AppSupport Bluetooth feedback thread
Sorry, no luck yet. Suunto app finds my Suunto Vertical but then I get out of luck and a generic error message. While waiting and trying again I use another device for the synchronization.
Bose app is fully dysfunctional
Polar flow connects but does not sync. It’s ok, I have my old android to sync the watch and sync Jolla from cloud.
I can connect and sync my Suunto watch on my Xperia 10ii, but not on the JP2…
On the JP2, the bt connection on my VW vehicle is lost each time I want to use it. To use it again, I have to remove the connection on the JP2 and VW and repair them.
Hi,
I´m new Jolla -26 phone user and starting learning same Sailfish OS.
What Bluethooth App do you recommend to use with aurora store?
@PMR I think there is some misunderstanding. You need “AppSupport Bluetooth” from Jolla Store to be able that Android apps can communicate with Bluetooth devices. So there’s no specific App on Aurora or F-Droid or elsewhere that you ‘need’ to get that working.
Thanks for reply,
Oh, okay. I had misunderstood the situation. I actually got WhatsApp working with my Garmin watch—I didn’t do anything special; I just paired the devices, and it finally worked. Gmail isn’t working yet, though—does that require anything special?
I use Gmail with native email app without problems.
In Settings>Accounts you can set up a Google account which should add your gmail and maybe some other creepy stuff that watches you sleep :sweat_smile:
I wonder if there is a way to make Bose companion app work (I’m pretty sure there’re other cases for this)? It uses bluetooth to manage BT headphones, but they already paired to SF, so no connection to the app is happening
Today I learned why Garmin Connect app does not work…its that the Blietooth stack doed not find it or has issues. so it is not directly linked to AppSupport.
Garmin Connect app has worked for me… without any other problems than connection/syncing to vivoactive 3 often requires to restart bluetooth from settings/Utility.
Of course pairing has to be done from Garmin Connect, not with normal Bluetooth pairing…
Can’t connect DJI pocket4’s Wi-Fi after paired with BT.
Fortunately, the Pocket4 provides an interface for displaying the WiFi SSID and password.
Got a navimow i210 lidar pro lawnmower yesterday and to my amazement the navimow app works flawlessly in the JP2026 with bluetooth AAS pairing and all! Fantastic!
I see the same thing. I have no issues with the connect app, but the Bluetooth service has to be restarted once in a while. I’m not sure if it’s related only to the Android integration, as I’ve seen Bluetooth eventually needs to be restarted as well, using native Sailfish apps.
Thanks for all the feedback so far. An update for the next release is nearly ready and should be a lot more stable.
Thank you for your hard work and for this teaser :slight_smile: Made my day :heart_exclamation:
It works with my Sony Xperia 10 II, actually not at the first trial, I had to reboot the device after installing and activating it in the system/bluetooth menu.
Anyway I’m now testing in my webApp using Bluetooth WebApi under Edge browser. It’s perfect! Thanks a lot!
Hello,
I’ve got a pair of Sennheiser Momentum True Wireless 4 but I can’t seem to pair them with the app even if I can see them there.
Pairing with the phone works flawlessly but I can’t seem to pair them with the app. I tried restarting, resetting bluetooth, removing the pair and adding it back and so on.
SFOS v5.2.0.18
Also networks and bluetooth within android settings seems to freeze and crash.
Any ideas how to solve this if it’s possible are welcomed !
jollabluetooth2
Are you trying to pair with the app/AAS and the actual OS? I’m not so sure that is meant to work.
