[4.4.0.64] XPERIA 10 III - Screen wakes up for no reason -> Battery drainage
REPRODUCIBILITY: Keeps happening repeatedly
OS VERSION: 4.4.0.64
HARDWARE: XPERIA 10 III
UI LANGUAGE: EN (UK)
REGRESSION:
When the phone is on the table without being used, the screen wakes up as if there was a notification coming, but there is none. After some seconds, the screen shuts down, and then everything begins again. This is causing a clear battery drainage.
EDIT: I forgot to say that I used the phone for several week with Android 11 and 12, and there were no problems whatsoever. So I would discard a hardware problem. Before flashing SFOSX I downgraded the phone to Android 11.
EDIT2: Having the device lock enabled or disabled makes no difference.
Phone lying idle on the table
  1. Phone on the table without being used.
  2. Enjoy seeing how the screen switches on for 10 secs, approx. The sleep time for the display has been tested with different values and does not appear to significantly change this problem. The time between switching off and switching on again seem to slightly change, but this could be subjective.
The screen of the idle phone should only be switchen on either when the user actively want to unlock it, or when a notification arrives.
Screen switches on cyclically w/o any reason.
Do you have developer mode and ssh enabled to check the logs? They may give some clue as to what’s going on.
Yes I have. Tell me what to input.
I did some tests again. I reflashed Android 11 and did the process again. In the beginning it seemed that it did not happen again. After modifying device lock settings (=disable device lock) it began happening.
Then, I reflashed again to “undo” the device lock setting modification. I did not do said modification but it happened again.
If you can ssh into your device and run the following:
devel-su journalctl --system -f
and just watch it for a bit, you may see a correlation between the activity and output to the logs. Unfortunately this isn’t my area, so it’s hard for me to suggest what to look out for, but it may be something obvious.
Standard warning: the logs can contain private/sensitive data, so be careful to strip anything of this nature before posting any of this log output to the forum.
I have inserted a couple of comment where the screen was switching on/off.
(deleted some apparently irrelevant events, to avoid writing >50K characters.)
[root@Xperia10III defaultuser]# journalctl --system -f
-- Logs begin at Fri 2022-05-20 13:27:02 CEST. --
May 20 13:35:49 Xperia10III kernel: pn544_dev_ioctl :exit cmd = 1074063617, arg = 0
May 20 13:35:49 Xperia10III kernel: @@@@ panel power off @@@@
**--->> screen Going to SLEEP**
May 20 13:35:49 Xperia10III mce[1862]: modules/display.c: mdy_display_state_enter(): current display state = OFF
May 20 13:35:49 Xperia10III kernel: [schedu][0x4aa859caf][13:35:49.764838] wlan: [6840:I:OSIF] scan start scan id 41066
May 20 13:35:50 Xperia10III kernel: binder: 7522 RLIMIT_NICE not set
May 20 13:35:53 Xperia10III kernel: binder: 7522 RLIMIT_NICE not set
May 20 13:35:54 Xperia10III kernel: [schedu][0x4af8d3bf7][13:35:54.159921] wlan: [6840:I:OSIF] vdev 0, scan id 41066 type COMPLETED(1) reason COMPLETED(1) scan found 13 bss
May 20 13:35:54 Xperia10III kernel: rpmh_rsc_send_data: 143 callbacks suppressed
May 20 13:35:54 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x42e08
May 20 13:35:56 Xperia10III kernel: binder: 7522 RLIMIT_NICE not set
May 20 13:35:56 Xperia10III mce[1862]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: OPEN -> UNDEF
May 20 13:35:56 Xperia10III kernel: PM: suspend entry (deep)
May 20 13:35:56 Xperia10III kernel: PM: Syncing filesystems ... done.
May 20 13:35:56 Xperia10III kernel: Freezing user space processes ...
May 20 13:35:56 Xperia10III kernel: Freezing of tasks aborted after 0.010 seconds
May 20 13:35:56 Xperia10III kernel: OOM killer enabled.
May 20 13:35:56 Xperia10III kernel: Restarting tasks ... done.
May 20 13:35:56 Xperia10III kernel: PM: suspend exit
May 20 13:35:57 Xperia10III kernel: PM: Syncing filesystems ... done.
