AppSupport Bluetooth feedback thread
I have a question on AAS Bluetooth support. I read that some pairings need to be done within the android settings to get a fully working connection.
But if I try to do so the Android settings crashes roundabout a second after a tapped the bluetooth menu entry.
Jolla Phone 2026, DE
Wonderful. Thank you! I’ll try it on my next Amazon order!
Can confirm this behaviour
Edit: have read through the bug report category but have not found one describing it. Anybody else with this issue?
BR
Lukas
Yep. Can’t open the AAS BT settings.
Just now noticed, Jolla phone with 5.2.0.16, looking in to the Jolla store it says I have installed version 0.9.6 of AppSupport Bluetooth, but in the store only 0.9.1 is available. This probably means that if I uninstall it I won’t get the latest one for reinstallation?
I wrote it on 5.2.0.16 release thread the morning after the evening release when I noticed.
Hello, I had install SFOS 5.1.0.11 last week on Xperia 10 and Xperia 10iii. After it I installed the BT bridge. It works for my Amazfit GTS and I can find now all BT devices in Android settings. Now I uninstalled the BT bridge because I have one big problem. The situations app cannot find BT devices with this BT support app. Also the patch Mac adresses for BT devices shows now no adresses. But the biggest problem is, that the automatic connection for BT speaker and my car not work. I have a bose mini and every time if I will use it, I have to disconnect this complete and have to reconnect it as new. Maybe it is solvable in future or in the app we have an option to deactivate this appwithout uninstalling. This problems I have on both phones and so I think its not a phone problem.
I tried PlayStation Remote Play. I successfully paired my PS5 Controller via SFOS, but tbe app doesn’t see it. I also wanted to try the androud bkuetooth setting, but android settings crash when trying to open that subpage from android settings.
Connectiong to my Roadie Tuners had bern no problem.
Setting up a bluetooth connection between Xperia 10 III with SFOS 5.1 and new Jolla Phone to transfe bank authenticator doesn’t work, the Xperia says ”to mucg bluetooth connections”.
Jolla Phone 2026
Jolla Phone 2026 (5.2.0.16 Finlayson) and AAS Bluetooth…
Working:
  • Oura ring with Oura app
  • Polar Verity Sense HR-monitor with Polar Flow app
Not working:
  • Polar Grit X2 Pro with Polar Flow app (Tried many times. A few times got as far as accepting paring codes in both ends, but paring didn’t succeed.)
Suunto App 6.12.6, JP26 5.2.0.16, Suunto Vertical watch. The app recognises the watch but pairing stops (the error message in the app is useless “something went wrong”).
I have Polar Grit X2 and it is kind of working. It will eventually synchronize with the phone if you try many times.
Same here with Suunto app and Suunto 5 watch.
Its likely missing the Ps4 and Ps5 controllers drivers so the phone doesn’t know what to do with the controller inputs and outputs
Finally managed to pair Polar Grit X2 Pro with PolarFlow in JP2026. Synchronizing starts and proceeds a few seconds but then gets interrupted.
Did you manage to make it work? I am looking for a smart watch brand that works with the J2, that has good sport features like good GPS and such.
This morning synchronizing Polar Grit X2 Pro with Polar Flow suddenly worked on my JP2026! Did the OS update to 5.2.0.17 a few days ago, perhaps that did the trick?
I tried Suunto 5 watch connectivity setup with Sailfish OS 5.2.0.17. Same as earlier, app finds the watch but setup fails still.
  1. Phone Jolla J2 2026 5.2.0.17
  2. Bluetooth: none
  3. Android app involved: none
  4. Whether the device was paired none
  5. What else is paired - pairing is working on Sailfish level
  6. Exact steps to reproduce the problem - Go to AppSupport Settings Click Connected devices (or Network and internet ) and running Settings aplication is crashing.
  7. Whether it works after restarting no
  8. Relevant logs with debug logging enabled - yes, log shows that service is OK
   Aug 24 11:14:42 JollaPhone2026 appsupport-bridge-bt-aidl[25698]: bluetoothManagerCallback: AppSupport Bluetooth service is up
Aug 24 11:14:42 JollaPhone2026 appsupport-bridge-bt-aidl[25698]: AppSupport binder connected (callback)
Aug 24 11:14:42 JollaPhone2026 appsupport-bridge-bt-aidl[25698]: bluetoothManagerCallback: AppSupport Bluetooth service is ok
The problem is that I can not access bluetooth settings on AppSupport (Androind) as If I select menu item “Connected devices” or “Network and internet” opened Android Settings application crashes without any trace in logs (Other menu items like “Notification”, “Storage”,“Apps”,etc - working as expected.)
Tried to reinstall AppSupport bluetooth - the same result.
The item I’m trying to pair is FORM smart swimming goggles with their application and pairing an firmware updates are working perfectly on Sony Xperia 10II ;):):).
MOD EDIT: Move quote.
I’ve been using Bluetooth support over a couple of months, and as these threads are typically around fixing remaining issues across different setups. Just wanted to highlight in between the great impact to everyday use. Kudos to everyone involved! :blush:
In my case, two great examples being possible without additional tweaks now - picking up parcels from sidewalk lockers and updating firmware to my motorcycle.
Just on time for my batch 2. Think this is a gamechanger for me to make Jolla 26 my daily. For now tested it with my Tissot T-touch connect sport on my C2 ands it’s working flawless. Will do some more testing with different watches.
Edit: also Huawei Fit 4 Pro is working with gadgetbridge (from Fdroid).
