OK, here it goes. Version 0.0.3
Changes:
- Choose between 7 font sizes (default Silica font sizes enums: Tiny, Extra Small, Small, Medium, Large, Extra Large, Huge)
- Choose between 7 line heights: 70-130% with 10% step
- Preview added to the settings page to instantly show the selected text and font/spacing combination
Oh, and as the Lock screen Label element’s text format is set to Text.RichText, you can be creative yourself and use simple HTML tags not only to set parts of the text to bold or italics or to change text color, but also to add even more lines (using the <br> tag to split one line into multiple lines) if there’s still space on your phone’s screen for that. (Just remember to leave enough space for the media playback controls or else it’ll overlap them).
This way everyone should now be able to adjust all text parameters to own preferences and phone screen size/resolution.
Files:
unified_diff.patch
--- a/usr/share/lipstick-jolla-home-qt5/lockscreen/LockItem.qml Mon Oct 3 18:31:06 2022
+++ b/usr/share/lipstick-jolla-home-qt5/lockscreen/LockItem.qml Sun Oct 9 00:02:38 2022
@@ -15,6 +15,7 @@
import com.jolla.lipstick 0.1
import com.jolla.settings.system 1.0
import org.nemomobile.lipstick 0.1
+import org.nemomobile.configuration 1.0
import "../backgrounds"
import "../main"
import "../statusarea"
@@ -181,6 +182,17 @@
enabled: !lockScreen.lowPowerMode && lockScreen.locked && !lockScreen.panning
onClicked: hintEdges()
+ ConfigurationGroup {
+ id: config
+ path: "/desktop/lipstick-jolla-home/devicelock/customText"
+ property string firstLine: []
+ property string secondLine: []
+ property string thirdLine: []
+ property string fourthLine: []
+ property int fontSize: Theme.fontSizeLarge
+ property real lineSpacing: 1.0
ContrastBackground {
@@ -190,8 +202,8 @@
? Theme.paddingLarge
: (lockItem.height - lockItem.contentTopMargin - height) / 2)
- width: Math.max(clock.width, weatherIndicator.width)
- height: clock.height + weatherIndicator.height
+ width: Math.max(clock.width, weatherIndicator.width, if_found.width)
+ height: clock.height + weatherIndicator.height + (Theme.paddingLarge * 2) + (if_found.height * 1.1)
opacity: Math.min(clock.transitionOpacity, clock.unlockOpacity)
@@ -287,6 +299,25 @@
temperatureFontPixelSize: clock.weekdayFont.pixelSize
active: visible
+ Label {
+ id: if_found
+ anchors {
+ horizontalCenter: clock.horizontalCenter
+ top: weatherIndicator.bottom
+ topMargin: Theme.paddingLarge * 2
+ font.pixelSize: config.fontSize
+ lineHeightMode: Text.ProportionalHeight
+ lineHeight: config.lineSpacing
+ color: lockScreen.textColor
+ textFormat: Text.RichText
+ horizontalAlignment: Text.AlignHCenter
+ text: (config.firstLine ? config.firstLine + "<br>" : "") + (config.secondLine ? config.secondLine + "<br>" : "") + (config.thirdLine ? config.thirdLine + "<br>" : "") + (config.fourthLine ? config.fourthLine : "")
main.qml
import QtQuick 2.0
import Sailfish.Silica 1.0
Page {
property string firstLine: ""
property string secondLine: ""
property string thirdLine: ""
property string fourthLine: ""
SilicaFlickable {
anchors.fill: parent
contentHeight: (content.height + preview.height) * 1.3
Column {
width: parent.width
spacing: Theme.paddingSmall
PageHeader {
title: "My text on Lock Screen"
description: "(To hide a row, just clear its text)"
TextArea {
label: "First row"
width: parent.width
placeholderText: "First row"
text: config.firstLine
onTextChanged: config.firstLine = text
rightItem: IconButton {
onClicked: {
firstLine.text = ""
width: icon.width
height: icon.height
icon.source: "image://theme/icon-m-input-clear"
opacity: firstLine.text.length > 0 ? 1.0 : 0.0
Behavior on opacity { FadeAnimation {} }
TextArea {
label: "Second row"
width: parent.width
placeholderText: "Second row"
text: config.secondLine
onTextChanged: config.secondLine = text
onClicked: {
secondLine.text = ""
width: icon.width
height: icon.height
opacity: secondLine.text.length > 0 ? 1.0 : 0.0
TextArea {
label: "Third row"
width: parent.width
placeholderText: "Third row"
text: config.thirdLine
onTextChanged: config.thirdLine = text
onClicked: {
thirdLine.text = ""
width: icon.width
height: icon.height
opacity: thirdLine.text.length > 0 ? 1.0 : 0.0
TextArea {
label: "Fourth row"
width: parent.width
placeholderText: "Fourth row"
text: config.fourthLine
onTextChanged: config.fourthLine = text
onClicked: {
fourthLine.text = ""
width: icon.width
height: icon.height
opacity: fourthLine.text.length > 0 ? 1.0 : 0.0
ComboBox {
label: "Font size: "
currentIndex: {
if (config.fontSize == Theme.fontSizeTiny) return 0
else if (config.fontSize == Theme.fontSizeExtraSmall) return 1
else if (config.fontSize == Theme.fontSizeSmall) return 2
else if (config.fontSize == Theme.fontSizeMedium) return 3
else if (config.fontSize == Theme.fontSizeLarge) return 4
else if (config.fontSize == Theme.fontSizeExtraLarge) return 5
else if (config.fontSize == Theme.fontSizeHuge) return 6
else return 4
menu: ContextMenu {
MenuItem {
text: "Tiny"
onClicked: config.fontSize = Theme.fontSizeTiny
MenuItem {
text: "Extra Small"
onClicked: config.fontSize = Theme.fontSizeExtraSmall
MenuItem {
text: "Small"
onClicked: config.fontSize = Theme.fontSizeSmall
MenuItem {
text: "Medium"
onClicked: config.fontSize = Theme.fontSizeMedium
MenuItem {
text: "Large"
onClicked: config.fontSize = Theme.fontSizeLarge
MenuItem {
text: "Extra Large"
onClicked: config.fontSize = Theme.fontSizeExtraLarge
MenuItem {
text: "Huge"
onClicked: config.fontSize = Theme.fontSizeHuge
ComboBox {
label: "Line spacing: "
currentIndex: {
if (config.lineSpacing == 0.7) return 0
else if (config.lineSpacing == 0.8) return 1
else if (config.lineSpacing == 0.9) return 2
else if (config.lineSpacing == 1.0) return 3
else if (config.lineSpacing == 1.1) return 4
else if (config.lineSpacing == 1.2) return 5
else if (config.lineSpacing == 1.3) return 6
else return 3
menu: ContextMenu {
MenuItem {
text: "70%"
onClicked: config.lineSpacing = 0.7
MenuItem {
text: "80%"
onClicked: config.lineSpacing = 0.8
MenuItem {
text: "90%"
onClicked: config.lineSpacing = 0.9
MenuItem {
text: "100%"
onClicked: config.lineSpacing = 1.0
MenuItem {
text: "110%"
onClicked: config.lineSpacing = 1.1
MenuItem {
text: "120%"
onClicked: config.lineSpacing = 1.2
MenuItem {
text: "130%"
onClicked: config.lineSpacing = 1.3
Column {
width: parent.width
spacing: Theme.paddingLarge
anchors.top: content.bottom
Separator {
anchors.horizontalCenter: parent.horizontalCenter
color: Theme.highlightColor
width: parent.width
Label {
text: "Preview"
Label {
patch.json
{"description": "Shows four lines of custom text on Lock screen, right below the Clock and Weather widgets", "name": "custom-text-on-lockscreen", "display_name": "Custom text on Lock Screen", "category": "silica", "author": "wetab73", "discussion": "", "donations": "", "sources": "", "version": "0.0.3", "compatible": ["4.4.0.72","4.4.0.68","4.4.0.58"]}
Enjoy