May 20 13:35:57 Xperia10III kernel: Freezing user space processes ... (elapsed 0.005 seconds) done.
May 20 13:35:57 Xperia10III kernel: OOM killer disabled.
May 20 13:35:57 Xperia10III kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
May 20 13:35:57 Xperia10III kernel: Suspending console(s) (use no_console_suspend to debug)
May 20 13:35:57 Xperia10III kernel: [kworke][0x4b2c5b9ef][13:35:56.974188] wlan: [9997:I:HDD] hdd_suspend_wlan: 1244: WLAN being suspended by OS
May 20 13:35:57 Xperia10III kernel: [kworke][0x4b2c5d1a3][13:35:56.974504] wlan: [9997:I:PMO] pmo_core_is_wow_applicable: 319: lpass enabled, enabling wow
May 20 13:35:57 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_suspend:enter
May 20 13:35:57 Xperia10III kernel: [kworke][0x4b2ce3b1b][13:35:57.003217] wlan: [282:I:HDD] __wlan_hdd_bus_suspend: 1066: starting bus suspend
May 20 13:35:57 Xperia10III kernel: [kworke][0x4b2ce3f0f][13:35:57.003269] wlan: [282:I:PMO] pmo_core_enable_wow_in_fw: 813: Prevent link down, non-drv wow is enabled
May 20 13:35:57 Xperia10III kernel: [kworke][0x4b2ce3f81][13:35:57.003275] wlan: [282:I:PMO] pmo_core_enable_wow_in_fw: 817: system suspend wow
May 20 13:35:57 Xperia10III kernel: [kworke][0x4b2ce40ac][13:35:57.003291] wlan: [282:I:WMI] send_wow_enable_cmd_tlv: 1831: suspend type: WOW_IFACE_PAUSE_DISABLED flag is 0x20
May 20 13:35:57 Xperia10III kernel: [kworke][0x4b2d0c39e][13:35:57.011863] wlan: [282:I:HDD] __wlan_hdd_bus_suspend: 1142: bus suspend succeeded
May 20 13:35:57 Xperia10III kernel: dpm_run_callback(): platform_pm_suspend+0x0/0x6c returns -16
May 20 13:35:57 Xperia10III kernel: PM: Device alarmtimer failed to suspend: error -16
May 20 13:35:57 Xperia10III kernel: PM: Some devices failed to suspend, or early wake event detected
May 20 13:35:57 Xperia10III kernel: [kworke][0x4b2d0e74c][13:35:57.012339] wlan: [282:I:HDD] wlan_hdd_bus_resume: 1280: starting bus resume
May 20 13:35:57 Xperia10III kernel: [kworke][0x4b2d0eabf][13:35:57.012385] wlan: [282:I:PMO] pmo_core_psoc_send_host_wakeup_ind_to_fw: 1219: Host wakeup indication sent to fw
May 20 13:35:57 Xperia10III kernel: [soft_i][0x4b2d0f9a7][13:35:57.012584] wlan: [0:F:WMA] Non-WLAN triggered wakeup: UNSPECIFIED (-1)
May 20 13:35:57 Xperia10III kernel: [kworke][0x4b2d10555][13:35:57.012740] wlan: [282:I:HDD] wlan_hdd_bus_resume: 1345: bus resume succeeded
May 20 13:35:57 Xperia10III kernel: [kworke][0x4b2d141de][13:35:57.013547] wlan: [12046:I:HDD] hdd_resume_wlan: 1302: WLAN being resumed by OS
May 20 13:35:57 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_resume:enter
May 20 13:35:57 Xperia10III kernel: OOM killer enabled.
May 20 13:35:57 Xperia10III kernel: i2c_pmic 2-0009: ignoring dependency for device, assuming no driver
May 20 13:35:57 Xperia10III kernel: Restarting tasks ... done.
May 20 13:35:57 Xperia10III kernel: PM: suspend exit
May 20 13:35:58 Xperia10III kernel: binder: 7522 RLIMIT_NICE not set
May 20 13:35:59 Xperia10III kernel: PM: suspend entry (deep)
May 20 13:35:59 Xperia10III kernel: PM: Syncing filesystems ... done.
