the case for SFOS 4.1, too. I’ll test it with XA2 Ultra on 4.2, too.
Overall it’s a great update, and no immediate regression popped up (except Whisperfish, and WLAN is untested, Bluetooth devices largely untested). Thanks again for great work!
Hello I would welcome any advice before updating my XA2. Sailfish recommends removing the following packages before updating: harbour-storeman and commhistory-daemon
Removing harbour storeman would be no problem. However I cant remove commhistory daemon. When using pkcon remove commhistory-daemon the terminal replies: fatal error this command leads to system crash.
What should I do? Some previous updates already broke my system - I really do not have time to setup my whole system again.
I have found a new bug (XA2 plus). After having received an MMS, no WLAN connection in 4g for Android apps. Connection OK after using “restart network connections” utility.
Well, the source of information I was using did not clearly state any exceptions. The serial number seems to appear on Xperia X and some business customer products only, not on XA2, 10 or 10II. After learning this, I decided to remove the mention of the serial number from the notes.
On an Xperia 10 II I experienced several cases of Battery drain with 4.2. that didn’t happen with 4.1. Today it was ofonod that ran at 100% CPU for hours. After an reboot everything is back to normal for now.
I just noticed the upcoming 4.2.0.21 update! Thank you so much! This in particular caught my eye:
Routing phone call voice to Bluetooth headsets improved, also by being less pedantic about the ordering of speech codecs
I knew it would be something like this, because I had some Bluetooth devices that worked and others that didn’t but they would all expose the same capabilities! Can’t wait to test my JBL with it!
