i updated my XA2 Ultra to 4.4
apparently everything went well, but after the upgrade
the SIM card seems to be not recognized any more though i am asked for the pin code after a reboot
trying to turn on WLAN throws this message
“Networking is not available Please restart device”
which i did a good dozen times without any effect
Same here after update to 4.4.0.58 today from the previous version, Polish PLAY network. I have two sims, nothing is working but WIFI now. Restoring from backup does not work.
EDIT: Just checked, these SIM cards work just fine in other (non-Jolla) phone.
DrDweeb: thanks for the answer
which version did you flash
any hint about that
jstaniek: yes nothing to do with the SIM card
in the mean time i called back on duty an old FairPhone 2 with SFOS 3.0
i had almost forgotten how nice it was to have:
a compass working
a battery utility working
UI Themer working
a GPS almost immediately responding
and a few other goodies…
Thanks, to clarify. In my case only SIMs are not visible with all consequences of this. All other non-calling functions of the device work OK, including networking via the WIFI.
And ‘systemctl-user’ command logs below.
Failed are:
● osupdate-check.service loaded failed failed Store client os update check
● sailfish-osupdate.service loaded failed failed Sailfish OS Update
Please note that my update to 4.4.0.58 went smoothly (at least from the end-user perspective, the device restarted as usual).
# systemctl-user status
UNIT LOAD ACTIVE SUB DESCRIPTION
sys-devices-soc-18800000.qcom\x2cicnss-net-p2p0.device loaded active plugged /sys/devices/soc/18800000.qcom,icnss/net/p2p0
sys-devices-soc-18800000.qcom\x2cicnss-net-wlan0.device loaded active plugged /sys/devices/soc/18800000.qcom,icnss/net/wlan0
sys-devices-soc-c084000.sdhci-mmc_host-mmc1-mmc1:0007-block-mmcblk1-mmcblk1p1.device loaded active plugged /sys/devices/soc/c084000.sdhci/mmc_host/mmc1/mmc1:0007/block/mmcblk1/mmcblk1p1
sys-devices-soc-c084000.sdhci-mmc_host-mmc1-mmc1:0007-block-mmcblk1.device loaded active plugged /sys/devices/soc/c084000.sdhci/mmc_host/mmc1/mmc1:0007/block/mmcblk1
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p1.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p10.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p10
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p11.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p11
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p12.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p12
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p13.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p13
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p14.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p14
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p15.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p15
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p16.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p16
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p17.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p17
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p18.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p18
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p19.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p19
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p2.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p2
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p20.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p20
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p21.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p21
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p22.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p22
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p23.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p23
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p24.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p24
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p25.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p25
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p26.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p26
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p27.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p27
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p28.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p28
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p29.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p29
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p3.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p3
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p30.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p30
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p31.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p31
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p32.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p32
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p33.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p33
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p34.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p34
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p35.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p35
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p36.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p36
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p37.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p37
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p38.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p38
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p39.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p39
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p4.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p4