May 20 13:35:59 Xperia10III kernel: Freezing user space processes ... (elapsed 0.011 seconds) done.
May 20 13:35:59 Xperia10III kernel: OOM killer disabled.
May 20 13:35:59 Xperia10III kernel: Freezing remaining freezable tasks ... (elapsed 0.003 seconds) done.
May 20 13:35:59 Xperia10III kernel: Suspending console(s) (use no_console_suspend to debug)
May 20 13:35:59 Xperia10III kernel: [kworke][0x4b52ea7db][13:35:59.079973] wlan: [9997:I:HDD] hdd_suspend_wlan: 1244: WLAN being suspended by OS
May 20 13:35:59 Xperia10III kernel: [kworke][0x4b52ec63c][13:35:59.080378] wlan: [9997:I:PMO] pmo_core_is_wow_applicable: 319: lpass enabled, enabling wow
May 20 13:35:59 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_suspend:enter
May 20 13:35:59 Xperia10III kernel: CPU7 is up
May 20 13:35:59 Xperia10III kernel: [soft_i][0x4b5611f2a][13:35:59.252231] wlan: [0:E:QDF] htc_rx_completion_handler: 442: Received initial wake up
May 20 13:35:59 Xperia10III kernel: no screen_state.
May 20 13:35:59 Xperia10III kernel: [kworke][0x4b5627d38][13:35:59.256898] wlan: [282:I:HDD] wlan_hdd_bus_resume: 1280: starting bus resume
May 20 13:35:59 Xperia10III kernel: [kworke][0x4b562803b][13:35:59.256938] wlan: [282:I:PMO] pmo_core_psoc_send_host_wakeup_ind_to_fw: 1219: Host wakeup indication sent to fw
May 20 13:35:59 Xperia10III kernel: [soft_i][0x4b56294de][13:35:59.257214] wlan: [0:F:WMA] WLAN triggered wakeup: PATTERN_MATCH_FOUND (9), vdev: 0 (STA)
May 20 13:35:59 Xperia10III kernel: [soft_i][0x4b5629955][13:35:59.257273] wlan: [0:F:WMA] WLAN wake reason counters:
May 20 13:35:59 Xperia10III kernel: [kworke][0x4b5629a00][13:35:59.257282] wlan: [282:I:HDD] wlan_hdd_bus_resume: 1345: bus resume succeeded
May 20 13:35:59 Xperia10III kernel: [soft_i][0x4b5629a55][13:35:59.257286] wlan: [0:F:WMA] uc:0 bc:0 v4_mc:0 v6_mc:0 ra:0 ns:0 na:0 icmp:0 icmpv6:0
May 20 13:35:59 Xperia10III kernel: [soft_i][0x4b5629b37][13:35:59.257298] wlan: [0:F:WMA] assoc:0 disassoc:0 assoc_resp:0 reassoc:0 reassoc_resp:0 auth:0 deauth:0 action:0
May 20 13:35:59 Xperia10III kernel: [soft_i][0x4b5629c09][13:35:59.257309] wlan: [0:F:WMA] pno_match:0 pno_complete:0 gscan:0 low_rssi:0 rssi_breach:0 oem:0 scan_11d:0
May 20 13:35:59 Xperia10III kernel: [soft_i][0x4b562a03c][13:35:59.257365] wlan: [0:I:WMA] wma_wow_parse_data_pkt: 2172: Src_mac: 5c:ba:ef:78:0d:15, Dst_mac: 3c:01:ef:f5:c8:39
May 20 13:35:59 Xperia10III kernel: [soft_i][0x4b562a1e6][13:35:59.257387] wlan: [0:I:WMA] WOW Wakeup: IPV4 TCP Packet rcvd
May 20 13:35:59 Xperia10III kernel: [soft_i][0x4b562a507][13:35:59.257429] wlan: [0:I:WMA] Pkt_len: 40, src_port: 49809, dst_port: 22
May 20 13:35:59 Xperia10III kernel: [kworke][0x4b562a528][13:35:59.257431] wlan: [12046:I:HDD] hdd_resume_wlan: 1302: WLAN being resumed by OS
