Sometimes (usually after I receive a call) the phone app loses the ability to make or receive a call.
When you go into your call list or contact list and tap on an entry to make a call, the phone GUI just sits there.
If you reboot the handset, then the problem goes away for a few days at least.
Rebooting any of the services from Settings seems not to have the same effect.
This is on an Xperia 10 III with 4.5.0.24 but the issue was present in the version before that too.
The problem didn’t seem to be there when I started using Sailfish on the phone several months ago but appeared a bit later on.
I experienced the problem a few times as well lately, same model, and only reboot fixes it. I’ve now taken to daily reboots of my phone to fix such problems. Not ideal, but I’m stuck with SFOS so gotta make the best out of it.
Ah well, at least it’s not just me and my network settings, by the look of it.
Yes, it seems to happen if you get the phone just as it’s going to voicemail for example.
Well, it does have a network service that you can restart but it’s not clear whether it has anything to do with calls, 4G or just VLAN.
In Settings, I have 4G calling (beta) enabled under Mobile Network.
That does look as though it might complicate things.
I’ve disabled that to see if that cures it.
Thanks for the suggestion!
I want to note on here that, although it’s a little early to say for sure, turning off 4G calling and restarting the phone seems to have cleared the issue.
Hello.
I have a big problem with the phone application /Phone/. When I make a call and the other party ends the call. The application stays running and still counts the call time even after it ends. I can’t dial another number, only restarting the device helps. Furthermore, when I end one call and want to dial another call after a while, it’s not possible, I still have the previous call window there. I have to restart again. After this update, I have to restart the phone at least 4 times a day.
By turning off the 4g calling and forcing it back to GSM in the settings, that seemed to fix the problem to a fair extent.
Interesting that the network I was using was O2 as well.
One major problem I had was voicemail, where it would constantly tell you that you had new voicemail messages and so you had no way to know when someone had actually left you one.
My issues were a lot less severe than what you’re describing. I hope they can straighten that out for you.
