Hi everyone, I’ve had the new Jolla phone 2026 for three days now, and it heats up worse than a microwave; the battery life is terrible and it drains on its own. I haven’t even inserted a SIM card—I’m just using Wi-Fi and haven’t installed any Android apps. I’m no Linux expert, but I want to use a European product and leave Google behind (if I can); I’m coming from a Pixel 8 and barely know how to use the terminal, so I’m asking for everyone’s help.
One of options is SysMetrics or any other app which can show CPU usage per app.
SysMetrics is not in the Jolla Store. You say you are 3 days with the phone so maybe it is easier do delete all apps you have installed and test it again.
All other is working fine?
That was my recommendation in another discussion, to get an overview without having OP drop into the terminal.
I take responsibility, he is innocent ![]()
What should I look for to find the solution? Do you have a way to post me the section you’re talking about? Thanks in advance but I want to be able to use my device without burning my hands.
thanks in advance!
same behavior in airplane mode? Just to rule out a bug with the radio part, given you have no sim inserted.
Since you havent installed that much I guess and the problem affects only you or maybe up to a few do a factory reset and start from scratch…
Maybe the easiest way. Problem still there after that I would take a deeper look
Nice screenshots. But in Record Load mode for a minute or so we will better see which app constantly drives CPU crazy.
I would also try with SIM card. I vaguely remember a similar case which was solved with SIM insertion.
I also remember that someone reported that using it without SIM card lead to atypical power usage. So it is definitely a good idea to test with SIM card and see if it changes anything.
You mean this?
He inserted the SIM card and then made a factory reset described here:
I have seen also a phone with strange behaviour which was setup w/o sim card. Insert the sim card and factory reset fixed. So maybe a try can help here.
I performed a factory reset twice, but nothing changed.
Sysmetrics
Not a great app to recommend to measure load if it uses two thirds of resources to draw pretty graphs…
Which app do you recommend?
I used my device days and set it up without a sim so dort think its a general problem.. But you can try…
Maybe first check if the battery and the other half sit in place.
If thats ok then its time to take a deeper look at the software side
But youre at the bginning and without further details what got installed its hard to find out.
But if the problem persist from the beginning look out for recover instructions to reflash the os or head over to jolla for rma (return authorization)
Now that would be a real culmination of bad luck.
Hope an immediate solution can be found.
Buona fortuna.
I’ve factory reset the device twice and haven’t installed anything major—just Storman and Chum. On top of that, it keeps shutting down… I only installed Brave from the Aurora Store today, and AIDA64 just showed it shutting down; the battery has been draining all day despite me barely using the phone. It’s absurd. The device is in good condition and the battery is seated perfectly; my only remaining option is to buy a physical SIM card—since I’m currently using an eSIM on my Pixel 8. I’m sure the SIM won’t actually fix anything, but it’s worth a try.
First the device lost by UPS… now this battery problem… what rotten luck ![]()
If you check in AIDA64 under “Thermals” do you see any specific component with particularly high temps?
