I’m experiencing random system crashes which don’t seem to be triggered by any specific application. They follow the similar pattern as mentioned by a user in February with the bootloader loading followed by the Sony logo and then black. The only way to get the system up again is to have the device charging. Obviously this is troublesome when moving about.
I’ve managed to capture some logs with journalctl -ab --no-pager > $MYHOME/journal.txt :
Sep 11 22:14:18 Xperia10II-DualSIM mce[1665]: tklock.c: tklock_dbus_notification_end_cb(): notification end from name=:1.56 owner=:1.56 pid=5264 uid=100000 gid=996 priv=1 cmd=/usr/bin/lipstick -plugin evdevtouch -plugin evdevmouse -plugin
Sep 11 22:14:18 Xperia10II-DualSIM lipstick[5264]: [W] unknown:0 - Effect failed, id 27
Sep 11 22:14:18 Xperia10II-DualSIM lipstick[5264]: [W] unknown:0 - Effect failed, id 28
Sep 11 22:14:19 Xperia10II-DualSIM lipstick[5264]: [W] unknown:0 - Effect failed, id 29
Sep 11 22:14:19 Xperia10II-DualSIM lipstick[5264]: [W] unknown:0 - Effect failed, id 30
Sep 11 22:14:19 Xperia10II-DualSIM lipstick[5264]: [W] unknown:0 - Effect failed, id 31
Sep 11 22:14:19 Xperia10II-DualSIM lipstick[5264]: [W] unknown:0 - Effect failed, id 32
Sep 11 22:14:19 Xperia10II-DualSIM lipstick[5264]: [W] unknown:0 - Effect failed, id 33
Sep 11 22:14:19 Xperia10II-DualSIM lipstick[5264]: [W] unknown:0 - Effect failed, id 34
Sep 11 22:14:19 Xperia10II-DualSIM lipstick[5264]: [W] unknown:0 - Effect failed, id 35
Sep 11 22:14:19 Xperia10II-DualSIM lipstick[5264]: [W] unknown:0 - Effect failed, id 36
Sep 11 22:14:20 Xperia10II-DualSIM lipstick[5264]: [W] unknown:0 - Effect failed, id 37
Sep 11 22:14:20 Xperia10II-DualSIM lipstick[5264]: [W] unknown:0 - Effect failed, id 38
Sep 11 22:14:20 Xperia10II-DualSIM lipstick[5264]: [W] unknown:0 - Effect failed, id 39
Sep 11 22:14:21 Xperia10II-DualSIM mce[1665]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: OPEN -> UNDEF
Sep 11 22:14:22 Xperia10II-DualSIM invoker[5929]: WARNING: An inactive plugin is misbehaving - tried to show a window!
Sep 11 22:14:22 Xperia10II-DualSIM invoker[5929]: WARNING: requestActivate() called for QQuickView(0x15ec9a50) which has Qt::WindowDoesNotAcceptFocus set.
Sep 11 22:14:23 Xperia10II-DualSIM invoker[5929]: WARNING: An inactive plugin is misbehaving - tried to show a window!
Sep 11 22:14:23 Xperia10II-DualSIM invoker[5929]: WARNING: requestActivate() called for QQuickView(0x15ec9a50) which has Qt::WindowDoesNotAcceptFocus set.
