Oh, just spotted my error. It’s not systemctl --system but sysctl --system. That should produce the mentioned output:
* Applying /etc/sysctl.d/ipv6_off.conf ...
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
I use ipleak.net to test my VPN. If I see an IPv6 address, I know my VPN is being bypassed. I saw you updated the sysctl command. I’ll respond to that on the it’s thread.
[defaultuser@Xperia10 ~] sysctl -a --pattern "disable_ipv6"
net.ipv6.conf.all.disable_ipv6 = 0
net.ipv6.conf.bond0.disable_ipv6 = 0
net.ipv6.conf.default.disable_ipv6 = 0
net.ipv6.conf.ip6_vti0.disable_ipv6 = 0
net.ipv6.conf.ip6tnl0.disable_ipv6 = 0
net.ipv6.conf.ip_vti0.disable_ipv6 = 0
net.ipv6.conf.lo.disable_ipv6 = 0
net.ipv6.conf.p2p0.disable_ipv6 = 0
net.ipv6.conf.rmnet_data0.disable_ipv6 = 1
net.ipv6.conf.rmnet_data1.disable_ipv6 = 1
net.ipv6.conf.rmnet_data2.disable_ipv6 = 1
net.ipv6.conf.rmnet_data3.disable_ipv6 = 1
net.ipv6.conf.rmnet_data4.disable_ipv6 = 1
net.ipv6.conf.rmnet_data5.disable_ipv6 = 1
net.ipv6.conf.rmnet_data6.disable_ipv6 = 1
net.ipv6.conf.rmnet_data7.disable_ipv6 = 1
net.ipv6.conf.rmnet_ipa0.disable_ipv6 = 1
net.ipv6.conf.sit0.disable_ipv6 = 0
net.ipv6.conf.vpn0.disable_ipv6 = 1
net.ipv6.conf.wlan0.disable_ipv6 = 0
[defaultuser@Xperia10 ~]$ ifconfig
-bash: ifconfig: command not found
1.) When I run the command it turns off IPv6
2.) If I reboot, IPv6 is re-enabled
Again, I am using www.ipleak.net to test
[defaultuser@Xperia10 ~]$ devel-su sysctl --system
Password:
- Applying /etc/sysctl.d/00-ipv4.conf …
net.ipv4.ip_forward = 0
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.default.accept_source_route = 0
- Applying /etc/sysctl.d/00-sysrq.conf …
kernel.sysrq = 0
- Applying /etc/sysctl.d/00-vm.conf …
vm.dirty_writeback_centisecs = 1500
vm.swappiness = 30
- Applying /usr/lib/sysctl.d/50-default.conf …
kernel.sysrq = 16
kernel.core_uses_pid = 1
net.ipv4.conf.all.rp_filter = 1
net.ipv4.conf.all.accept_source_route = 0
net.ipv4.conf.default.promote_secondaries = 1
net.ipv4.conf.all.promote_secondaries = 1
sysctl: setting key “net.core.default_qdisc”: No such file or directory
net.core.default_qdisc = fq_codel
fs.protected_hardlinks = 1
fs.protected_symlinks = 1
- Applying /etc/sysctl.d/ipv4-settings.conf …
net.ipv4.conf.default.accept_redirects = 0
net.ipv4.conf.all.accept_redirects = 0
net.ipv4.conf.default.secure_redirects = 0
net.ipv4.conf.all.secure_redirects = 0
- Applying /etc/sysctl.d/ipv6-settings.conf …
net.ipv6.conf.default.use_tempaddr = 2
net.ipv6.conf.all.use_tempaddr = 2
net.ipv6.conf.default.accept_redirects = 0
net.ipv6.conf.all.accept_redirects = 0
- Applying /etc/sysctl.d/ipv6_off.conf …
Sorry… I should have run the command as ROOT
[defaultuser@Xperia10 ~]$ devel-su ifconfig
Password:
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:521 errors:0 dropped:0 overruns:0 frame:0
TX packets:521 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1
RX bytes:53010 (51.7 KiB) TX bytes:53010 (51.7 KiB)
rmnet_ipa0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
UP RUNNING MTU:2000 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
vpn0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:10.17.0.3 P-t-P:10.17.0.3 Mask:255.255.0.0
UP POINTOPOINT RUNNING NOARP MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:518 errors:0 dropped:0 overruns:0 frame:0
TX packets:600 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:142449 (139.1 KiB) TX bytes:57037 (55.7 KiB)
wlan0 Link encap:Ethernet HWaddr 38:78:62:68:3E:12
inet addr:192.168.1.221 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: 2600:1700:9bd2:34b0:3a78:62ff:fe68:3e12/64 Scope:Global
inet6 addr: fe80::3a78:62ff:fe68:3e12/64 Scope:Link
UP BROADCAST RUNNING MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:2899 errors:0 dropped:334 overruns:0 frame:0
TX packets:3235 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3000
RX bytes:1118524 (1.0 MiB) TX bytes:454719 (444.0 KiB)
That helps. Settings are properly picked up by sysctl but get overridden by some other process and connman seems to be responsible. You can test that assumption by running
# sysctl --system
# ifconfig
Now interface wlan0 will not have an IPv6 address. But after
# systemctl restart connman
or switching flightmode on and off again
# ifconfig
proves the address is back again and sysctl settings are overwritten.
connman offers to disable IPv6 in service configuration files or from commandline but I didn’t find a way to disable it globally or on all interfaces except loopback.
Maybe blocking IPv6 in the firewall helps as it avoids getting a routable address when the interface comes up?
