Chump?? (20 charakters)
Maybe he meant “Chum”
Yes, sure. But I had a look into dictionary what a chump is and had to laugh long and loud!
Maybe his chum app identifies as chump
Download the RPM from https://repo.sailfishos.org/obs/sailfishos:/chum/4.6_aarch64/aarch64/sailfishos-chum-gui-0.6.9-1.10.1.jolla.aarch64.rpm, install, open Settings inside Chum app and set Sailfish version to 4.6.0.15.
That should sort you out
Just make sure you don’t try looking for “Chump”, you may never find the app in your list otherwise
I’m experiencing Bluetooth connection problems with C2. Even if the phone is connected to car, I cannot hear anything from other side. At the same time my voice is going through. Sometimes it work fine and then turning the call it just disconnects.
Hello I just inserted my sim card no mms. I think it comes from my operator. Apn setting. But I find it incredible my C2 does not ring. I set the jolla ringtone by default. But nothing to do it does not ring. I did Restart, but nothing to do No ringtone. In addition I noticed that I have no sound on the Android music apps. It works well on SailfishOs
Did you set the Preferred network to less then 4G?
I left 4G as the default. Is there a setting to make?
I tried 2G 3G. The phone remains silent. I receive calls. But it does not ring. It is silent mode
Did you reboot to restore sound?
Right after boot with AppSupport turned off from start the sound should work in the settings.
Hum it sounds after stopping AndroidApp and stopping the automatic start and putting in 2G. I restarted. So where does the problem come from? Is it AndroidApp? Can I stay in 4G without starting AndroidApp? In case thank you very much for the info
It works thanks a lot
No idea. For me sound mostly works after disabling vibrating on touch and call. Some bugs about that are fixed but we’ll have to wait and see in the next version.
I guess you’ll have to test for yourself.
There is no VoLTE support for now. So 4G only works for SMS and it should for MMS (for me it doesn’t). No voice calls in 4G yet (next version with support for that is on RC5 level - info from community meeting). For now phone goes to 3G or lower. It depends on your mobile network.
AppSupport doesn’t properly route yet with mobile network. It only works with Wi-Fi for now.
I think I have the same problem on an Xperia 10 III. I experienced exactly this a lot of times while driving a car. Sometimes, when I make a call or someone calls me, I can’t hear anything, although the other side can hear me well. Other times, it works perfectly fine. Maybe we should open a bug report for this?
Disabling vibration solved for me aslo Wifi connection problem, where moving between diferent networks I had to turn-off-on wifi to re-connect.
I remember seeing this on almost ALL of my Android phones. Very annoying, wired transmission worse than WLAN. Sad to hear C2 has the same problem.
How I fixed hanging camera app:
I changed setting to autofocus.
Can you be a bit more specific?
When the camera app was hanging?
Can you provide us a screenshot?
Sorry… I hadn’t the intend to debug…
Just played around during a concert.
Before I set “autofocus”: when I shot a foto, tha app hanged. There were reoccurring dialogs where you could wait or kill the app.
