Qt5-plugin-geoservices-osm does not permit setting host/customhost
REPRODUCIBILITY: 100%
OS VERSION: 4.4
HARDWARE: xperia 10ii, volla/gs290
UI LANGUAGE: en
REGRESSION: yes
As reported (see below) qt5-qtlocation changes from 5.2.1 on the version 3.4.0.24 to 5.4.2 on the version 4.1.0.24
At this point we can no longer load custom host plugin parameters, for instance: osm.mapping.custom.host
Have upgraded to SFOS > 4.1
Try to create a QML Map element:
        Map {
            anchors.fill: parent
            zoomLevel: (maximumZoomLevel - minimumZoomLevel)/2 + 4.5
            plugin : Plugin {
                PluginParameter { name: "osm.useragent"; value: "Draftmap" }
                PluginParameter { name: "osm.mapping.host"; value: "https://tile.openstreetmap.org" }
                PluginParameter { name: "osm.mapping.custom.host"; value: "https://tile.openstreetmap.org" }
                PluginParameter {
                    value: "Ā© <a href=\"http://www.openstreetmap.org/copyright\">OpenStreetMap</a> contributors"
Regardless of what you set host values to you get:
[W] unknown:0 - QGeoTileRequestManager: Failed to fetch tile (1169,566,11) 5 times, giving up. Last error message was: ā€˜Host otile1.mqcdn.com not found’
map tiles.
Error messages
Additional previous discussion:
Ah, Well looking at the code in the sfos repos, it’s no wonder. That’s from before the changes in 2016 that ā€˜fixed’ the hardcoded foo. And the broken qt redirector! Ach, weh.
Thanks for digging in to this @poetaster. Could you elaborate on your followup comment a little please though? Are you saying that there is an issue, but that the reason is obvious, or are you saying that this isn’t actually an issue after all?
Sorry, I was being elliptical. What I’m suggesting is that there may be a gpl issue that happens to coincide with a bug fix. jolla didn’t pick up a fix because they stopped at ā€˜$version’.
In any case, I pulled apart the spec in SFOSs Location .spec and started on getting ā€˜only’ that plugin (at 5.10) built on obs. I’ll try to get that done and see if the issue is dealt with.
In the current state, it is a bug in SFOS version of Location.
Thanks for the explanation Mark. I’ve created an internal issue for this and have tagged it as ā€œtrackedā€. If I can find out anything further (e.g. in case this was licence-related) I’ll post it back here.
It would be good to know the results from your OBS build once you have it.
Thanks! I’m struggling on a couple of other fronts but it’s in the queue!
Although this leaves a bad taste in my mouth, this minimal change is probably enough to resurrect the plugin from complete uselessness:
This is not ā€˜quite’ building on obs, but almost :slight_smile: GitHub - poetaster/qtlocation at backport5.5
All lgplv2.1 backports that would permit setting the uri of tile servers dynamically.
