No. The free version for the 10 IV & V was said to be released “in 1-2 months” counting from the Jolla Love Day 2, whereas the paid components (i.e. the AppSupport) were said to come out in August.
This is a screenshot of their presentation:
I would like to point out that the following bug
has not been solved and it renders the device next to unusable.
Just to mention an example from this morning, I went out by car to go to work and started Waze; connectivity was f**ed up, Waze did not connect and I missed information about a road accident which blocked my usual road. After some time in the queue, I managed to get connectivity back (this time it required a reboot, looks like there is another bug with Android connectvity but I cannot single it out until this one is solved). I took a secondary road to go back and take an alternate way, only to find TWO construction sites with alternating traffic regulated by traffic lights. This resulted in about half an hour wasted during my commute.
As I unfortunately still see the massive audio (routing) issues on a Xperia 10 II with this update, I’ve decided to summarise all the different kinds I’ve encountered so far again. Xperia 10 III audio and video problems trigger after a period of time in use - #60 by schmittlauch
Subjectively it might have even gotten worse and the issues appear more frequent, at least nothing has improved with the 4.6.x updates.
Tethering (USB or WIFI) : ip_forward setting is missing when tethering is used.
I had to set it manually
Niether has the issue of duplicate buttons, like ‘flashlight’ or ‘Do Not Disturb’, been fixed in 4.6.0.13 as stated either. I had this issue again this morning when I added the ‘Hotspot’ button in settings. What I got was two flashlight buttons (both working and turning the flashlight on/off) instead. I had to remove the flashlight button from the menu to get rid of both of them, and then one of them turned into its correct hotspot button.
For me the Android connectivity issue is better, but certainly not solved. Its happened to me twice since upgrading to 4.6.0.13.
On the question of whether to upgrade now, or later - when it might be safer:
Do we have to go through 4.6.0.13 anyway, or could I jump from directly from 4.5.x.xx to 4.6.0.14?
I believe the answer here depends on whether this release is considered a ‘stop release’…
That’s still to be determined.
In terms of fixed Vulnerabilities, i would upgrade now.
Podcatcher does work, Use the Jolla store version, Openrepos has an old version. Happiness joyous swells within my breast.
Navigation
(Here Wego)
Mail
Telefone
SMS
Mail
Threema
Signal
Telegram
Vodafone… Has to be startet via settings.
Works for me.
And the best thing is: I can search my calender.
Still needs an android browser to run Tuta (for encrypted mail and calendar).
There is no official message of release of 4.6 yet?
Not here in the forum, but found no new blog post on Jolla’s blog, and no tweet.
Look the first post. Even if not blogged I guess that it’s official. Or something
Midsummer? Everyone busy with
See this Thread above …
Sony Xperia 10 III (public release) here… I tried the update, ignored the warnings (did this for many updates already… now it was a very bad idea as it seems) and now the smartphone is in a boot loop with a white screen saying “no apps started”.
So I tried to go to the recovery mode using this article (Recovery Mode | Sailfish OS Documentation) but the problem is: I can flash the recovery image file to both boot_a and boot_b (and even back to hybris-boot.img) but when I try to start it it just says " Your device is corrupt. It can’t be trusted and won’t boot.” and it does not go into the recovery mode no matter what.
Like that, telnet isn’t possible (yes my computer is able to do it, but SFOS is not in the right mode).
I do not (constantly) see the device “RNDIS” in the device manager of my windows machine.
When I start the smartphone, a very short time it is recognized (with drivers installed as it seems) when the SFOS logo is on the screen but 1 or 2 seconds later it disapears again.
The only recovery mode I can (sometimes with the right timing) access seems to be the one of the phone itself called “Android Recovery” where i do see a couple of options but nothing about the shell.
Reboot system now
Reboot to bootloader
Enter fastboot
Apply update from ADB
Apply update from SD card
Wipe data/factory reset
Mount /system
View recovery logs
Run graphics test
Run local test
Power off
Any idea what I am doing wrong?
I can reflash with “fastboot flash boot_a hybris-boot.img” and “fastboot flash boot_b hybris-boot.img” without a problem and am in the same state again (flashing white screen no apps installed).
Yes my phone’s bootloader is unlocked. (there is a big notice when I start the phone even now). I can not use “fastboot oem device-info” to see it (“unknown command”) but I can see it if I do “fastboot getvar all” too.
I would like to get into telnet somehow to restore some data. Any help would be highly appreciated.
Best regards and thanks for any answers
Fuchur
install on a 10iii has gone very nicely.
even have android service starting automically!
Searching key words “Your device is corrupt” (with the quotation mark), I found this topic: "Your device is corrupt. It can't be trusted and won't boot." after reflashing - #8 by robthebold
This may be a lead to fix your problem.
Thank you very much, but they are only talking about reflashing the phone, which might be the only “end” solution I can find, but before that, I would like to get some data from my phone which I can not since I cant go to Recovery mode (the one from Sailfish instead of Android). In recovery mode I should be able to go to the shell and transfer data to an microsd card.
It might even be possible to get the phone to a running state with telnet as far as I understand (for instance by removing OSM scout server and something else I do not remember at the moment) but before that I need to go to the recovery mode to get telnet access.
Best regards
Fuchur
What I assume is, that my phone never did the update to 4.6 but is still on 4.5.0.25(?) and the flash “hybris-recovery.img” which I have is for 4.6.0.13. (why ever Jolla is not providing at least the last one before that too in case you need to recover after a faulty update is beyond me…)
