Ok, dumb question maybe, but is there a user guide for Sailfish OS? Something I can read before deciding to dive in?
There is the old Jolla user guide: https://jolla.com/guide/en/index.html
That is Sailfish OS 1.x (weāre at 3.x now) so some things are a bit different these days. It has the basic ideas though.
I couldnāt find anything else for now.
You may take a look at this threadā¦
https://together.jolla.com/question/226905/dumb-howwhere-in-sailfish-to-send-mms-user-guides/
Thanks very much, Iāll go and check those out.
I know itās not exactly what you asked for, but you could also get an idea by watching some feature videos. Here are a couple (both a bit old now, but they still give an idea). Youāll find a bunch more videos on both the official Jolla and Leszekās YouTube accounts.
Jollaās Tips & Tricks: https://youtu.be/KzbdGfwgcbQ?t=260
Leszekās Tips for Beginners: https://youtu.be/vN7HIfEnZdc
Thank you! Folks here are really helpful, appreciate it.
Linking to a collection of useful links, including the āuser guideā ones.
āedit
and if we still had the power Iād close this answered ![]()
@david.giffin you can do this, I think. I have seen this in other Discourse forums.
No idea how to do that, sorry!
It is explained here: https://www.discourse.org/plugins/solved.html
But maybe the plugin is not enabled? If so, it should definitely be given that most will come from together.jolla.com/AskBot.
I asked here: Is the Solved plugin enabled (for marking replies as solutions and topics as solved)?
I donāt see the āSolvedā button, so an guessing itās not enabled.
It is enabled now!
https://forum.sailfishos.org/t/is-the-solved-plugin-enabled-for-marking-replies-as-solutions-and-topics-as-solved/951/17
The TJC app/sensors wiki seems to be very old and disorganized. Also, the result for many apps and sensors would depend on being a vanilla Aliendalvik or microG. Also, the microG setup method seems to have changed as of 3.4.x
You see where Iām getting at with these āalsosā? There are a lot of variables and not enough community (in users, resources and organization) for a fresh new user, like me, to have a smooth onboarding.
After 5 years trying to eke everything out of my N9, I had to use Android for a few years, but since my Android phone is reaching the end, I got a Sony XA2 and bought Sailfish.
The instructions for installing Sailfish on the XA2 were excellent. All the rest has been a struggle.
