Lineage based port for Xperia 10 IV (murray)
Wow, this sounds very promising (once again)! Did you hear something new from Jolla regarding AAS on community ports?
Thank you all for your work!
Unfortunately not as yet, latest from Jolla is
Honestly at this stage I’m more interested in them getting 5.2 out, its a fabulous improvement over 5.1 and I’m very keen for users of this port to get their hands on it. But hopefully not too long after that they’ll have some time to try out AppSupport 15 on these ports.
Yes, understandable. If the C2 AAS ist upgraded to Android 15, it should be possible for other ports as well.
AppSupport major updates already happened in the past also on Xperia ports.
Thanks for all your efforts you have spent on Zambezi.
I get an error when following the instructions at VerdandiTeam Website - Device zambezi
It says “ 2. … then reflash `lineage-22.2-20251010-nightly-pdx235-signed.zip”
However I get “ERROR: recovery: Logical partitions are mapped. Please reboot recovery before installing an OTA update.”
I have followed the installation instructions twice, starting from Emma, but twice it failed.
Any hint on what I might be overlooking?
Hi there @a.zak,
I’m not sure what’s gone wrong - to be sure, can you please try following the original instruction guide (which is more detailed)?
Note the Zambezi guide just references the Murray guide with some values / links changed.
To confirm, Lineage did boot up in Slot a?
Thanks for the more detailed instructions, but I think I have performed the steps already as given in the detailed instructions.
Lineage has booted up, then I went to recovery, there it said “slot b active”. Then I sideloaded successfully the “copy partitions zip”. But the second sideloading of lineage fails with “ERROR: recovery: Logical partitions are mapped.”
I will keep trying.
Hmm, seems odd.
Apologies I’m away currently without access to a computer, so I’m of limited help.
You’re sure you don’t have any partitions (eg. /system) mounted from the recovery environment?
I have tried the mount/unmount option from the recovery menu, but it did not make a change.
Futhermore I have tried the following to change the slot:
C:\Users\vboxuser\Desktop\SFOS_X10V_Release_0.0.1>fastboot.exe getvar current-slot
current-slot: b
Finished. Total time: 0.003s
C:\Users\vboxuser\Desktop\SFOS_X10V_Release_0.0.1>fastboot.exe --set-active=a
Setting current slot to ‘a’
OKAY [  0.024s]
Finished. Total time: 0.028s
current-slot: a
Finished. Total time: 0.002s
Flashing Sailfish was possible, but then I was stuck at the Sony boot logo.
Do I get you right, that you do the second flashing of the partitions zip and lineage zip just to change the slot (and ofr no other reason)?
Correct, flashing the second time is done just to have Lineage in slot a. Usually it is not a problem at all.
Perhaps reflash stock Android 14/15, then run --set-active=b, then flash Lineage?
Solved. Setting fastboot --set-active=b after flashing Android 15 and before flashing Lineage helped.
The sequence that worked on my Sony Xperia 10 V (Zambezi) XQ-DC54:
  1. Use EMMA to flash to the original Android 13.
  2. Use newflasher to flash Android 15 (68.2.A.3.123).
  3. Use fastboot --set-active=b then fastboot reboot-bootloader.
  4. Follow the usual instructions to flash lineage-22.2-20251010-nightly-pdx235-signed.zip
  5. Use fastboot flash dtbo dtbo.img && fastboot flash boot hybris-boot.img && fastboot flash userdata sailfish.img001 && fastboot reboot
I have used virtualbox on Ubuntu 24.04 with a Windows 11 LTSC Eval for the whole procedure, because EMMA does not run on Linux.
To get the USB device captured by virtualbox, VBoxManage list usbhost helped to identify the VendorId(s) and ProductId(s), that were needed to create filters in virtualbox for automatic capturing.
Thanks for your support, @Sharks.
i could install the port on a 10iv now and could install waydroid. i made a small script so anyone can use waydroid on this port, available here: GitHub - smatkovi/sfos-waydroid-hybris: Waydroid on Sailfish OS hybris ports (Xperia 10 IV): chum install via zypper, binder/iptables/EGL fixes, Adreno GPU rendering · GitHub
@a.zak happy to help, glad you worked it out. Still not sure why you had the problem but at least we found a workaround.
@smatkovi, interesting stuff! I shall look into it when I get back from holidays.
And it works, too! Well done! I have just tried it.
So that answers that - if anyone is holding off from installing this port, we now have Android support thanks to @smatkovi.
you’re welcome. thanks for the good port and the right kernel options
Get excited - 5.2 is finally here! :partying_face:
If you have zypper ref; zypper duped recently, you’ll have the Verdanditeam GUI updater available under ‘Settings → Sailfish OS updates’ and should be able to use that to update your system from 5.1.0.11 to 5.2.0.22. Otherwise, please follow the below instructions to update from the command line:
devel-su ssu re 5.2.0.22
devel-su zypper clean -a
devel-su zypper ref -f
version --dup
reboot
I will build a new set of flashable images for 5.2 later today (including all the improvements to the port since day 1) and make them available on Github & the Verdanditeam website.
5.2 is a fantastic improvement over 5.1. IMO the best advantages are the better browser and full camera support, but new fixes are still coming all the time. Stay tuned, and please let me know if you have any dramas.
And how about to leave a star on repository. By the way, how is the speed of rendering. Is it usable? Can you install apps there and are they usable? Anything you mentioned?
By the way i use official Sailfish port on mine Xperia 10 IV. After upgrade - stability got better, but not same as Your community port. Calls in telegram sends sound to loud speaker, battery indicator is wierd, but I was managed to run all 4 cameras (only for photos now), video recording still doesnt work due to lack of hardware encoding, maybe because of kernel missing part, maybe because of missing libs (I was investigating weakly). If all 4 cameras would work and record video too, and Waydroid would give amazing app support - Then i might think to switch back to Lineage based port. Now with AAS + MicroG I’am able to use: Google Maps, Google translate, Local public transport planning apps, Youtube, Some AI features, Native Telegram client, Native WhatsApp, Native Github client. Everything encounted just works after installation and configuring MicroG in the MicroG settings window.
Absolutely they are.
The only bug I’ve run into is you need to shutdown the Android machine from its top menu / notification shade button before exiting Waydroid, otherwise a whole heap of android services get caught in a crash / restart loop and chew your battery right down. I’m not sure if that’s a bug unique to @smatkovi’s work or common to Waydroid in general as I’ve not used it in the past.
But yes, apps are perfectly usable in Waydroid. The camera is not passed through, and I haven’t tested speaker / microphone for eg. calls etc., but your bank app or Google Maps or whatever will work fine.
On my port, all four cameras are working fully, photos and videos.
Dear Xperia 10 IV fans,
I’ve updated to the official 5.2.0.22 version. When making regular phone calls using the native dialer, the call only goes through the speakerphone. So, to put it another way, it’s not advisable to have a private conversation in public. Is this a Sony issue, or did a flash error just slip in on my end?
I’d really appreciate a response.
By the way, thanks again for all your hard work—it’s really made me love the 10 IV… :folded_hands: :heart_eyes:
In official port i have this issue all the time. In community port just sometimes. I was doing calls over RooTelegram client only
