As per announcement I’ve been porting miami (edge 30 neo but i’ll call it miami for short its funnier) for some time now and today I managed (with help) to get it to daily drive’able state, so I’m releasing it!
Notification LED in very very very very very stupid place that won’t ever not annoy me!
Compact size!
Stereo!
Wireless charging!
And now for what’s not working:
Fingerprint - it’s under display and I can’t be arsed making it work
You cannot reject a call and also screen turns off during call and you cannot turn it back on (can if you spam the power button but it’s glitchy)
USB OTG - we already know how to fix it it’s just matter of fixing it so it will be fixed on later date
Wide angle camera - it should work but is not listed
And that’s it! All of those are just commodity issues i’d call it in terms of g2 to be fully working. And battery life/suspend is insane, 6h on wifi and it lost 1-2% battery. NUTS
As usual with my port you get commodity features like my apps, all 3 stores, and updater, so you don’t have to manually update.
And I believe if you see this you won’t be able to reject call or this phone:
As of today I’ve switched from op6t to miami and I am NOT looking back at the glass-back frying pan thatgotblacklistedbymycarrierfornoapparentreasonandwithnoexplanationbecausethecarrierispieceofshi.
P.S.: Oneplus 6(t) users do not worry, verdanditeam promises long support and that shall be delivered, even though i’m not gonna be using op6(t) i never used it to start with, I’m still going to be supporting them for foreseeable future. I still wanna do mainline port
Please click on Battery-Charge-Graph and show us the Battery overview page.
It nearly has almost 100% CPU sleep, while my C2 has around 80%. A reason could be that LPM-Screen is activated (lift to show clock and double tap to unlock), so I ended up at 0.25%/h, which is quite okay for this feature. At Flight-Mode of course!
Yeah it’s insanely good, with wifi it has power draw like my other devices without wifi, it’s seriously nuts
Also also if this smaller compact size is not your thing @Morc declared that he’ll port G85, they’re on the same SoC so should be incredibly simple to port and yes i’m gaslighting him into doing it right now xd
It’s narrower but taller than my beloved perfect x2 so imho compared to frying pan that is op6 it is compact, you can grab it from left and right side that’s plenty enough
Well nobody installed the port yet beside me, and I don’t have C2 so I don’t think that’ll be possible, but it has 120Hz which C2 doesn’t have which will make it smooth. Youtube quickly switches pages its nice
Completely different soc and that has nothing to do with it.
Even if we go with this flawed logic that you can just drag and drop sfos on any device with the same soc as an officially supported device, that means that Miami is the same as Xperia 10 IV/V.
So even by that, this port looks like it’s insanely better than the one on Xperias.
Again, completely wrong, but even if you think that makes sense to you, it’s still the wrong conclusion.
Its rather obvious that Mr Magister has a special humor that is not supposed to be forced through your offense detector. Also, there is this saying, what throwaway69 says about Mr_Magister, says more about throwaway69 than Mr_Magister. wInK wInk.
