I can revert and reinstall or do you have better suggestion?
Edit:
Install printout from ssh (in Slovene)
[root@JollaC2 defaultuser]# pkcon install ofono-vendor-unisoc-radio-plugin ofono-binder-plugin libofonobinderpluginext
Razreševanje
Preizkušanje sprememb
Končano [ ] (0%)
Namestiti je treba naslednje pakete:
libofonobinderpluginext-1.1.18-1.10.1.jolla.aarch64 Extension framework for ofono-binder-plugin
ofono-binder-plugin-1.1.18-1.10.1.jolla.aarch64 Binder based ofono plugin
ofono-vendor-unisoc-radio-plugin-1.0.0-1.1.1.jolla.aarch64 UNISOC radio extension
Ali želite nadaljevati s spremembami? [N/y] y
Unfortunately, there is often no ringing or vibration for incoming calls. The mobile internet also often goes down, but the 4G label is there next to the network signal. I will also test the Vodafone network soon.
Sailfish OS version: 5.0.0.29 SIM provider and country: Tele2, SE Network provider and country (if roaming): n/a Number of SIM cards in use and in which slot: 1 / 1
Country
Provider
Registered
Voice in
Voice out
SMS in
SMS out
MMS in
MMS out
Compared
SE
Tele2
* Outgoing MMS was stuck on Sending..., incoming MMS was stuck on Waiting... until I disabled mobile data. Then both worked within seconds. Previously reported by meolic above.
Will be away/busy, but will try testing while roaming.
I was referring to the more detailed and focused logging instructions, so that less “excess” information is saved. The ofono logs are rather verbose, let’s put it that way.
First outgoing SMS worked.
Then I installed the logger app for ofono. After a test, the app could not connect with ofono anymore.
I had to restart.
Since then no SMS is working anymore.
Calls seem to work reliable, just signal tones and vibration isn’t working anymore, even that I reconfigured several times.
Sailfish OS version: 5.0.0.29 SIM provider and country: Vodafone, PT Network provider and country (if roaming): n/a Number of SIM cards in use and in which slot: 1 / 1
Country
Provider
Registered
Voice in
Voice out
SMS in
SMS out
MMS in
MMS out
Compared
PT
Vodafone
From my testing, it seems to be working great! Yay!