Sep 11 22:14:25 Xperia10II-DualSIM kernel: pmi632_charger: somc_aicl_irq_handler: IRQ: aicl-done
Sep 11 22:14:25 Xperia10II-DualSIM kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:5160
Sep 11 22:14:25 Xperia10II-DualSIM estart[6000]: [W] unknown:0 - Effect failed, id 14
Sep 11 22:14:25 Xperia10II-DualSIM estart[6000]: [W] unknown:0 - Effect failed, id 15
Sep 11 22:14:25 Xperia10II-DualSIM estart[6000]: [W] unknown:0 - Effect failed, id 16
Sep 11 22:14:25 Xperia10II-DualSIM estart[6000]: [W] unknown:0 - Effect failed, id 17
Sep 11 22:14:26 Xperia10II-DualSIM estart[6000]: [W] unknown:0 - Effect failed, id 18
Sep 11 22:14:26 Xperia10II-DualSIM estart[6000]: [W] unknown:0 - Effect failed, id 19
Sep 11 22:14:26 Xperia10II-DualSIM estart[6000]: [W] unknown:0 - Effect failed, id 20
Sep 11 22:14:26 Xperia10II-DualSIM estart[6000]: [W] unknown:0 - Effect failed, id 21
Sep 11 22:14:26 Xperia10II-DualSIM estart[6000]: [W] unknown:0 - Effect failed, id 22
Sep 11 22:14:26 Xperia10II-DualSIM estart[6000]: [W] unknown:0 - Effect failed, id 23
Sep 11 22:14:26 Xperia10II-DualSIM estart[6000]: [W] unknown:0 - Effect failed, id 24
Sep 11 22:14:26 Xperia10II-DualSIM estart[6000]: [W] unknown:0 - Effect failed, id 25
Sep 11 22:14:27 Xperia10II-DualSIM estart[6000]: [W] unknown:0 - Effect failed, id 26
Sep 11 22:14:36 Xperia10II-DualSIM kernel: i2c_geni 4a88000.i2c: i2c error :-107
Sep 11 22:14:38 Xperia10II-DualSIM kernel: pmi632_charger: somc_aicl_irq_handler: IRQ: aicl-done
Sep 11 22:14:38 Xperia10II-DualSIM kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:5195
Sep 11 22:14:47 Xperia10II-DualSIM kernel: i2c_geni 4a88000.i2c: i2c error :-107
Sep 11 22:14:51 Xperia10II-DualSIM kernel: pmi632_charger: somc_aicl_irq_handler: IRQ: aicl-done
Sep 11 22:14:51 Xperia10II-DualSIM kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:5195
Sep 11 22:14:57 Xperia10II-DualSIM dbus-daemon[5104]: dbus-daemon[5104]: [session uid=100000 pid=5104] Activating service name='com.google.code.AccountsSSO.SingleSignOn' requested by ':1.143' (uid=100000 pid=26690 comm="/usr/libexec/buteo-oopp-runner nextcloud-posts nex" label="u:r:kernel:s0")
Sep 11 22:14:57 Xperia10II-DualSIM invoker[5140]: SailfishKeyProvider_storedKey(): error: no scheme or key found for provider/service
Sep 11 22:14:57 Xperia10II-DualSIM dbus-daemon[5104]: dbus-daemon[5104]: [session uid=100000 pid=5104] Successfully activated service 'com.google.code.AccountsSSO.SingleSignOn'
Sep 11 22:14:57 Xperia10II-DualSIM buteo-oopp-runner[26690]: [D] unknown:0 - Sending request: "GET" to: "https://[redacted]/ocs/v2.php/cloud/capabilities" data: ""
Sep 11 22:14:57 Xperia10II-DualSIM kernel: i2c_geni 4a88000.i2c: i2c error :-107
Sep 11 22:14:58 Xperia10II-DualSIM mce[1665]: modules/cpu-keepalive.c: cka_session_finish(): long session lasted 1803056 ms; id=132/BlockSuspend-22 name=:1.46 owner=:1.46 pid=5152 uid=100000 gid=996 priv=1 cmd=/usr/bin/msyncd