May 20 13:35:59 Xperia10III kernel: [soft_i][0x4b562a62a][13:35:59.257444] wlan: [0:F:WMA] WLAN wake reason counters:
May 20 13:35:59 Xperia10III kernel: [soft_i][0x4b562a6fc][13:35:59.257455] wlan: [0:F:WMA] uc:1 bc:0 v4_mc:0 v6_mc:0 ra:0 ns:0 na:0 icmp:0 icmpv6:0
May 20 13:35:59 Xperia10III kernel: [soft_i][0x4b562a7cd][13:35:59.257466] wlan: [0:F:WMA] assoc:0 disassoc:0 assoc_resp:0 reassoc:0 reassoc_resp:0 auth:0 deauth:0 action:0
May 20 13:35:59 Xperia10III kernel: [soft_i][0x4b562a8a4][13:35:59.257477] wlan: [0:F:WMA] pno_match:0 pno_complete:0 gscan:0 low_rssi:0 rssi_breach:0 oem:0 scan_11d:0
May 20 13:35:59 Xperia10III kernel: [soft_i][0x4b562b3d8][13:35:59.257627] wlan: [0:I:HTT] htt_get_first_packet_after_wow_wakeup: First packet after WOW Wakeup rcvd
May 20 13:35:59 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_resume:enter
May 20 13:35:59 Xperia10III kernel: OOM killer enabled.
May 20 13:35:59 Xperia10III kernel: Restarting tasks ...
May 20 13:35:59 Xperia10III kernel: i2c_pmic 2-0009: ignoring dependency for device, assuming no driver
May 20 13:35:59 Xperia10III kernel: done.
May 20 13:35:59 Xperia10III kernel: PM: suspend exit
May 20 13:36:01 Xperia10III kernel: PM: Syncing filesystems ... done.
May 20 13:36:01 Xperia10III kernel: Freezing user space processes ... (elapsed 0.005 seconds) done.
May 20 13:36:01 Xperia10III kernel: OOM killer disabled.
May 20 13:36:01 Xperia10III kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
May 20 13:36:01 Xperia10III kernel: Suspending console(s) (use no_console_suspend to debug)
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b5749bb0][13:35:59.318744] wlan: [89:I:HDD] hdd_suspend_wlan: 1244: WLAN being suspended by OS
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b574b513][13:35:59.319083] wlan: [89:I:PMO] pmo_core_is_wow_applicable: 319: lpass enabled, enabling wow
May 20 13:36:01 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_suspend:enter
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b57edbcd][13:35:59.353733] wlan: [282:I:HDD] __wlan_hdd_bus_suspend: 1066: starting bus suspend
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b57ee00a][13:35:59.353789] wlan: [282:I:PMO] pmo_core_enable_wow_in_fw: 813: Prevent link down, non-drv wow is enabled
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b57ee07b][13:35:59.353795] wlan: [282:I:PMO] pmo_core_enable_wow_in_fw: 817: system suspend wow
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b57ee2af][13:35:59.353824] wlan: [282:I:WMI] send_wow_enable_cmd_tlv: 1831: suspend type: WOW_IFACE_PAUSE_DISABLED flag is 0x20
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b582df1c][13:35:59.367430] wlan: [282:I:HDD] __wlan_hdd_bus_suspend: 1142: bus suspend succeeded
May 20 13:36:01 Xperia10III kernel: Disabling non-boot CPUs ...
