REPRODUCIBILITY: 100%
OS VERSION: 4.4.0.68
HARDWARE: Xperia 10 Plus
UI LANGUAGE: German
REGRESSION: Maybe
I came across an interesting bug similar to what has been described before pertaining voice calls , only that this is with the latest Signal app. In short terms, even though a Bluetooth headset is connected to the device, Signal doesn’t route the call through it so you’re forced to use the built-in microphone and speakers.
Android runtime installed; Signal app installed, working Bluetooth headset paired and connected with the device.
- Connect phone to the Bluetooth headset, maybe do a normal call to make sure it works;
- Open Signal
- Make a video call using Signal.
You hear the person through your Bluetooth headphones.
No sound coming out of headphones - only through the built-in speaker.
None.
No idea how should I log this…
