I restarted lipstik but it doesn’t seem to go under that soy, I put the cover back on and it went back to octamali temperature. What do you do in this case?
When I run Stumblefish with location+cellular+wifi+bluetooth, I notice it gets hot and drains quite a lot the battery. Disconnecting those services makes it cool down. I’ll try and quantify the battery drain rate.
Guys, at this point, I really think the problem lies with either the I2C sub-board or the chip attached inside the cover. How do you think I can figure out which one is the culprit? It’s worth noting that it heats up the same way with both the “Orange” and “Inari Blue” covers, so I guess I’ve answered my own question
Before we all get on the wrong trail: can you reproduce this behavior with 100% confidence? As in, putting the cover back makes the phone hot again? ![]()
So, it seems he has the “Friendly Pocket Warmer” TOH.
Let’s not jump to the wrong conclusions. It’s very logical that temperature will rise if heat source is closed by plastic.
You can easily verify that the heat source is not the subboard by simply touching it briefly.
It seems that the heat source is SOC. More precisely lipstick process. Worth a bug report and if not improved by SIM even Zendesk ticket.
Before blaming the TOH I would take some insulator tape, tape a small piece to itself, so that no glue is exposed and put it over the pogo pins so that they do not actually contact the TOH. Then check if the heating up behaves differently fom just regularily attaching the TOH.
Ah yes, the pocket warmer TOH. May have been a mistake in dispatch, accidentally sending the “Finland, polar circle” spec parcel to Sicily.
Immediate apology for unhelpful jokes.
Guys, without the case, the smartphone is cold—not just lukewarm, but cold… but as soon as I put the case on, it literally cooks. I hope I’m making myself clear: it’s not just a bit warm, it’s absolutely scorching.
Then it’s absolutely worth trying @thejiral approach to confirm the subboard issue. Assuming the heating is the same with both TOH.
Removing the PCB from a TOH could temporarily fix the problem until you replace the entire unit with by Jolla or obtain the i3C Dockport part. An even better way would be to place a piece of tape over the contacts on one TOH.
Now I remember a very similar issue. A greek user had similar issue. But he send back the phone very soon IIRC.
Nice work isolating the problem!
Unfortunately, that means you will probably have to return the phone to Jolla. Did you get a return shipping label with the phone?
Yes, there is a return label inside the package.
If both TOH heat the phone then it’s very likely that either the phone subboard has an issue or IMO more likely there is a rare occurring bug.
Decision is yours. I would report a bug and wait.
And congratulations on debugging despite bitter taste!
Do you think it could be a bug, or simply a faulty I2C board?
Yes. As I wrote above.
I’d really like to keep the smartphone—especially after all the hassle I went through just to get it delivered via UPS, and now with this issue involving the I2C sub-board… I’m just really unlucky
. I’m worried that if the 30-day window passes, I’ll still be stuck with the problem and unable to fix it.
