My trusty Xperia 10 Plus won’t switch on anymore. I have to admit I dropped it (while developing Dee ), but it didn’t seem damaged. However, this morning I found it switched off and it won’t switch on. The battery was charged and I even left it plugged in for 4 hours, but nothing. Then I tried taking it apart to check the cable connections and everything seems fine. If I perform the hardware reboot with the 3 buttons, the LED flashes white very quickly and that’s it. If anyone thinks they can fix it, I can send it to them, but I’m not sure if it’s worth it.
I can’t afford to buy a phone, so here I’m again, asking you to help me by donating your old one. And I really hope I haven’t betrayed @ziellos’s trust in any way.
I’ve got a spare XA2 I bought from this very forum a while back. The fingerprint reader is pretty unreliable, but other than that it seems to work fine. I haven’t used it as a phone though; it was meant to be a donor or a project platform.
So, it’s pretty old, but I can part with it if you don’t get any better offers
