[Jolla2026][5.2] On boot, screen is off despite system being active and ready
REPRODUCIBILITY: every time
OS VERSION: 5.2.0.18
HARDWARE: Jolla 2026
UI LANGUAGE: Italian
REGRESSION: was in 5.2.17 too
After the phone boots up and completes the normal procedures (show the logo, etc.) the screen turns off, like it’s doing something in background and you have to wait until you can enter the access key to unlock LUKS, but the system is actually ready waiting for input.
The only way to move forward is to press the lock button until the screen turns on.
This happens again at the home lock screen, but only after booting. Once the boot process is done and the system unlocked everything works as intended.
Reboot the phone.
  1. Reboot
  2. Wait until the booting process ends
  3. Wait until the screen lights up again to signal user input is needed
Whenever user actions are needed during the boot process the screen should light up, to notify the user.
The screen is off until hardware buttons are pressed.
Only apps from the Jolla Store.
It happens only during boot. When the lock button is pressed the screen flashes briefly with the graphics I’m supposed to see and then fades to black. If I press the button again the screen turns on normally.
I’m affected by this black screen issue on every boot now (Jolla Phone 2026 running 5.2.0.20). I need two taps on power button to enter encryption key (display just flashes briefly on first tap); a single tap suffices for the device PIN and SIM PIN.
It was reported in the release thread for 5.2.0.20 by @Moppa5.
It was also reported for 5.2.0.18 with additional information by @DominikH.
First time I saw this was on first boot of 5.2.0.16.
There are two possibly related threads for 5.0.0.77 on Xperia 10 III (XQ-BT52) and 3.4.0.24 on Xperia 10.
Getting back at this to report an occurrence I have yet to replicate but might or might not shed some light.
If the phone is rebooted or the home service restarted enough times, perhaps in quick succession, this issue disappears. But, if the phone is rebooted or the home service restarted again it can manifest again.
It’s very random and it may or may not be caused by a race condition somewhere.
I discovered this after rebooting the phone several times to deal with a Bluetooth issue (which turned out to be caused by external stuff and the reboot was just a coincidence) and one time the screen lit up as intended and kept like that for a while, then returned to the “bugged” version.
Another possibly related report for the Jolla Phone 2026: Jolla Phone (2026) does not start when charging