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p40.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p40
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p41.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p41
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p42.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p42
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p43.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p43
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p44.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p44
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p45.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p45
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p46.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p46
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p47.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p47
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p48.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p48
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p49.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p49
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p5.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p5
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p50.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p50
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p51.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p51
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p52.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p52
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p53.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p53
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p54.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p54
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p55.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p55
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p56.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p56
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p57.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p57
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p58.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p58
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p59.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p59
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p6.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p6
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p60.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p60
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p61.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p61
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p62.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p62
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p63.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p63
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p64.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p64
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p65.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p65
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p66.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p66
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p67.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p67
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p68.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p68
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p69.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p69
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p7.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p7
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p70.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p70
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p71.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p71
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p72.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p72
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p73.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p73
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p74.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p74
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p75.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p75
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p76.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p76
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p77.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p77
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p78.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p78
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p79.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p79
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p8.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p8
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p9.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p9
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0rpmb.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0rpmb
sys-devices-soc-c0c4000.sdhci-mmc_host-mmc0-mmc0:0001-block-mmcblk0.device loaded active plugged /sys/devices/soc/c0c4000.sdhci/mmc_host/mmc0/mmc0:0001/block/mmcblk0
sys-devices-soc-c1af000.uart-tty-ttyHS0.device loaded active plugged /sys/devices/soc/c1af000.uart/tty/ttyHS0
sys-devices-soc-soc:sound-sound-card0.device loaded active plugged /sys/devices/soc/soc:sound/sound/card0
sys-devices-virtual-block-dm\x2d0.device loaded active plugged /sys/devices/virtual/block/dm-0
sys-devices-virtual-block-dm\x2d1.device loaded active plugged /sys/devices/virtual/block/dm-1
sys-devices-virtual-block-loop0.device loaded active plugged /sys/devices/virtual/block/loop0
sys-devices-virtual-block-ram0.device loaded active plugged /sys/devices/virtual/block/ram0
