Ditto with me with Xperia 10 II. The update stuck at 100 % (=full bar).
After waiting about ten minutes and doing normal shutdown by pressing the power button, and then doing normal restart with pressing the power button, the device booted to 4.4.0.58 and things are seemingly ok.
Regarding the new bluetooth NFC pairing: I tested this with SONY WH-CH710N over-the-ear headphones which can be paired by NFC. However the headphones turned on once I came close to the NFC tag but pairing did not work.
NFC logger also did not show any PDUs received.
Maybe someone who bought a Xperia III with the headphone bundle can give it a try?
@svalmont I agree, this is really frustrating. Also the statement I read, that VoLTE will not come to âolderâ devices (Xperia 10). Itâs a well known fact, that these devices CAN VoLTE under Android out of the box, so why should it not be possible under SFOS?? The hardware can do it, the underlying original Sony binaries can do it, so I donât know whatâs against implementing it for the Xperia 10.
edit: @KuroNeko OK, so I have to correct myself: VoLTE will come later to older devices.
I experienced that issue a few times, but it resolved itself a few days later. Maybe try clearing the zypper cache, installing something from the store or just waiting a bit.
There were no statements about older devices. The only statement said, that it will come to the X10 II first, presumably because thatâs the hardware they are developing it on first. Presumably other devices will be supported at a later point, but it makes sense to target one specific set of hardware first instead of spreading out development resources trying to do everything at once.
Thank you for this update!.Much appreciated!
The update went smooth on my XA2 plus. Data were saved (sd card not possible because of broken card slot).
The browser is faster now.
MagicEarth starts faster (not yet checked while driving).
Fernschreiber: video calls not yet possible.
Storeman doesnât work anymore. Removing and re-installing does not help.
The same with Chum.
This annoying asking for all permissions occurs, because if the needed permissions are not defined in an app, it asks for all. And personally, I think this will be more a temporarily phenomenon until all apps are updated in near future and then will have their really needed permissions defined.
edit: Chum works if you go to Chum settings, there on the bottom of the page, enter â4.3.0.12â into Chum repository field. Then apps are back, but the old versions. For the future, to get the updated app versions as soon as they are available, you must then cancel this entry so that Chum searches for 4.4 versions in future.
Dear Jolla,
itâs really sad that there still is no Xperia 10 III support. I think last October you mentioned that the Xperia III will be supported around the beginning of next year. Since there was a really good black friday deal I ordered a Xperia III in November. Since then the brand new phone is lying around waiting for the Xperia III update. Meanwhile my Xperia 10 is slowly dying. It switches off constantly, probably due to battery degradation.
Will it take another 3 or 4 months now to get the next update with Xperia 10 III support? I just donât think the Xperia 10 will make it that long⊠I would have to leave the ship then and just start using the Xperia 10 III with the preinstalled Android OS. After 12 years using Nokia N9 / Jolla C / Xperia / Xperia 10 that would be sadâŠ
While Storeman will install on Xperia 10ii (download RPM harbour-storeman-0.2.12-1.aarch64.rpm and can install .rpm using the stealth (hidden) file manager in settings|storage|user data|download (directory where .rpm is saved - Once installed Storeman seems to be in a constant state of âInitialisingâ As a result the pull down menus for individual aps donât work.
Anything to get Storeman to work on Xperia 10ii with Sailfish 4.4. installed would be welcome please. Installed yes - able to function and install aps - NO.
If not, please unsubscribe the EA releases; they are not suitable for âgetting the updates earlierâ. They exist for people willing to test early and fully expecting that some things will break.
And if you have not found anything related to an issue you observe (though a solution was already reported here, yesterday), please at least try starting the app at the command line (e.g. here, harbour-storeman; and you would have seen that it works just fine) and report your issue at the issue tracker of that software including the CLI output of it etc.
If that is too demanding or just technical gibberish for you, then rather stay away from EA releases (or have multiple SFOS devices at hand, so it does not matter if one is unusable for weeks).
Please do look and search thoroughly (both) before writing complaints!
