Jolla Phone (2026) does not start when charging
REPRODUCIBILITY: 100%
OS VERSION: 5.2.0.22
HARDWARE: Jolla Phone (2026)
UI LANGUAGE: Fi
REGRESSION:?
In cases where the battery has reached zero and you plug it in to charge, turning it on does not get to unlocking phase.
In my cases when this has been encountered, the battery has been drained. Not sure if required to encounter this.
  1. Drain battery so that phone turns OFF
  2. plug in and chtage so that some % of power is in battery
  3. Turn ON the phone
The option to unlock the phones decryption and SIM stages to appear
After sailfisOS logo the notification light stayd on, but the screen stays black.
No custom patches etc. SysMon installed, but not enabled or started at boot.
After detaching power cable and turning OFF and ON again, phone works normally. Have not seen change in cable / charger as have encountered on couple of different versions. Have not tried in situations where there is charge in battery and is plugged in while turning back ON. Have encountered this 2-4 occasions after getting the phone in september.
Could not reproduce with battery at ~70% on two different charging sets.
You may be affected by an issue where the JP2026 boots to a black screen, but is actually running. When this happens, you can see the PIN pad flash briefly if you tap the power button. Tapping the button a few times usually makes the screen stay on, and you can enter your decryption code.
Then, when the device has booted and you would normally get the login PIN pad, the screen turns black again. As before, tapping the power button lets you enter your PIN. The phone works normally once you have logged in.
This issue is reported here: [Jolla2026][5.2] On boot, screen is off despite system being active and ready and I have added a link to your report there as possibly related.
There are also reports about sudden “black screen crashes”, which may or may not be related. In the case of a crash it seems like only a long press to reboot works.
