REPRODUCIBILITY (% or how often): Once
BUILD ID = OS VERSION (Settings > About product): 3.4.0.22
HARDWARE (Jolla1, Tablet, XA2,…): Sony XA2
UI LANGUAGE:English USA
VPN is losing credentials and after re-entering credentials, SFOS states that it is connected, however traffic is not going through the VPN
Setup VPN through ProtonVPN ovpn file (working in prior version of SFOS)
- Upgrade to SFOS v3.4.0.22
- Re-enter VPN credentials that worked in previous version
- SFOS reports that it is connected however traffic is not protected
I checked the new “set as default route” option in 3.4.0.22 and it the VPN was set as the default
try to use the utilities app of for sfos, where it says restart the connectivity wlan, network and so on.
hope it helps
delocoyo, I think I may have found the problem. When I upgraded to 3.4.0.22, it may have re-enabled IPv6. I’m going to disable IPv6 and retest. I’ll let you know how it goes.
So it turns out the problem was that IPv6 was re-enabled after the upgrade and it was leaking my real IP. I disabled it and Bob’s your Uncle! Anyway, I’m sorry for the false alarm and thank you for your help!
how did you disable the ipv6?
Disable IPv6 using the following commands: devel-su sysctl -w net.ipv6.conf.all.disable_ipv6=1 and devel-su sysctl -w net.ipv6.conf.default.disable_ipv6=1
But I have found that after a reboot it, it loses the settings and re-enables IPv6. So, I have to issue the commands again
Here is the full thread if you are interested. https://together.jolla.com/question/163103/how-to-protonvpn-on-sailfish-os/
You can store these settings in a file in /etc/sysctl.d. Then they will survive a reboot.
Why false alarm? I would expect both IPs to be protected?
So I do not see this as ‘solved’ but worked around (so maybe reset the solution flag and link in OP to your workaround?). Let Jolla be aware of this.
martinh,
I found the sysctl.d folder (under: /etc/sysctl.d/) and added the first 4 lines to ipv6-settings.conf. However, IPv6 comes back after a reboot
Can you tell me how I have offended the IPv6 Gods and how appease them?
GNU nano 2.8.5 File: ipv6-settings.conf
Disable IPv6 to stop VPN leaks
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
Enable IPv6 tempaddress and prefer it
net.ipv6.conf.default.use_tempaddr = 2
net.ipv6.conf.all.use_tempaddr = 2
Disable icmp redirects
net.ipv6.conf.default.accept_redirects = 0
net.ipv6.conf.all.accept_redirects = 0
[ File 'ipv6-settings.conf' is unwritable ]
^G Get Help ^O Write Out ^W Where Is ^K Cut Text ^J Justify ^C Cur Pos
^X Exit ^R Read File ^\ Replace ^U Uncut Text^T To Spell ^_ Go To Line
Can you please clearly explain which four lines (I see three lines) has worked to solved the problem with reboot? Thank you
Hey Tinybit,
I wasn’t able to solve the reboot issue
I an pretty sure you know how to handle devel-su and nano and comment lines.
But from your post I see you used normal user to list content of /etc/sysctl.d/ipv6settings.conf.
And the new added lines look bold as the other comment lines which seems strange to me.
Another possible reason could be cr/lf issue in case you edited that file via ssh on Windoze?
I’m using a Debian based flavor called Parrot. And yeah, I used the admin account to edit the file and a normal user account to take the screenshot. So, I don’t know why the text got crazy when I copied and pasted into the forum but… c’est la vie.
And just for the record, I don’t use Windoze, sir!
Allright!
So then I do not know!
And here are two more guesses:
- remove the multiple blank lines in between and leave only one (do not think so but just experience…)
- move the ‘disable ipv6’ section behind the ‘enable ipv6’ section
Just a few comments:
- I’ld rather not edit a configuration file managed by a system package, in this case
# rpm -qf ipv6-settings.conf
droid-config-h3113-0.2.65-1.17.40.jolla.armv7hl
In the best case it will be overwritten during upgrade, in the worst case an update will fail.
- A new file in that folder should end in
.conf, e.g.:
# cat > /etc/sysctl.d/ipv6_off.conf
CTRL-D to send EOF to cat and exit.
- To test your changes, use e.g.
# sysctl --system
* Applying /etc/sysctl.d/ipv6_off.conf ...
Post edited: It’s not systemctl --system but sysctl --system.
Thanks. Makes sense.
But that still does not explain why those changes were not accepted
We need an update on solution , otherwise I’ll have to re-flash back to 3.3 as not willing to use phone without VPN
OK, here is what I did:
1.) Put the ipv6-settings.config file back to “stock”
2.) Created the ipv6_off.conf file in the /etc/sysctl.d directory as ROOT
3.) Ran the systemctl --system command as ROOT
4.) Rebooted
Unfortunately, my IPv6 address is still leaking through the VPN
That’s hard to debug remotely. Some things come to mind…
# sysctl -a --pattern "disable_ipv6"
- … and
ifconfig?
On my device wlan0 still has a (link local) ipv6 address even with net.ipv6.conf.all.disable_ipv6 = 1.
- What does “Unfortunately, my IPv6 address is still leaking through the VPN” actually mean? How did you test that?
I’m not using openvpn here but it simply opens a tun or tap interface and routes traffic through that device, as e.g. ssh can do. You can check, if traffic to a certain address is properly routed by calling e.g.
# host www.google.com 9.9.9.9
Using domain server:
Address: 9.9.9.9#53
Aliases:
www.google.com has address 172.217.18.100
www.google.com has IPv6 address 2a00:1450:4001:801::2004
and with these addresses:
# ip route get 172.217.18.100
172.217.18.100 via 192.168.178.20 dev wlan0 src 192.168.178.46
cache
and
# ip route get 2a00:1450:4001:801::2004
Obviously the ipv4 address to Google is routed via wlan0 on my device and no route for ipv6. For you with enabled VPN it should be a tap or tun device, e.g. tun0.