May 20 13:36:01 Xperia10III kernel: CPU1: shutdown
May 20 13:36:01 Xperia10III kernel: psci: CPU1 killed (polled 0 ms)
May 20 13:36:01 Xperia10III kernel: CPU2: shutdown
May 20 13:36:01 Xperia10III kernel: psci: CPU2 killed (polled 0 ms)
May 20 13:36:01 Xperia10III kernel: CPU3: shutdown
May 20 13:36:01 Xperia10III kernel: psci: CPU3 killed (polled 0 ms)
May 20 13:36:01 Xperia10III kernel: CPU4: shutdown
May 20 13:36:01 Xperia10III kernel: psci: CPU4 killed (polled 0 ms)
May 20 13:36:01 Xperia10III kernel: CPU5: shutdown
May 20 13:36:01 Xperia10III kernel: psci: CPU5 killed (polled 1 ms)
May 20 13:36:01 Xperia10III kernel: CPU6: shutdown
May 20 13:36:01 Xperia10III kernel: psci: CPU6 killed (polled 1 ms)
May 20 13:36:01 Xperia10III kernel: CPU7: shutdown
May 20 13:36:01 Xperia10III kernel: psci: CPU7 killed (polled 1 ms)
May 20 13:36:01 Xperia10III kernel: suspend ns:    1041331023541        suspend cycles:      20225818508
May 20 13:36:01 Xperia10III kernel: resume cycles:      20273165204
May 20 13:36:01 Xperia10III kernel: Enabling non-boot CPUs ...
May 20 13:36:01 Xperia10III kernel: Detected VIPT I-cache on CPU1
May 20 13:36:01 Xperia10III kernel: arch_timer: CPU1: Trapping CNTVCT access
May 20 13:36:01 Xperia10III kernel: CPU1: Booted secondary processor 0x0000000100 [0x51df805e]
May 20 13:36:01 Xperia10III kernel: CPU1 is up
May 20 13:36:01 Xperia10III kernel: Detected VIPT I-cache on CPU2
May 20 13:36:01 Xperia10III kernel: arch_timer: CPU2: Trapping CNTVCT access
May 20 13:36:01 Xperia10III kernel: CPU2: Booted secondary processor 0x0000000200 [0x51df805e]
May 20 13:36:01 Xperia10III kernel: CPU2 is up
May 20 13:36:01 Xperia10III kernel: Detected VIPT I-cache on CPU3
May 20 13:36:01 Xperia10III kernel: arch_timer: CPU3: Trapping CNTVCT access
May 20 13:36:01 Xperia10III kernel: CPU3: Booted secondary processor 0x0000000300 [0x51df805e]
May 20 13:36:01 Xperia10III kernel: CPU3 is up
May 20 13:36:01 Xperia10III kernel: Detected VIPT I-cache on CPU4
May 20 13:36:01 Xperia10III kernel: arch_timer: CPU4: Trapping CNTVCT access
May 20 13:36:01 Xperia10III kernel: CPU4: Booted secondary processor 0x0000000400 [0x51df805e]
May 20 13:36:01 Xperia10III kernel: CPU4 is up
May 20 13:36:01 Xperia10III kernel: Detected VIPT I-cache on CPU5
May 20 13:36:01 Xperia10III kernel: arch_timer: CPU5: Trapping CNTVCT access
May 20 13:36:01 Xperia10III kernel: CPU5: Booted secondary processor 0x0000000500 [0x51df805e]
May 20 13:36:01 Xperia10III kernel: CPU5 is up
May 20 13:36:01 Xperia10III kernel: Detected PIPT I-cache on CPU6
May 20 13:36:01 Xperia10III kernel: arch_timer: CPU6: Trapping CNTVCT access
May 20 13:36:01 Xperia10III kernel: CPU6: Booted secondary processor 0x0000000600 [0x411fd0d0]
May 20 13:36:01 Xperia10III kernel: CPU6 is up
May 20 13:36:01 Xperia10III kernel: Detected PIPT I-cache on CPU7
May 20 13:36:01 Xperia10III kernel: arch_timer: CPU7: Trapping CNTVCT access
May 20 13:36:01 Xperia10III kernel: CPU7: Booted secondary processor 0x0000000700 [0x411fd0d0]
May 20 13:36:01 Xperia10III kernel: CPU7 is up
May 20 13:36:01 Xperia10III kernel: no screen_state.
