Has anyone a solution for Amazfish? Is not working anymore in 4.4.0.58
Thanks!
Because IMS/VoLTE modem interfaces are proprietary, it takes time to reverse-engineer those. And the solution is likely to end up being vendor/device specific. But yes, itās possible. At least theoretically.
OK @slava , that I understand. Thank you for explanation. BUT, isnāt there a Sony Open Device program?
So, why canāt Jolla simple get the Open Device specs from Sony instead of reverse-engineering something? And, as I understood until now, the whole SFOS project is vendor/device specific. There are a few Sony devices officially supported plus some community ports inofficially. And, what is so top secret on some fu**ing VoLTE specs, that is the industrial standard in telecommunications of the whole world in the next decade? Why canāt Sony be so nice and kindly provide their VoLTE specs as part of their Open Device program? I do not understand this.
edit: Or is simply legal and/or economic stuff the reason for this misery?
If you wish to dive deeper - yes, Google standardized IMS/VoLTE interfaces and Sony provides implementations of those but they are Java interfaces, meaning that to actually use them you would have to bring up the whole Android VM. That doesnāt help SFOS adaptation. The lower level interfaces usable by SFOS and particularly ofono (e.g. binder APIs) are proprietary and require reverse-engineering (albeit not a super-difficult one).
Itās not clear yet if thatās a trend or not, but that could mean a deliberate shift towards hiding native interfaces and making it harder to use native Android drivers/middleware in non-Android systems like SFOS.
Updated, seen this couple of times now: something is using location services in background (the indicator is flashing on top of the display) causing a power drain.
Hi there, Today i start new update on my new experia 10 ii dual sim but i all ready wait 5 hours and still freezing in the end of update(progress) bar before finish update⦠what to do because I donāt have any response⦠and i think after battery drain the phone will shut down and then will be dead ⦠What can i do and i donāt wanna lose my data ?
Sticking progress bar at the end of update procedure is often reported and in most cases the new system works fine after a forced reboot by long pressing the power button.
but: no guarantee !
Most works just great, but for me the browser does not open links when asked?
So, when I tap a link somewhere, it launches the browser but then nothing happens. Also, for a website is attached to the app grid, tapping on it launches the browser, also nothing happens.
Anyone here with the same issue?
As it was my bug report your are referring to, I can confirm this is indeed fixed in SFOS 4.4.
Your piece of code seems to work for me. Even tried version 4.0.9 of your app, before you removed this part of the code in 4.0.10. Your download function in 4.0.9 also worked for me using SFOS 4.4 on my Xperia XA2 plus.
BTW I did not enable sailjail yet for my use case (āwelkweerā app), as it will most likely break for 4.3 users (as 4.3 has this bug). But will do so as soon as 4.4 is out of EA.
P.s. why not put your code on some public git repo. Makes searching in the code and tracking changes a lot easier.
Hi,
Thanks for your help
I canāt understand where is the problem!
you have tell me that itās work on Xperia XA2 plus (with SFOS 4.4)
but in my Xperia X I get this error āCould not load pageā if I comment lines (contextkit) its work
I have also tried:
[X-Sailjail]
Sandboxing=Disabled
but not work!
Perhaps the bug was not corrected in Eperia X ?
I have verified in Terminal (zypper pa -i > everything.txt) if nemo-qml-plugin-contextkit exist in my Eperia X but I can find it! perhaps itās not installed!
Can you please verified that on your XA2 plus.
Hi
Can any one please verifier if the package ānemo-qml-plugin-contextkit-qt5ā is in SFOS 4.4 for Xperia X (2sim)
in Terminal :zypper pa -i > everything.txt
Rem: I have doing that manually!
Documents app doesnāt start in 4.4.0.58 EA. Only appcover with endless running circle is shown. Removing the app and reinstall doesnāt work.
So the import of contextkit simply fails in your case. Maybe try to reinstall this package?
I have the following version installed in SFOS 4.4: nemo-qml-plugin-contextkit-qt5-1.1.12-1.5.1
Have you opened the browser on its own, via the app-drawer? If I recall correctly, I had the same issue, because sailjail init for the app hadnāt happened yet.
Documents app opens normally on both of my devices⦠Does it open from the terminal?
If the browser is already running, it works indeed. So maybe some arguments get discarded because of SailJail?
If the right name is sailfish-office, no.
From terminal I got this:
[defaultuser@Xperia10II-DualSIM ~]$ sailfish-office
library ālibGLESv2_adreno.soā not found
library āeglSubDriverAndroid.soā not found
Yes it is. Those errors are always there, so not fatal.
Has anybody problems with the new browser?
It sometimes terminates. Maybe it is related to memory - since I have had huge apps like Teams and Outlook (Android) running.
Update:
The last time, it seemed to have another cause.
With EMBED_CONSOLE=1, the log shows
Call EmbedLiteApp::StopChildThread().
It was here in this forum page. Is there a good way to debug spontaneous terminates?
Xparia 10 II: GUI install failed as I did not remove storeman, Wisperfish and one another⦠After GUI install announced failure, OS was showing the version 4.4, but almost everything was the same as in 4.3. Then I used sfos-upgrade and it finished the job. So far so good. Storeman refused to start, so I removed it and installed storeman-installer. ATM, it fails to install storeman - therefore no usable storeman ATM. Hope storeman and storeman-installer get fixed in near future.
No other critical issues detected so far except for less or more all applications requesting permissions and those permissions requested are way over what Iād expect they should have.
What I miss the most: MFA support for exchange onlineā¦
