No outgoing calls possible on VollaPhone GS290
I use Sailfish 4.5.0.19 on GS290/Vollaphone and get just mobile data to work again. But since 4.5 I cannot have outgoing calls everytime I get the message “no network”. What do I Have to do for being able to call out? What packages are needed? here is my setup
# cat /etc/ofono/ril_subscription.conf
[root@VollaPhone defaultuser]# cat /etc/ofono/ril_subscription.conf
# Ofono configuration for Volla yggrasil
[Settings]
#EmptyConfig=false
#Identity=radio:radio
#3GLTEHandover=true
#SetRadioCapability=auto
SetRadioCapability=off
emptyPinQuery=false
radioPowerCycle=false
confirmRadioPowerOn=false
useDataProfiles=true
mmsDataProfileId=1001
#May need this
#singleDataContext=true
[ril_0]
transport=binder:name=slot1;interface=radio@1.4
name=slot1
#socket=/dev/socket/rild
#sub=SUB1
#slot=0
#timeout=0
#technologies=all
#enable4G=true
#uiccWorkaround=true
#ecclistFile=/var/lib/ofono/ril.ecclist
#allowDataReq=auto
#dataCallFormat=auto
#dataCallRetryLimit=4
#dataCallRetryDelay=200
#remoteHangupReasons=20
#localHangupReasons=23
#enableVoicecall=true
#enableCellBroadcast=true
#startTimeout=20000
#legacyImeiQuery=false
#lteNetworkMode=9
#networkModeTimeout=20000
[ril_1]
transport=binder:name=slot2;interface=radio@1.4
name=slot2
Summary
Repository-Daten werden geladen...
Installierte Pakete werden gelesen...
S  | Name                               | Typ        | Version                | Arch    | Repository
   | harbour-nofono                     | Paket      | 0.1-3                  | aarch64 | openrepos-velox
i  | libgofono                          | Paket      | 2.1.6-1.9.1.jolla      | aarch64 | jolla
   | libgofono                          | Quellpaket | 2.1.6-1.9.1.jolla      | noarch  | jolla
   | libgofono-debuginfo                | Paket      | 2.1.6-1.9.1.jolla      | aarch64 | jolla
   | libgofono-debugsource              | Paket      | 2.1.6-1.9.1.jolla      | aarch64 | jolla
   | libgofono-devel                    | Paket      | 2.1.6-1.9.1.jolla      | aarch64 | jolla
i  | libgofonoext                       | Paket      | 1.0.14-1.7.1.jolla     | aarch64 | jolla
   | libgofonoext                       | Quellpaket | 1.0.14-1.7.1.jolla     | noarch  | jolla
   | libgofonoext-debuginfo             | Paket      | 1.0.14-1.7.1.jolla     | aarch64 | jolla
   | libgofonoext-debugsource           | Paket      | 1.0.14-1.7.1.jolla     | aarch64 | jolla
   | libgofonoext-devel                 | Paket      | 1.0.14-1.7.1.jolla     | aarch64 | jolla
i  | libofonobinderpluginext            | Paket      | 1.1.11-1.5.1.jolla     | aarch64 | adaptation-common
   | libofonobinderpluginext-devel      | Paket      | 1.1.11-1.5.1.jolla     | aarch64 | adaptation-common
i  | libqofono-qt5                      | Paket      | 0.115.1-1.8.1.jolla    | aarch64 | jolla
   | libqofono-qt5                      | Quellpaket | 0.115.1-1.8.1.jolla    | noarch  | jolla
   | libqofono-qt5-debuginfo            | Paket      | 0.115.1-1.8.1.jolla    | aarch64 | jolla
   | libqofono-qt5-debugsource          | Paket      | 0.115.1-1.8.1.jolla    | aarch64 | jolla
i  | libqofono-qt5-declarative          | Paket      | 0.115.1-1.8.1.jolla    | aarch64 | jolla
   | libqofono-qt5-devel                | Paket      | 0.115.1-1.8.1.jolla    | aarch64 | jolla
   | libqofono-qt5-examples             | Paket      | 0.115.1-1.8.1.jolla    | aarch64 | jolla
   | libqofono-qt5-tests                | Paket      | 0.115.1-1.8.1.jolla    | aarch64 | jolla
i  | libqofonoext                       | Paket      | 1.0.29-1.6.1.jolla     | aarch64 | jolla
   | libqofonoext                       | Quellpaket | 1.0.29-1.6.1.jolla     | noarch  | jolla
   | libqofonoext-debuginfo             | Paket      | 1.0.29-1.6.1.jolla     | aarch64 | jolla
   | libqofonoext-debugsource           | Paket      | 1.0.29-1.6.1.jolla     | aarch64 | jolla
i  | libqofonoext-declarative           | Paket      | 1.0.29-1.6.1.jolla     | aarch64 | jolla
   | libqofonoext-devel                 | Paket      | 1.0.29-1.6.1.jolla     | aarch64 | jolla
i+ | ofono                              | Paket      | 1.29+git6-1.13.1.jolla | aarch64 | jolla
   | ofono                              | Quellpaket | 1.29+git6-1.13.1.jolla | noarch  | jolla
   | ofono-binder-plugin                | Paket      | 1.1.11-1.5.1.jolla     | aarch64 | adaptation-common
   | ofono-configs-binder               | Paket      | 1.1.11-1.5.1.jolla     | aarch64 | adaptation-common
   | ofono-configs-mer                  | Paket      | 1.0.6-1.3.1.jolla      | aarch64 | adaptation-common
   | ofono-debuginfo                    | Paket      | 1.29+git6-1.13.1.jolla | aarch64 | jolla
   | ofono-debugsource                  | Paket      | 1.29+git6-1.13.1.jolla | aarch64 | jolla
   | ofono-devel                        | Paket      | 1.29+git6-1.13.1.jolla | aarch64 | jolla