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b8643228][13:36:01.884164] wlan: [282:I:HDD] wlan_hdd_bus_resume: 1280: starting bus resume
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b8643513][13:36:01.884203] wlan: [282:I:PMO] pmo_core_psoc_send_host_wakeup_ind_to_fw: 1219: Host wakeup indication sent to fw
May 20 13:36:01 Xperia10III kernel: [soft_i][0x4b8657a04][13:36:01.888536] wlan: [0:F:WMA] Non-WLAN triggered wakeup: UNSPECIFIED (-1)
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b86580c6][13:36:01.888625] wlan: [282:I:HDD] wlan_hdd_bus_resume: 1345: bus resume succeeded
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b865888e][13:36:01.888729] wlan: [12046:I:HDD] hdd_resume_wlan: 1302: WLAN being resumed by OS
May 20 13:36:01 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_resume:enter
May 20 13:36:01 Xperia10III kernel: OOM killer enabled.
May 20 13:36:01 Xperia10III kernel: Restarting tasks ...
May 20 13:36:01 Xperia10III kernel: i2c_pmic 2-0009: ignoring dependency for device, assuming no driver
May 20 13:36:01 Xperia10III kernel: binder: 7522 RLIMIT_NICE not set
May 20 13:36:01 Xperia10III kernel: done.
May 20 13:36:01 Xperia10III kernel: PM: suspend exit
May 20 13:36:01 Xperia10III kernel: PM: suspend entry (deep)
May 20 13:36:01 Xperia10III kernel: Freezing user space processes ... (elapsed 0.006 seconds) done.
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b8725ed7][13:36:01.932546] wlan: [12045:I:HDD] hdd_suspend_wlan: 1244: WLAN being suspended by OS
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b872776c][13:36:01.932874] wlan: [12045:I:PMO] pmo_core_is_wow_applicable: 319: lpass enabled, enabling wow
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b87b4402][13:36:01.962909] wlan: [282:I:HDD] __wlan_hdd_bus_suspend: 1066: starting bus suspend
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b87b4628][13:36:01.962937] wlan: [282:I:PMO] pmo_core_enable_wow_in_fw: 813: Prevent link down, non-drv wow is enabled
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b87b4651][13:36:01.962939] wlan: [282:I:PMO] pmo_core_enable_wow_in_fw: 817: system suspend wow
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b87b46d6][13:36:01.962946] wlan: [282:I:WMI] send_wow_enable_cmd_tlv: 1831: suspend type: WOW_IFACE_PAUSE_DISABLED flag is 0x20
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b87b6ad8][13:36:01.963426] wlan: [282:I:HDD] __wlan_hdd_bus_suspend: 1142: bus suspend succeeded
May 20 13:36:01 Xperia10III kernel: dpm_run_callback(): platform_pm_suspend+0x0/0x6c returns -11
May 20 13:36:01 Xperia10III kernel: PM: Device soc:bu520x1nvx failed to suspend: error -11
May 20 13:36:01 Xperia10III kernel: PM: Some devices failed to suspend, or early wake event detected
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b87bdd60][13:36:01.964954] wlan: [282:I:HDD] wlan_hdd_bus_resume: 1280: starting bus resume
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b87bdf6a][13:36:01.964981] wlan: [282:I:PMO] pmo_core_psoc_send_host_wakeup_ind_to_fw: 1219: Host wakeup indication sent to fw
May 20 13:36:01 Xperia10III kernel: [soft_i][0x4b87bec2f][13:36:01.965151] wlan: [0:F:WMA] Non-WLAN triggered wakeup: UNSPECIFIED (-1)
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b87bf148][13:36:01.965219] wlan: [282:I:HDD] wlan_hdd_bus_resume: 1345: bus resume succeeded
May 20 13:36:01 Xperia10III kernel: [kworke][0x4b87bf395][13:36:01.965250] wlan: [12048:I:HDD] hdd_resume_wlan: 1302: WLAN being resumed by OS
May 20 13:36:02 Xperia10III kernel: Restarting tasks ... done.
May 20 13:36:02 Xperia10III kernel: PM: suspend exit
May 20 13:36:02 Xperia10III kernel: [schedu][0x4b8e09b00][13:36:02.308815] wlan: [6840:I:OSIF] scan start scan id 41067
May 20 13:36:02 Xperia10III kernel: PM: suspend entry (deep)
May 20 13:36:02 Xperia10III kernel: PM: Syncing filesystems ... done.
May 20 13:36:03 Xperia10III kernel: Freezing user space processes ... (elapsed 0.010 seconds) done.
May 20 13:36:03 Xperia10III kernel: OOM killer disabled.
