My df -h shows that I am using 611.4MB out of 820.6MB in /opt…
I did a du -ax /opt | sort -nr, the biggest file is indeed system.img, and the /opt/qt5 folder has a total size of ~230MB. The biggest file under /opt/qt5 is /opt/qt5/lib/libQt5WebEngineCore.so.5.15.17, which is around 80MB, like one-third of the whole /opt/qt5.
I do not recall installing additional Qt5 libraries / modules by myself - I seldom do such kind of things. Still puzzled…
I’m puzzled how this is an All Access release and not early access/beta.
I got a long list of core packages (libhybris-*, busybox-*, appsupport-*, sailfish-version* and some others) that I have to remove to proceed with the update, while I may be able to deal with that on my own if we want a broader appeal this really shouldn’t happen.
Also last time I had to remove appsupport to update it messed up my app grid, at the very least there should be a way to revert to the layout with android apps the moment app support returns to the phone instead of forcing a complete rebuild.
Thank you for publishing the beta versions of Xperia 10 V images. Now I was able to easily install it on my device!!!
Great. Also already purchased another license in order to support you and get Android App Support as soon as it is available. How can I link the license with my 10 V device? Or will it eventually just work, if I have enough licenses for all my devices listed in my account?
Looking at the filename and path, that seems to be part of Qt 5.15 packages available from Chum. Perhaps you tried Angelfish which pulled those in? Try running this command to see of that could be the case:
in short: you don’t have to manually remove anything, simply confirm the message and let the installer proceed.
TLDR: the installer tells you, that you should remove the old packages but this is only a wrong wording. It means really that the installer will do so. You haven’t to do anything, simply proceed by confirming the message. This issue is an old one. I’m more than 5 years with SFOS and had this message occuring most times on updating. I always ignored the message and proceeded and could successfully update, except one time a few years ago. This time I really removed the mentioned packages and the result was a completely broken system and I had to reflash.
Has anyone here installed sailfish in Xperia 10 IV? I’ve tried it, but the sound output in all voice calls are through the loudspeaker, I haven’t read about this bug
For me I don’t get messages like that every time, but when I do the update fails and I end up running it from CLI or running parts from CLI, as said previously I don’t mind I have been using Linux for a long time but I do wonder how this is a positive user experience for a “normal” user, especially since stuff like removing appsupport instead of upgrading it also messes up the app grid and may cause stress that stuff that is supposed to be there is gone.
