If you report this to Zendesk you don’t need to worry about 30 days limit.
I’m also pretty sure that this will be solved.
Good luck.
Good luck.
Forgive me, how do I submit a report on Zendesk? I’m not very familiar with it. Is there a website? A section on this forum? An email address? Thanks!
That would be https://jolla.zendesk.com/hc/en-us/requests/new
As recently mentioned, there is no J2 selection yet, but you should be fine selecting C2 and stating it in the description. Same with software.
Edit: Since you like the phone and intend to keep it, I don’t think the 30-day window applies. Your device or an accessory is defect and under warranty. Jolla will have to repair or replace it. (The 30-day return period applies if you have changed your mind about the purchase.)
I wouldn’t worry too much, but file a report via Zendesk to be on the safe side re: the 30-day window.
Since you seem to have a “fix” in place for the power consumption problem, you could just keep using the phone until you hear from Jolla.
It is difficult to say what causes the problem, or what consequences it may have had, without letting Jolla have a look. It could be a software problem, hardware problem with the USB/I2C board, or a problem with one one of your TOHs. A problem in one part may have damaged other parts, e.g. a faulty I2C board may have killed components in your TOHs, or the other way round.
Okay, reported. Let’s see what happens. I’ll keep you posted if there are any updates; thanks everyone for the help ![]()
