I recorded you a vid cause i thought people might wanna see how it works
It looks fast and smooth. Good candidate for the next daily driver.
120Hz is seriously smooth. On 60Hz phones have hiccups (skip frames) and on 120Hz even if you skip frame it’s half the length so its not noticeable at all
Guys I think i’ll be able to add support for the motorola gestures like chop chop or the camera one if everything goes well
cross your fingies
How does 120hz refresh rate affect battery life? Does it drain the battery much faster compared to 60hz?
Such things are really hard to tell to be honest, it surely does draw more power but i wouldn’t concern myself with it
I could imagine that if buffer-content doesn’t change, there’s no update to the display (0Hz). Anything else would be a dumb waste of energy.
Sadly you have too high expectations for sfos and the latter is the case
You can test it yourself, settings → developer tools → frame rate display
This should be implemented on hardware- or driver level.
Well but it isn’t ![]()
I’m sure android does that, while sfos does not
True variable refresh (10Hz to Max) is LTPO display. Here’s 134 of them.
It seems to be a feature exclusive to the flagship models, so unfortunately it’s not available for us.
There’s also Adaptive Refresh - where it’s 60Hz when doing mundane stuff, and boosting up to 90/120/144Hz when scrolling or playing games. That’s most budget or better phones for the last few years.
The question here is how much impact the display update frequency has on battery life, since the main battery consumer is display brightness and not updates.
By the way, does the Edge 30 Neo support an LPM-screen, like Nokia’s Glance Screen?
Sfos sadly does not implement it either
Sfos doesn’t, it’s software thing. Maybe you mean AOD or something but that still is mostly software thing
Which version of neo 30 is recommended? There is a “lite, regular and pro”. Or doesn’t that matter? What does the boot logo look like.
Will waydroid work like on op6?
What do you mean? There’s just one Edge 30 neo. There’s no lite regular pro
wayrdoid will not work yet, it needs to be updated first
Are you planning on bringing the G34 to the list of your supported devices as well at some point?
Nah it was just for my experiments. @Morc might bring some other motorola on same soc but, i’m already supporting 7 ports and 10 apps, that’s quite enough for me and a tad too much.
Current plans for ports are:
- wait for perfect phone to port, small with 3.5mm and sdcard
- port mainline to moto x2
- make port for op6 on mainline
Sounds like a plan!
G34 is fully packed and only missing the OLED display, besides being too big
Which was the reason I didn’t order J2. But I asked for G34 cos I could get it for free and play with SFOS on it…
Anyways thanks for your hard work ![]()
Guys I’ve noticed another issue, with volte registered I’m unable to send sms ![]()
Need to fix it now ![]()
But if you never register for volte it works just fine
So current issues with volte:
- Cannot reject a call - toggle flight mode quickly
- Cannot send sms - you can receive and I rarely send sms so it’s not much of a problem to me but workaround is to disable volte registration and restart ofono
Volte issues are notoriously hard to fix/debug, hanging up the calls was only fixed because we simply changed version of the protocol but no such easy fix will work anymore
Now we have to ACTUALLY fix stuff which is hard ![]()
(tho implementing dial tone was entirely implemented by me so that counts as actual fix
but that was easy too)
Since switching to miami I’ve had couple calls including spam call and let me tell you they work flawelssly (minus the aforementioned issues)
About fingerprint: with some coding (a lot of it) it possibly could be done, android side is working daemon is communicating it’s just matter of updating sfos side to latest api and modifying lipstick to draw circle in correct spot on lock screen, it’s all doable just time consuming and looking at how idc about fp maybe i’ll do it when I’m bored
USB OTG: Still no clue about that one boss
Motorola gestures: TBD
SMS/call rejectoin: no clue how to fix the issues, next question
Camera2 api: i’ve applied WIP changes to use camera2 api and all 3 cameras are working nicely, but no video recording hence I won’t be pushing it to the repo
Dynamic refresh rate: I’ve locked it to 120Hz which is not ideal but sfos can barely handle anything beyond 60Hz yet alone changing it dynamically lol
Also I’ve realised you don’t have to restart ofono, if you simply unregister from volte (give it like 30 seconds) sms should work so it’s quite acceptable workaround in my opinon. I will still pursue fixing it of course but as they say, this is way beyond my pay grade i’m just lowly web developer
So that’s the status. From things i already know how to implement would be motorola gestures (i have quite good idea), USB OTG I think i’ll just add manual toggle just so that there’s some workaround, FP, i kinda do know what needs to be done but i don’t wanna do it.
