Problems via Nextcloud, can't connect - invalid username or password even though they are correct
Trying to connect Nextcloud via Settings > Accounts or CalDAV / CardDAV does not work. It says username or password is incorrect. Logging in via the web browser with the same host, username and password works. In the Nextcloud Admin Logs I can see “Invalid password” and also “Too Many Requests” errors.
My suspicion is that some characters in the password, since I use a very strong password, is not encoded correctly by the system? It seems I can connect CardDAV if I deselect the CalDAV integration.
Hi!
Your bug report is unfortunately incomplete. Please complete it to ease the bug triage.
Have you got your server’s well-known configs setup correctly? I had a similar issue and that was the cause.
Alternatively, can you use an app password for Sailfish, at least as a troubleshooting step?
I use Nextcloud All In One Container so I have done no file modifications myself and I would rather not start doing that since also my containers auto-update via Watchtower service so any changes would dissappear.
I will try creating a test account in Nextcloud with a simple password to see if the password is the issue
Check well-known by going to eg. https://your-server.com/.well-known/carddav
Ok I got redirected to /remote.php/dav/ with the message
This is the WebDAV interface. It can only be accessed by WebDAV clients such as the Nextcloud desktop sync client.
Same behaviour with .well-known/caldav..
Do you have 2fa enabled? Then username/pw wont work. Create a dedicated APP password under Settings/Security.
No I don’t have it enabled and it worked logging in via the browser without any 2FA. I created a new user with a simple password and it worked so my hunch seems to be right, something in the password is not encoded correctly
I got my phone yesterday so everything is new, I guess I need to find the information to do a proper bug report
Cool, that’s not the problem then
Interesting. An App Password is probably the best workaround for now, but it’s certainly a genuine bug that needs fixing if this is indeed the case.
Thank you for the tip, it worked by using an App Password instead
Maybe related to
That sounds reasonable, esp as there is a known bug in Qt that doesn’t do the encoding correctly (or rather, the real world practices have deviated from the standard, and Qt is following the standard).
There have been fixes merged for that but the situation is not perfect still.
Tried something different.
WebDAV from a different service than NextCloud. Figured NC WebDAV account configuration to be standard, apart of branding, as the service itself.
Server URL https://webdav-[user].alwaysdata.net , Backup and Sharing only, do not Authenticate at creation. Then Advanced settings all fields to blank.
Selecting Sync did nothing. Update sign-in credentials returned the error on Server URL/.well-known.
  • On macOS mounts w/o issues
  • curl -s -X PROPFIND ${WEBDAV_URL} -u $USERNAME:$PASSWORD -H “Depth: 1” | xmllint --format - returns the xml representation of DAV root dir
  • on Firefox after authentication again DAV root dir content is shown.
In this case there is no issue of complex redirects. Alwaysdata serves WebDAV directly from the URL above.
GhostCloud app WebDAV works though.
Accounts in Settings is only meant to provide authentication configuration to other apps. For NC I don’t know which one.
Trialing v4.4 on an oldie.
Ps: forum admins if possible move my post under PCloud cloud storage . It belongs there I believe.
Similarly to what @Sharks said; try de-activating as many server options as possible. I had a similar issue, which I commented below:
Pardon me for asking but after setting up NC under Settings : Accounts which app do you use leveraging the new account? For files access and syncing.
My needs are very basic (backup and upload images), but for syncing folders:
Also check the list of threads at the end of this veeery long post:
EDIT: test also:
Sync images:
Notes:
Sailsync does not appear to be available in the Jolla Store. Any particular reason for that?
@ez for ferry sync: currently available on CHUM but jolla app store is on the roadmap (need to move sync-daemon into separat package first)
Edit: installed FerrySync and it works.
Edit 6: @DominikH why harbour-ferry saves config files with the user defaultu ?
Edit 7: Also trying to --config ~/.config/harbour-ferry/harbour-ferry/rclone.conf for experimenting but asks for a password: is not the root password so any hint? I found something because $RC listremotes --config $CONFIG returns ferry: but is not in plain sight there?
