[JP2026] Unanswered incoming call stays stuck in voicecall-manager, outgoing calls impossible until service restart
REPRODUCIBILITY: happened 2 times in 8 days (plus likely earlier occurrences)
OS VERSION: 5.2.0.22 (Finlayson)
HARDWARE: Jolla Phone (2026), jp2601
UI LANGUAGE: Czech
REGRESSION: unknown
Occasionally, after an unanswered incoming call, the call is never cleaned up in voicecall-manager. The Phone app keeps showing the call, and no outgoing call can be placed afterwards (incoming calls still work). Previously only a reboot helped.
I captured D-Bus state during two occurrences (6 Nov and 13 Nov):
  • org.ofono /ril_0 VoiceCallManager.GetCalls returns an empty array — the modem side is clean.
  • org.nemomobile.voicecall still lists one voice call with status 7 (“disconnected”), duration 0, isIncoming=true. The same handler is still set as activeVoiceCall.
  • ofono.service and voicecall-manager.service had been running continuously for days — nothing crashed or restarted.
In both cases the stuck call was an unanswered incoming call with duration 0. Curiously, both calls started at second 0 of a minute (14:49:00.058, 13:54:00.763), so an automated calling system may be involved.
WORKAROUND:
systemctl --user restart voicecall-manager (as defaultuser) immediately clears the stale call; outgoing calls work again. Verified on both occurrences.
Not reliably reproducible. Receive an incoming call and let it go unanswered; rarely the disconnected call is never removed from voicecall-manager.
The disconnected call object is removed and the phone can dial out.
status=7 “disconnected” call stays in /calls/ and as activeVoiceCall; dialing out is impossible until voicecall-manager is restarted.
voicecall-qt5-0.9.0-1.17.1, voicecall-ui-jolla-1.17.1-1.22.1, ofono-1.29+git13.1-1.19.1, modem FW MOLY.NR17.R2.MP2.RC.RC2.SP.V18.4. Full D-Bus dumps from both occurrences available on request.
Possibly related to older reports:
