Hello everyone, I’m new to Jolla and I’m trying to install Sailfish OS on the Sony Xperia 10 III using my linux debian notebook. I successfully followed all the instructions from the link https://jolla.com/how-to-install-sailfish-x-on-xperia-10-iii-on-linux/ up to step 7.12 in the guide. From here on, I started encountering issues. After my first attempt to run the command sudo ./flash.sh unsuccessfully (because the flash.sh file was in a folder read by the system as an external drive), I moved everything to the desktop in a new folder and tried to restart from where I left off.
So, I try the command to flash again:
root@paolo-deb:/home/paolo/Scrivania/Sailfish_OS-Jolla-4.6.0.15-xqbt52-1.0.1.14# ./flash.sh
And the output unfortunately is:
Flash utility v1.2
Detected Linux
Searching device to flash…
No device that can be flashed found. Please connect your device in fastboot mode before running this script.
Then, when I run the following command:
root@paolo-deb:/home/paolo/Scrivania/Sailfish_OS-Jolla-4.6.0.15-xqbt52-1.0.1.14# sudo fastboot oem unlock 0x354287794543566
I get this output:
FAILED (remote: ‘Device already unlocked’)
fastboot: error: Command failed
Since the device is already unlocked, I try to run the command again:
root@paolo-deb:/home/paolo/Scrivania/Sailfish_OS-Jolla-4.6.0.15-xqbt52-1.0.1.14# sudo ./flash.sh
And the output I get is:
Flash utility v1.2
Detected Linux
Found XQ-BT52, serial:HQ619H1ACE, baseband:, bootloader:
Found matching device with serial HQ619H1ACE
Fastboot command: fastboot -s HQ619H1ACE
>> fastboot -s HQ619H1ACE getvar secure
<< getvar:secure FAILED (remote: ‘GetVar Variable Not found’)
And now I’m stuck and don’t know what to do.
Can anyone help me get past this issue?
