I have no idea, my 12 eur dac was ignored. There is a usb audio config file that is disabled, maybe it is only required in some cases?
Still would be nice to include info which file it was that helped you, so possible future sufferers get a fix when searching (or a link to the post that gave the answer)
Is yours maybe a “dumb” adapter without any DAC inside?
Is yours, on the other hand, maybe a “smart” adapter having its own DAC (and therefore requiring proper support from the OS side)?
Yeah, it’s much better than any Xperia, it even worked on the flight when started from takeoff (assumed the anti-missile built-in nerf would kick in, but it worked up to reaching flight speed/altitude, after half an hour break it would no longer get a lock though) and few k km from finland after landing the lock time again was seconds (and a lot more sats used in gpsinfo), huge improvement
Yeah most likely, it’s the cheapest adapter I could find and so far no issues
Mine definitely does have a DAC, budget Chi-Fi stuff. I thought a DAC was reqired but I honestly have only superficial knowledge how USB-C works.
Compliments, these pictures are A-W-E-S-O-M-E !!! :smiley: :+1: :+1: :+1:
This must be said - both IQ- and compositionwise …
Thanks, it was just a fast snap :blush:
let me point out that in android or iOS, to block a number, you open the calls list then long press a number and tap on block
in sailfish to block a number, you open the calls list then long press on a number and tap on block
it’s probably one of the few things that is self explanatory xD
… you were lucky indeed - but you nailed it perfectly :wink: :+1:
@grayhowls I can’t confirm photos having a red tint. Maybe it’s a phone-specific issue?
@grayhowls
Does it stay that way after reboot and is that the case for all colour settings (AWD, cloudy, etc)?
During my first boot everything looked blueish but that resolved itself after reboot.
Excluding the Xperia 1 & 5 IV (the Nagara port).
Is there anyone that has both devices to compare in this case?
Because I believe that LOS base would solve a lot of issues, but every time I jump on that topic for about a year now there is always a work in progress problem and something else that doesn’t work.
I can’t say that the overall state can’t be better, but as a reader only I don’t see any flawless experience yet.
Unfortunately yes. I think it’s the software rather than hardware, as videos also suffer from the same issue, plus a sorta smearing effect too :confused:
Completely minor things left. The port is amazingly stable and fully functional. Just to compare, the 10 III has much more severe problems after years of development than the 1 IV after merely a few months. I’ve been daily driving it since March, the best SFOS experience I’ve ever had.
Have you ordered the Jolla Phone? Would love to hear a comparison
The problem here was that the contact I wanted to block didn’t appear in the call history, because they hadn’t called me after I switched to my new Jolla phone. And I wanted to block them before they do :grinning_face_with_smiling_eyes: On iOS I’ve been able to select a contact even before they called me, then select “Block number”.
What we’re looking at is the image data processing pipeline. I get to do a lot of video color grading at work and one comes to understand that everything between the lens and the jpg plays a role. And unfortunately, not everything that can go wrong in the capture can be easily or even acceptably corrected in the jpg.
If Jolla has used some out-of-the-box settings to process the data coming from these Sony sensors, then there may be a lot that we could do to help Jolla dial in the settings - they may just need the right feedback to adjust WB thresholds, black level, color and contrast correction, etc.
It’d be amazing if we could open up the look of the camera by letting users make camera profiles (a little json or xml file) that the camera software could read in. With this, some could strive for the best neutral looks, and others could create distinctive look - like sepia or chrome or bleach or whatever.
Is this something for a community meeting?
Without being really knowledgeable in this raw processing area: would this allow LUTs (Look up tables), therefore film looks like Ektachrome?
