As @attah says there is a native Yubikey-otp app. it doesn’t seem to be in the Jolla Store, but there are 2 other sources for community apps - OpenRepos (the Storeman app lets you browse and install these apps easily) and Chum (with a similar Chum GUI app), and you can find the app in both locations.
Exactly these aesthetics and simplicity are what makes SFOS so special, apart from all the privacy aspects of course. To be honest, I liked the more “organic” and “glowy” pulley menu indicators and background blurring (while inside an app) from the very first Jolla Phone much better than the nowadays optics, but the current SFOS look and UX still stands out beautifully and unique compared to iOS and Android.
So it’s actually only about carefully enhancing an already powerful foundation, without wanting to overthrow everything, let alone wanting to look and feel like one of the “Big 2”.
Plenty of proposals for adding additional native (system-wide) gestures, making the unique ambiences concept more versatile, etc. have already been posted in various threads on this forum. I hope that with the sales figures of the new Jolla Phone developing nicely, Jolla will get the confidence and resources to do such careful and thoughtful (and yes, somewhat needed) polishing work.
Thanks for the nice pictures.
All I saw seem a bit contrasted and underexposed to me. Perhaps tweakable…
RAW? Yeah, let’s make a RAW desire club!
That would be great to have access to RAW data!
Strangely, on the third one, there is cyan in the hi exposed sky and magenta in the clouds.
Also on the white walls, some cyan is present.
Perhaps the cyan/magenta curves aren’t aligned or not reacting the same to exposure levels?
:rofl:
The title of such a feature request thread is clearly settled hereby. :wink:
Thank you, I’ll take a look!
found another small thing, when you are connected to wi-fi then switch flight mode on, after that switch privacy mode on (with wi-fi disabling included). After switching off flight mode phone will connect to wi-fi and you can’t disconnect it because of privacy mode on (at least from top menu)
RAW support would have been something! I am one who spend time in desktop photo editors.
I couldn’t find a report on this but how is everyone’s access to 5G? No issues there?
One of the main reasons for me to use Sailfish is the OSM scout application, used on my every bicycle trip, hike, even on boat, car. Works well, as always. Would be nice to import collections from the previous Xperia - any idea how to export them from there? Could not easily find documentation.
Bluetooth used for Android applications seems not always work out-of-box that is expected, earlier it did not work at all. In my case Oura ring works well but Mahle bike connection poorly. Seems that there are quite many options, permissions, connections to wlan/mobile network which should all be combined accurately. Once I got Mahle paired for a while, not the next time. No problems with an Android phone. Perhaps there is a separate thread for bluetooth issues? Finding blutooth-related logs in Jolla phone might be helpful for understanding.
Look in (easiest with File Browser from Openrepos, show hidden files)
/home/defaultuser/.cache/cz.karry.osmscout
/home/defaultuser/.config/cz.karry.osmscout
/home/defaultuser/.local/share/cz.karry.osmscout
Edit: I used sshfs to copy 20 GB of music and 2,5 GB of Maps from my 10 II.
Yes, also, if you go into a collection, there is an ‘export’ option in the top menu.
Then you can re-import it from the new OSMscout.
Or, in terminal, make an archive with all OSMscout files and dirs.
Yes, the the flap part and the plastic casing (where the J2 sits with the silicone sleeve) are detachable; Those parts are connected with a strong magnet. So yes, that would be one way to make it completely usable!
Yes, thanks, essential is to go into a collection - at the upper level there is only Import. This worked, thank you, now that I do not have access to development mode and also cannot install new Sailfish components from Openrepos or Jolla shop in the old phone.
Citing myself from a different thread regarding the privacy switch:
To all of you who have already received their device: Is this something to be concerned about, or is it rather unlikely to happen in daily use?
At least in mine the switch is so stiff that I have to use fingernail to move it. Unless it looses up in use I won’t have problems with accidentally toggling it on or off.
It is on purpose and was commented by a Jolla employee [Sami] in March when community member @JoshStrobl (who lives in Finland), got access to an early copy of the phone:
@moripeluka: Thanks for linking this preview article. Seems I completely missed that one. :sweat_smile: I only read the preview of @cybette here.
Not sure if someone already mentioned this, but I had to post more pros; The GPS tracked my location very accurately and blazing fast, while sitting inside a community bus. I had Pure Maps open, and thought why not to test the GPS. Turned it on, zoomed a tiny amount and blam, in three or four seconds, the position was correct and moving steadily as the bus drove.
My 2-3$ usb-c to 3.5jack adapter worked out of the box, no idea what symlink you needed