Sep 11 22:15:04 Xperia10II-DualSIM kernel: pmi632_charger: somc_aicl_irq_handler: IRQ: aicl-done
Sep 11 22:15:04 Xperia10II-DualSIM kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:5195
Sep 11 22:15:06 Xperia10II-DualSIM logd: logdr: UID=0 GID=0 PID=26721 b tail=0 logMask=19 pid=0 start=0ns timeout=0ns
Sep 11 22:15:07 Xperia10II-DualSIM kernel: i2c_geni 4a88000.i2c: i2c error :-107
Sep 11 22:15:10 Xperia10II-DualSIM buteo-oopp-runner[26690]: [D] unknown:0 - "{\"ocs\":{\"meta\":{\"status\":\"ok\",\"statuscode\":200,\"message\":\"OK\"},\"data\":{\"version\":{\"major\":25,\"minor\":0,\"micro\":5,\"string\":\"25.0.5\",\"edition\":\"\",\"extendedSupport\":false},\"capabilities\":{\"core\":{\"pollinterval\":60,\"webdav-root\":\"remote.php\\/webdav\",\"reference-api\":true,\"reference-regex\":\"(\\\\s|\\\\n|^)(https?:\\\\\\/\\\\\\/)((?:[-A-Z0-9+_]+\\\\.)+[-A-Z]+(?:\\\\\\/[-A-Z0-9+&@#%?=~_|!:,.;()]*)*)(\\\\s|\\\\n|$)\"},\"bruteforce\":{\"delay\":0},\"metadataAvailable\":{\"size\":[\"\\/image\\\\\\/.*\\/\"],\"gps\":[\"\\/image\\\\\\/.*\\/\"]},\"files\":{\"bigfilechunking\":true,\"blacklisted_files\":[\".htaccess\"],\"directEditing\":{\"url\":\"[redacted]
Sep 11 22:15:11 Xperia10II-DualSIM buteo-oopp-runner[26690]: [D] unknown:0 - Sending request: "GET" to: "[redacted]/ocs/v2.php/apps/notifications/api/v2/notifications" data: ""
Sep 11 22:15:17 Xperia10II-DualSIM kernel: pmi632_charger: somc_aicl_irq_handler: IRQ: aicl-done
Sep 11 22:15:17 Xperia10II-DualSIM kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:5195
Sep 11 22:15:17 Xperia10II-DualSIM kernel: i2c_geni 4a88000.i2c: i2c error :-107
Sep 11 22:15:23 Xperia10II-DualSIM buteo-oopp-runner[26690]: [D] unknown:0 - "{\"ocs\":{\"meta\":{\"status\":\"ok\",\"statuscode\":200,\"message\":\"OK\"},\"data\":[]}}"
Sep 11 22:15:23 Xperia10II-DualSIM buteo-oopp-runner[26690]: [W] unknown:0 - No 'data' entry found in notifications JSON response!
Sep 11 22:15:23 Xperia10II-DualSIM mce[1665]: modules/cpu-keepalive.c: cka_state_set(): long keepalive stopped after 1827250 ms
Sep 11 22:15:28 Xperia10II-DualSIM kernel: i2c_geni 4a88000.i2c: i2c error :-107
Sep 11 22:15:30 Xperia10II-DualSIM kernel: pmi632_charger: somc_aicl_irq_handler: IRQ: aicl-done
Sep 11 22:15:30 Xperia10II-DualSIM kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:5195
Sep 11 22:15:31 Xperia10II-DualSIM kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:5222
Sep 11 22:15:31 Xperia10II-DualSIM mce[1665]: modules/battery-udev.c: mcebat_update(): battery_level : 53 -> 54
Sep 11 22:15:33 Xperia10II-DualSIM booster-qt5[5107]: *** signal=17 pid=5107
Sep 11 22:15:38 Xperia10II-DualSIM kernel: i2c_geni 4a88000.i2c: i2c error :-107
Sep 11 22:15:43 Xperia10II-DualSIM kernel: pmi632_charger: somc_aicl_irq_handler: IRQ: aicl-done
Sep 11 22:15:43 Xperia10II-DualSIM kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:5222
Sep 11 22:15:48 Xperia10II-DualSIM kernel: i2c_geni 4a88000.i2c: i2c error :-107
