Lineage based port for Xperia 10 IV (murray)
This is a known issue of the Jolla port, but I produced this port specifically to solve this problem and fix the cameras.
If you are sure you still have this problem on my port, then the only issue I can think of is you must somehow have the wrong combination of pulseaudio-modules-droid and droid-config-xqcc72.
For 5.2.0.22 you should have pulseaudio-modules-droid-14.2.114 and droid-config-xqcc72-0.0.15 or higher (0.0.19 is latest). You can confirm what you have installed with $ rpm -qa, and $ zypper ref; zypper dup should get you the latest.
I can’t comment on this as I’ve never used this app. But regular VoLTE phone calls work flawlessly in my port, with the exception of audio not routing to bluetooth headsets. Speakerphone, earpiece, and 3.5mm headphones all work fine.
Hey @smatkovi,
I have noticed when Waydroid is running there are a significant number of process crashes recorded in the Crash Reporter app (in Settings). They all have PID 0 with no information attached to them.
Waydroid seems as functional as I’d expect but if it sits in the background for ~1 hour I get the “you’ve collected 100MB of Crash data” notification.
I could of course just turn off crash reporting and ignore it, but I’m curious as to why its happening. Do you know or have any insight?
i will look into it tomorrow
Thank you for this, nice to see my 10iv alive again!
Are there known issues with wlan, though?
I can get online by connecting to a tether wlan, but connecting to the home wlan just won’t accept the password.
Don’t even know what exactly to say, as nothing seems “interesting”. Wlan6. Only ascii characters.
The phone has no SIM card.
Anyone seen anything like this before?
Big hooray to everyone for their hard work!
same here, in my case xperia 10V SF5.1 lineage port - i can not connect to home wlan where is enabled wlan roaming (roaming between multiple APs: 802.11r, 802.11k and 802.11v) on the openWRT enabled AP, so i had to create another Wlan without roaming on same AP.
all other ‘simple’ AP like phone hotspots or any AP configured to WPA2/AES works as expected
Jolla port works fine and switching between roaming APs smoothly
@koza did you ever get around to capturing journal logs showing this issue?
I’m trying to figure out what the deciding factor is that stops these networks from connecting. Maybe WPA3?
I can’t get to debug the 10iv more now, but I can confirm WPA2-Personal working in my wlan on a laptop.
Is WPA2 too recent or something otherwise unsupported on the port?
PS.
My Jolla2026 also says “WPA/WPA 2 PSK” fwiw, same as the 10iv connected to the tether-wlan.
Waydroid’s com.android.nfc crash-loops every ~5 s (no usable NFC HAL; the
host vendor advertises NFC). Each crash gets piped to rich-core-dumper →
“PID 0” reports.
Fix: hide the NFC app via an overlay whiteout, then restart Waydroid:
devel-su mkdir -p /var/lib/waydroid/overlay/system/app
devel-su mknod /var/lib/waydroid/overlay/system/app/NfcNci c 0 0
(pm disable doesn’t help, Android restarts it anyway.)
No i did not checked logs on phone, had no taste to. Just checked openwrt logs to see if device is just connecting or not.
i dont use wpa3 some of my devices does not connect so i still use wpa2aes
now lot of another work , i am happy with jp2026, my gf on xperia10V does not need to use home wlan as she have unlimited mobile data and in case backuping to home nextclous she just go upstairs and connect to working wifi…
will check how things will go after update to 5.2 on secondary xp10V…
My Xperia IV is now alive. Thank you for your amazing work. All works, calls, browser, internet, all. By the moment I cannot make working Waydroid. Is it possible to pay for AAS oficially? Thanks for all.
No you can’t pay for AAS yet. Paying for AAS will probably come one day. But quite some patience will likely be needed, thats not of the priority list.
You’re welcome @Cigival, glad its working well for you.
Waydroid is working for me using @smatkovi’s scripts (scroll up a bit in this thread). Did you try with that, or did you just try installing “normally”?
Says who? Last I heard, Jolla would complete AAS 15 for C2, then work on bringing it to this port. AFAIK the C2 implementation will drop in the next month or so with SailfishOS 5.3.
Its great to heard that. I have tried installing AAS manually. I will try how you said. Thanks
Hi, when I write the script, the response is authentication failure. What am I doing wrong? Thanks a lot.
I see. Well yes sure i don’t speak from any official voice, but i’m used that ‘‘we’ll look into it after doing x and y’’ is usually translating in like ‘‘looking into it in about a year from now’’.
I could be wrong of course :blush:.
Patience is a sailor’s quality :wink:
Non working out of the box android apps - is pain for me too. That’s the reason that I’am still using the official SFOS port.
Is it authentication failure after asking for the password? You need to set the password in Developer Tools in the Settings app.
Ok, I did it, well, IA did it. The next step is improve the performance. At rhe moment is too slow…
As I have a C2 too, i figured out that the files for AAS-15 are already in the repos, but they wont start on 10IV… I didnt investigate further at this point, but I fear that AAS-support is not around the corner…
So, Waydroid crashes when I reboot the phone, but I have decided not to use it. I have discovered an amazing client for whatsapp, so I dont need Waydroid anymore. The rest of Google apps are links to web and all works perfectly! Now I can say Sailfish is my daily driver. Thanks to this fantastic community.
