i can confirm that. I have the same while I try to move from the XA2 to the 10II.
They figured it out at Restore backup from Xperia X to Xperia 10 II fails when restoring Notes
Symlink /home/nemo quite smart.
Jolla should have an official guide posted as to where is all personal information (phone log/contacts/sms/notes) stored and how to edit/backup/restore it.
We have Cheat Sheet, but years pass and I still didnât get an answer how I can edit sms DB with wal-shm files thru sqlite3 so that it makes a difference.
See here, although it doesnât list export function.
On Xperia 10 II the volume during a call is quite low and the other side has an echo when the loudspeaker are turned on. Can this be adjusted (it was possible somehow in the ancient times, I think)
Thanks. commhistory-tool does have export param listed in --help, although copying database seems to have worked also.
I experience that on my X10 also.
Please note
and especially
Hi all
I flashed SFOS 4.1.0 yesterday on my brand new Xperia 10 II, it went almost flawlessly
Many thanks to the whole Jolla team for your hard work !
Cheers, Samuel
I have a question regarding the 10 ii. I received mine today, and I want to install SFOS 4.1 on it. I am currently waiting for the Android 11 update to finish, but reading the instructions here:
I shall upgrade to Android 11, but then download Sony software binaries for Android 10 in step 5. Is this a typo and should be software binaries for Android 11, or is this correct?
Confusing, but correct (@jovirkku maybe should be made more clear or noted more verbose?)
And see here:
Thanks.
Post most be at least 20 characters.
There is a simple button for that ![]()
Plus is no more possible to sort ambiences by favouriting them.
⊠and it sorts itself, depending on usage. But in a strange wayâŠ
This is correct. They are two different things. The quote from rinigus by peterleinchen explains it. Also check the chapter beginning with " A quick clarification of what an underlying Android version adaptation" in the latest blog.
I activated and deactivated developer mode a few times.
And I ended up with 3 terminals in the launcher.
Removing dev mode doesnât remove the terminal icon and I canât delete them.
Is this a bug or something known? How do I remove these 3 terminals?
I tried to put them in a folder. Only one goes in. But when moving it out, I end up with an empty folder I canât delete either.
Are there desktop files for it in ~/.local/share/applications?
Nothing special, only mimeinfo and open-url.
There is a fingerterm.desktop is /usr/share/applications but I donât want to mess with system files.
But I played putting the shortcuts in and out the folder, activating and removing dev mode, and I got them removed. Though the empty folder is still there.