sys-devices-virtual-block-ram1.device loaded active plugged /sys/devices/virtual/block/ram1
sys-devices-virtual-block-ram10.device loaded active plugged /sys/devices/virtual/block/ram10
sys-devices-virtual-block-ram11.device loaded active plugged /sys/devices/virtual/block/ram11
sys-devices-virtual-block-ram12.device loaded active plugged /sys/devices/virtual/block/ram12
sys-devices-virtual-block-ram13.device loaded active plugged /sys/devices/virtual/block/ram13
sys-devices-virtual-block-ram14.device loaded active plugged /sys/devices/virtual/block/ram14
sys-devices-virtual-block-ram15.device loaded active plugged /sys/devices/virtual/block/ram15
sys-devices-virtual-block-ram2.device loaded active plugged /sys/devices/virtual/block/ram2
sys-devices-virtual-block-ram3.device loaded active plugged /sys/devices/virtual/block/ram3
sys-devices-virtual-block-ram4.device loaded active plugged /sys/devices/virtual/block/ram4
sys-devices-virtual-block-ram5.device loaded active plugged /sys/devices/virtual/block/ram5
sys-devices-virtual-block-ram6.device loaded active plugged /sys/devices/virtual/block/ram6
sys-devices-virtual-block-ram7.device loaded active plugged /sys/devices/virtual/block/ram7
sys-devices-virtual-block-ram8.device loaded active plugged /sys/devices/virtual/block/ram8
sys-devices-virtual-block-ram9.device loaded active plugged /sys/devices/virtual/block/ram9
sys-devices-virtual-block-zram0.device loaded active plugged /sys/devices/virtual/block/zram0
sys-devices-virtual-bluetooth-hci0.device loaded active plugged /sys/devices/virtual/bluetooth/hci0
sys-devices-virtual-misc-rfkill.device loaded active plugged /sys/devices/virtual/misc/rfkill
sys-devices-virtual-net-bond0.device loaded active plugged /sys/devices/virtual/net/bond0
sys-devices-virtual-net-rmnet_data0.device loaded active plugged /sys/devices/virtual/net/rmnet_data0
sys-devices-virtual-net-rmnet_data1.device loaded active plugged /sys/devices/virtual/net/rmnet_data1
sys-devices-virtual-net-rmnet_data2.device loaded active plugged /sys/devices/virtual/net/rmnet_data2
sys-devices-virtual-net-rmnet_data3.device loaded active plugged /sys/devices/virtual/net/rmnet_data3
sys-devices-virtual-net-rmnet_data4.device loaded active plugged /sys/devices/virtual/net/rmnet_data4
sys-devices-virtual-net-rmnet_data5.device loaded active plugged /sys/devices/virtual/net/rmnet_data5
sys-devices-virtual-net-rmnet_data6.device loaded active plugged /sys/devices/virtual/net/rmnet_data6
sys-devices-virtual-net-rmnet_data7.device loaded active plugged /sys/devices/virtual/net/rmnet_data7
sys-devices-virtual-net-rmnet_ipa0.device loaded active plugged /sys/devices/virtual/net/rmnet_ipa0
sys-devices-virtual-net-sit0.device loaded active plugged /sys/devices/virtual/net/sit0
sys-module-configfs.device loaded active plugged /sys/module/configfs
sys-module-fuse.device loaded active plugged /sys/module/fuse
sys-subsystem-bluetooth-devices-hci0.device loaded active plugged /sys/subsystem/bluetooth/devices/hci0
sys-subsystem-net-devices-bond0.device loaded active plugged /sys/subsystem/net/devices/bond0
sys-subsystem-net-devices-p2p0.device loaded active plugged /sys/subsystem/net/devices/p2p0
sys-subsystem-net-devices-rmnet_data0.device loaded active plugged /sys/subsystem/net/devices/rmnet_data0
sys-subsystem-net-devices-rmnet_data1.device loaded active plugged /sys/subsystem/net/devices/rmnet_data1
sys-subsystem-net-devices-rmnet_data2.device loaded active plugged /sys/subsystem/net/devices/rmnet_data2
sys-subsystem-net-devices-rmnet_data3.device loaded active plugged /sys/subsystem/net/devices/rmnet_data3
sys-subsystem-net-devices-rmnet_data4.device loaded active plugged /sys/subsystem/net/devices/rmnet_data4
sys-subsystem-net-devices-rmnet_data5.device loaded active plugged /sys/subsystem/net/devices/rmnet_data5
sys-subsystem-net-devices-rmnet_data6.device loaded active plugged /sys/subsystem/net/devices/rmnet_data6
sys-subsystem-net-devices-rmnet_data7.device loaded active plugged /sys/subsystem/net/devices/rmnet_data7
sys-subsystem-net-devices-rmnet_ipa0.device loaded active plugged /sys/subsystem/net/devices/rmnet_ipa0
sys-subsystem-net-devices-sit0.device loaded active plugged /sys/subsystem/net/devices/sit0
sys-subsystem-net-devices-wlan0.device loaded active plugged /sys/subsystem/net/devices/wlan0
-.mount loaded active mounted Root Mount
bt_firmware.mount loaded active mounted /bt_firmware
config.mount loaded active mounted /config
dsp.mount loaded active mounted /dsp
firmware.mount loaded active mounted /firmware
home.mount loaded active mounted /home
mnt.mount loaded active mounted /mnt
odm.mount loaded active mounted /odm
opt.mount loaded active mounted /opt
persist.mount loaded active mounted /persist
run-firejail-dbus.mount loaded active mounted /run/firejail/dbus
run-media-nemo-bcbee4af\x2d89fb\x2d44bd\x2db614\x2d60ec59d070c0.mount loaded active mounted /run/media/nemo/bcbee4af-89fb-44bd-b614-60ec59d070c0
run-user-100000.mount loaded active mounted /run/user/100000
sys-fs-fuse-connections.mount loaded active mounted /sys/fs/fuse/connections
sys-kernel-config.mount loaded active mounted /sys/kernel/config
sys-kernel-debug-tracing.mount loaded active mounted /sys/kernel/debug/tracing
sys-kernel-debug.mount loaded active mounted /sys/kernel/debug
tmp.mount loaded active mounted /tmp
booster-silica-session.path loaded active running Session root process booster socket path
init.scope loaded active running System and Service Manager
alienaudio.service loaded active running Alien Audio Service
alienkeyboard.service loaded active running Alien Keyboard Service
ambienced.service loaded active running Ambience daemon
apkd-bridge-user.service loaded active running Bridge native data to Alien Dalvik
apkd-bridge.service loaded active running Bridge native data to Alien Dalvik
booster-browser.service loaded active running Application launch booster for Sailfish Browser
booster-browser@jolla-email.service loaded active running Application launch booster for Sailfish Browser (sandboxed)
