I’m using a patch for rotation (does’nt matter which, same result with any of them).
In landscape, the app inside PartnerSpace does rotate, but the actual partnerspace (container/window??) does not.
So it misbehaves badly. As soon as you swipe into it, the homescreen rotates back to partrait =>Swiping from the right brings up the app launcher.
From bottom or top: Events View and multitasking view.
Swiping from the left however; though it does bring up Top Menu, brings it up from the side (but in a landscape orientation), chopped out with messsed up behavior.
And I know Sailfish OS doesn’t support landscape orientation by default for the homescreen(s), but I hope Jolla would do something about it anyway.
In the meantime, maybe someone has some insight on making partnerspace behave coherently and consistently with the rest of the homescreens/views.
I think this behavior is common on all hardware, but mine is XA2(4.5.0.24).
