Use built in file manager can install rpm
can do it by pkcon install sailfish-manager. Then there is a new icon there
âpkcon install sailfish-managerâ reports package not found.
[Unsolved] Xperia X 4.3.0.15 upgrade to 4.4.0.58
If I try to upgrade via System settings Iâll get the message that the âsystem cannot check the size oft he upgradeâ. The message gets even worse if I try the following in the terminal:
- devel-su
- ssu release 4.4.0.58
- version âdup
âThis request will break your device. Upgrade not complete.â
There is also OLFâs sfos-upgrade 4.4.0.58 which throws similar messages. Any help appreciated!
You could try running sfos-upgrade 4.3.0.15 to âsamegradeâ and check that the current installation is complete.
Does any command list incompatible packages?
Thanks for your advice. Everything is fine. The only message I got while sfos-upgrade 4.3.0.15 is â-Stopping osupdate-check.timerâ and âNO UPDATES FOUND. Try again later.â No incompatible items.
Thanks, Iâve got it. Added an EDIT to my comment.
Iâm a little confused now⌠What is âStock filebrowserâ and what is 'Filebrowser by @ichthyosaurus '? Isnât that the same?
I always thought that File browser is @ichthyosaurus 's contribution to SFOS and there is no other Filebrowser existing.
Now I have deinstalled @ichthyosaurus 's filebrowser and will reinstall it if better times will come.
For the mean time, is there another âStock filebrowserâ anywhere?
The stock âfile browserâ is the Settings > Transfers/Downloads view (idk my locale is Finnish).
Aha, found it⌠(iâm on a German system), here itâs called (in settings): âĂbertragungenâ, and itâs a list of the previous downloads. And this seems to work fine on the new system, all previous downloads are correctly listed there.
I donât think theyâre the same.
Oh. Oh! Thatâs very well hiddenâŚ!
Transfers should rather be called Downloads, IMHO, but cannot help. It is not the file manager. However, in Settings > Transfers one can easily install a downloaded rpm simply by tapping it.
Sorry.
pkcon install sailfish-filemanager
Thank you @ichthyosaurus for the quick fix!
In case of harbour-file-browser from @ichthyosaurus one kann add the following lines
[X-Sailjail]
Sandboxing=Disabled
to usr/share/applications/harbour-file-browser.desktop as discribed here for Storeman.
It makes the âhiddenâ files and folders seeable.
Yes, this Settings - Storage - pulldown Filemanager works fine and shows all files. I didnât know that this is also named âFile managerâ, not even that itâs thereâŚ
, sorry.
As said, this works.
I was talking before, of @ichthyosaurus 's File browser, thatâs no more working.
I installed âSailfish-filemanagerâ now and the installation worked.
But itâs the same bug as with @ichthyosaurus 's File browser: Exactly the same, existing, dirâs and file are not shown!
Hi. Upgrade failed for me on Xperia 10 II. I then finish it by usual ssu release 4.4.0.58 && version --dup. But now, call UI is not working! In journal I found out:
Xperia invoker[19796]: /usr/bin/voicecall-ui: symbol lookup error: /usr/lib64/qt5/qml/Sailfish/Telephony/libsailfishtelephonyplugin.so: undefined symbol: _ZN4i18n12phonenumbers11PhoneNumberC1EPN6google8protobuf5ArenaE
It is issue with my installation, or with release in general? All packages are up-to-date.
edit: when I start voicecall-ui from terminal, I get:
edit3: that symbol exists in /usr/lib64/libphonenumber.so.8.12, but I am not sure why it is failing?
edit4: force reinstalling related packages solves the issue. WTFâŚ
zypper --plus-content debug install -f \
libphonenumber libphonenumber-geocoding \
sailfish-components-telephony-qt5 voicecall-ui-jolla
Let me write an appreciation post for Sailjail: despite all the momentary issues now that the Big Switch is happening, sandboxing is a huge step forward in terms of security and I am glad that it was introduced.
Thanks Jolla!
Transfers show the outgoing items also, for example shared items via bluetooth. Therefore, âtransfersâ does seem like the correct name.
