[Release notes] Finlayson 5.2.0.22
So far so good on the 10 II and 10 III, only one thing: i cannot connect to the Jolla Store as well, it seems.
Would you mind elaborating on this a bit? Does this resolve the aggressive noise reduction outlined in Jolla Phone Camera: Too many details are lost - #72 by j6s ?
I didn’t update yet and there is a communication problem with the Jolla store. (5.2.0.20)
Awesome! my display looks way better now and there is no weird green/red glow anymore
Look like Jolla store is down.
Store issue is being investigated.
Edit: Store has been fixed.
My JP2026 rebooted three times, then a black screen for a while and then booted up. Ugh, it was a bit tense.
It looks like the Store is back.
On my C2, the PIN keyboard doesn’t work when turning on the device from the off state to enter the LUKS PIN. I have to press the power button, wait a few seconds, and press it again to turn on the screen; then the keyboard works.
Update went through without problems on the C2 and JP26.
Same here. Will try later.
And it’s done. :slight_smile:
20 Characters
Have a read of the following posts for some tips on how to free up space. Removing App Support would be a last resort for me:
Update went smoothly and the display on Jolla Phone 2026 is night and day compared with what it was before the update. Photos also look more vivid and crisp now. Thank you for the fix!
In my experience that just works fine.
Thanks for the update. Process went smoothly and camera has improvement, can be seen.
Did someone secretly replace my phone’s screen during the update? It feels like I went from a crappy LCD to a Retina display.
Are the browser and AAS updates included for older devices, like the C2?
My browser seem to still be Gecko 91 and AAS says it’s Android 13.
EDIT: False alarm about the browser.
Browser on my C2 seems 115. How did you tested?
OTOH AAS versions does says 13.
AAS 13 on the 10 II and 10 III too.
Jolla store came back to life, as noted by others :blush:
Hi,
The issue with setting the Android PIN hasn’t been fixed yet, has it? I just read that the C2 is still only running Android 13 after the update. Is that correct? Because if so, the patch from Openrepos would still work.