booster-browser@sailfish-browser.service loaded active running Application launch booster for Sailfish Browser (sandboxed)
booster-generic.service loaded active running Generic application launch booster
booster-qt5-signal.service loaded active exited Signal booster-qt5 that boot is over
booster-qt5.service loaded active running Application launch booster for Qt5
booster-silica-media.service loaded active running Application launch booster for Sailfish Media
booster-silica-media@jolla-camera-lockscreen.service loaded active running Application launch booster for Sailfish Media (sandboxed)
booster-silica-media@jolla-camera.service loaded active running Application launch booster for Sailfish Media (sandboxed)
booster-silica-qt5.service loaded active running Application launch booster for Silica on QtQuick2
commhistoryd.service loaded active running Communication history daemon
connectionagent.service loaded active running Connection Agent
contactsd.service loaded active running Contacts daemon
dbus.service loaded active running D-Bus Session Message Bus
dconf.service loaded active running User preferences database
jolla-messages.service loaded active running Jolla messaging
jolla-signon-ui.service loaded active running Jolla sign-on UI daemon
lipstick-security-ui.service loaded active running The lipstick security prompt UI
lipstick.service loaded active running The lipstick UI
maliit-server.service loaded active running The Maliit server
messageserver5.service loaded active running messageserver5
mission-control-5.service loaded active running Telepathy mission control daemon
mpris-proxy.service loaded active running Bluez5-MPRIS Proxy
msyncd.service loaded active running Sync FW daemon
ngfd.service loaded active running Non-Graphic Feedback Daemon
obex.service loaded active running Bluetooth OBEX service
ohm-session-agent.service loaded active running OHM Session Agent
oneshot-user-late.service loaded active exited Oneshot stuff for user (late run)
oneshot-user.service loaded active exited Oneshot stuff for user
post-user-session-init-done.service loaded active exited Post user session bootup finished
profiled.service loaded active running Profile Daemon
pulseaudio.service loaded active running PulseAudio
sailfish-homescreen-services.service loaded active running Sailfish homescreen user agent service
sailfish-secretsd.service loaded active running Sailfish Secrets Daemon
simkit-agent.service loaded active running simkit agent
timed-qt5.service loaded active running Time Daemon
tracker-miner-fs-3.service loaded active running Tracker file system data miner
user-session-init-done.service loaded active exited User session bootup finished
voicecall-manager.service loaded active running Voicecall manager
voicecall-ui-prestart.service loaded active running Voicecall ui prestart
-.slice loaded active active Root Slice
background.slice loaded active active background.slice
booster\x2dbrowser.slice loaded active active booster\x2dbrowser.slice
booster\x2dsilica\x2dmedia.slice loaded active active booster\x2dsilica\x2dmedia.slice
dbus.socket loaded active running D-Bus Session Message Bus Socket
dev-zram0.swap loaded active active /dev/zram0
basic.target loaded active active Basic System
booster-session.target loaded active active Booster session
paths.target loaded active active Paths
post-user-session.target loaded active active Post user session
pre-user-session.target loaded active active Pre user session
sockets.target loaded active active Sockets
timers.target loaded active active Timers
user-session.target loaded active active User session
osupdate-check.timer loaded active waiting OS update timer
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
218 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
My “failed” update appeared to go smoothly. I wasn’t watching it work, but the phone was rebooted and showed as running 4.4.0.58 when I went back to it.
However, nothing networking related was working. I think I made a post about it in the 4.4 release thread.
I was upgrading from the previous 4.3 release.
I reflashed back to that release (that’s what is available on the download website) and then upgraded again, which now works mostly. I can’t access my dropbox backup which is a pain.
Update, per Jolla support, to gather some ofono logs, I Installed “ofono logger” 1.0.21 from Jolla store and it looks like in the attachment. Isn’t the app not working because of the isolation enabled in recent OS releases?
Or how to run the logger in priviledged mode or preferably how to gather ofono logs from the command line?
Also, openrepos (storeman) app disappeared and I am not able to reinstall from the GUI.
not it complained again about missing internet connection
i have never done any ssh !
a good tutorial would be welcomed
I finally did Settings > reset device
which reverted to 3.3 OS version and i may stay there for a while
as i have had troubles to understand what the recent 4.* version brought useful to my way of using the phone
but it surely brought its share of troubles and bad (to my eyes) behavior
i finally did a System > Reset device
which restored the WLAN connection
and i got through the tedious job of downloading and installing from 3.0 version
all went well until i tried to download and install 4.3.0.15
with this i had the following issue
1- “Remove or revert the following package… ofono-alien-binder-plugin”
which could not be removed
i had to remove Android support
then second issue
2- “Remove or revert the following package… fingerterm”
i ignored this and 4.3.0.15 is now installed
I’ll try to clarify steps a bit further – these steps could potentially help with Xperia 10 II:
# Make sure repositories point to right version
devel-su ssu re 4.4.0.58
devel-su ssu rr adaptation-common
devel-su -p pkcon refresh
devel-su -p pkcon install ofono-ril-binder-plugin
# Reboot device
devel-su -p version --dup