   | ofono-doc                          | Paket      | 1.29+git6-1.13.1.jolla | aarch64 | jolla
i  | ofono-ril-binder-plugin            | Paket      | 1.2.7-1.5.1.jolla      | aarch64 | adaptation-common
i  | ofono-ril-plugin                   | Paket      | 1.0.6-1.3.1.jolla      | aarch64 | adaptation-common
   | ofono-tests                        | Paket      | 1.29+git6-1.13.1.jolla | aarch64 | jolla
   | openrepos-logger-ofono             | Paket      | 1.0.22-1.5.1.jolla     | aarch64 | sailfishos-chum-yggdrasil
   | openrepos-logger-ofono-debuginfo   | Paket      | 1.0.22-1.5.1.jolla     | aarch64 | sailfishos-chum-yggdrasil
   | openrepos-logger-ofono-debugsource | Paket      | 1.0.22-1.5.1.jolla     | aarch64 | sailfishos-chum-yggdrasil
   | sailfish-log-viewer-ofono          | Paket      | 1.0.22-1.2.1.jolla     | aarch64 | jolla
i  | sailfish-mdm-ofono-plugin          | Paket      | 1.0.10-1.2.1.jolla     | aarch64 | jolla
   | voicecall-qt5-plugin-ofono         | Paket      | 0.8.0-1.9.1.jolla      | aarch64 | jolla
# ssu lr
[root@VollaPhone defaultuser]# ssu lr
 - adaptation-common           ... https://releases.jolla.com/releases/4.5.0.19/jolla-hw/adaptation-common/aarch64/
 - adaptation-community        ... https://repo.sailfishos.org/obs/nemo:/testing:/hw:/volla:/yggdrasil:/4.5.0.19/sailfish_4.5.0.19_aarch64
 - adaptation-community-common ... https://repo.sailfishos.org/obs/nemo:/testing:/hw:/common/sailfishos_4.5.0.19_aarch64/
 - apps                        ... https://releases.jolla.com/jolla-apps/4.5.0.19/aarch64/
 - hotfixes                    ... https://releases.jolla.com/releases/4.5.0.19/hotfixes/aarch64/
 - jolla                       ... https://releases.jolla.com/releases/4.5.0.19/jolla/aarch64/
 - sailfishos-chum-yggdrasil   ... https://repo.sailfishos.org/obs/sailfishos:/chum/4.5.0.19_aarch64/
Enabled repositories (user):
 - harbour-storeman-obs      ... https://repo.sailfishos.org/obs/home:/olf:/harbour-storeman/4.5.0.19_aarch64/
 - openrepos-AndyWuest       ... https://sailfish.openrepos.net/AndyWuest/personal/main
 - openrepos-Kabouik         ... https://sailfish.openrepos.net/Kabouik/personal/main
 - openrepos-Mister_Magister ... https://sailfish.openrepos.net/Mister_Magister/personal/main
 - openrepos-Rikudou_Sennin  ... https://sailfish.openrepos.net/Rikudou_Sennin/personal/main
 - openrepos-ade             ... https://sailfish.openrepos.net/ade/personal/main
 - openrepos-aviarus         ... https://sailfish.openrepos.net/aviarus/personal/main
 - openrepos-black_sheep_dev ... https://sailfish.openrepos.net/black_sheep_dev/personal/main
 - openrepos-direc85         ... https://sailfish.openrepos.net/direc85/personal/main
 - openrepos-dpurgin         ... https://sailfish.openrepos.net/dpurgin/personal/main
 - openrepos-enigma9o7       ... https://sailfish.openrepos.net/enigma9o7/personal/main
 - openrepos-fooxl           ... https://sailfish.openrepos.net/fooxl/personal/main
 - openrepos-jobe            ... https://sailfish.openrepos.net/jobe/personal/main
 - openrepos-nephros         ... https://sailfish.openrepos.net/nephros/personal/main
 - openrepos-olf             ... https://sailfish.openrepos.net/olf/personal/main
 - openrepos-pamoedo         ... https://sailfish.openrepos.net/pamoedo/personal/main
 - openrepos-rubdos          ... https://sailfish.openrepos.net/rubdos/personal/main
 - openrepos-velox           ... https://sailfish.openrepos.net/velox/personal/main
 - store                     ... https://store-repository.jolla.com/yggdrasil/aarch64/?version=4.5.0.19
Ibhave now no time but check the sfsos on volla or gs290 threads
i had the same issue and tgere is communication between piggz and me that describes how tobsolve it.
should be here
To elaborate: try
zypper install patterns-sailfish-device-adaptation-yggdrasil patterns-sailfish-device-configuration-yggdrasil
Those packages require the correct ofono binder plugin.
thanks I read your thread a few times https://forum.sailfishos.org/t/no-outgoing-calls-possible-solved/13632 and also https://forum.sailfishos.org/t/gs290-installation/11690
but didn’t understand the solution for me.
I reinstalled patterns-sailfish-device-configuration-yggdrasil and patterns-sailfish-device-adaptation-yggdrasil but it doesn’t fixed this fo me.
I had updated my Vollaphone very early to 4.4.0.72 to 4.5.0.16, 4.5.0.18 and 4.5.0.19 before the community support fo GS290 was ready…
ok I locked this package but after zypper up there is nothing to do only the warning shows up:
The following item is locked and will not be changed by any action:
 Installed:
Did you lock it before trying to re-install
Uninstall the wrong one, install the correct one and lock that
I uninstalled both and reinstalled it. Shutdown and boot again. Otherwise I don’t know what I have done that I finally can call out again. Thank you for quick response