May 20 13:36:03 Xperia10III kernel: Freezing remaining freezable tasks ... (elapsed 0.003 seconds) done.
May 20 13:36:03 Xperia10III kernel: Suspending console(s) (use no_console_suspend to debug)
May 20 13:36:03 Xperia10III kernel: [schedu][0x4b920702b][13:36:02.526697] wlan: [6840:I:OSIF] vdev 0, scan id 41067 type COMPLETED(1) reason CANCELLED(2) scan found 3 bss
May 20 13:36:03 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_suspend:enter
May 20 13:36:03 Xperia10III kernel: [kworke][0x4b92f4c47][13:36:02.577419] wlan: [282:I:HDD] hdd_suspend_wlan: 1244: WLAN being suspended by OS
May 20 13:36:03 Xperia10III kernel: [kworke][0x4b92f6752][13:36:02.577779] wlan: [282:I:PMO] pmo_core_is_wow_applicable: 319: lpass enabled, enabling wow
May 20 13:36:03 Xperia10III kernel: [kworke][0x4b92f7b29][13:36:02.578044] wlan: [12043:I:HDD] __wlan_hdd_bus_suspend: 1066: starting bus suspend
May 20 13:36:03 Xperia10III kernel: [kworke][0x4b92f7fd4][13:36:02.578106] wlan: [12043:I:PMO] pmo_core_enable_wow_in_fw: 813: Prevent link down, non-drv wow is enabled
May 20 13:36:03 Xperia10III kernel: [kworke][0x4b92f8058][13:36:02.578113] wlan: [12043:I:PMO] pmo_core_enable_wow_in_fw: 817: system suspend wow
May 20 13:36:03 Xperia10III kernel: [kworke][0x4b92f8199][13:36:02.578130] wlan: [12043:I:WMI] send_wow_enable_cmd_tlv: 1831: suspend type: WOW_IFACE_PAUSE_DISABLED flag is 0x20
May 20 13:36:03 Xperia10III kernel: [kworke][0x4b9333627][13:36:02.590777] wlan: [12043:I:HDD] __wlan_hdd_bus_suspend: 1142: bus suspend succeeded
May 20 13:36:03 Xperia10III kernel: Disabling non-boot CPUs ...
May 20 13:36:03 Xperia10III kernel: CPU1: shutdown
May 20 13:36:03 Xperia10III kernel: psci: CPU1 killed (polled 0 ms)
May 20 13:36:03 Xperia10III kernel: CPU2: shutdown
May 20 13:36:03 Xperia10III kernel: psci: CPU2 killed (polled 0 ms)
May 20 13:36:03 Xperia10III kernel: CPU3: shutdown
May 20 13:36:03 Xperia10III kernel: psci: CPU3 killed (polled 0 ms)
May 20 13:36:03 Xperia10III kernel: CPU4: shutdown
May 20 13:36:03 Xperia10III kernel: psci: CPU4 killed (polled 0 ms)
May 20 13:36:03 Xperia10III kernel: CPU5: shutdown
May 20 13:36:03 Xperia10III kernel: psci: CPU5 killed (polled 0 ms)
May 20 13:36:03 Xperia10III kernel: CPU6: shutdown
May 20 13:36:03 Xperia10III kernel: psci: CPU6 killed (polled 1 ms)
May 20 13:36:03 Xperia10III kernel: CPU7: shutdown
May 20 13:36:03 Xperia10III kernel: psci: CPU7 killed (polled 0 ms)
May 20 13:36:03 Xperia10III kernel: suspend ns:    1042092804845        suspend cycles:      20287791405
May 20 13:36:03 Xperia10III kernel: resume cycles:      20295454087
May 20 13:36:03 Xperia10III kernel: Enabling non-boot CPUs ...
May 20 13:36:03 Xperia10III kernel: Detected VIPT I-cache on CPU1
May 20 13:36:03 Xperia10III kernel: arch_timer: CPU1: Trapping CNTVCT access
May 20 13:36:03 Xperia10III kernel: CPU1: Booted secondary processor 0x0000000100 [0x51df805e]
May 20 13:36:03 Xperia10III kernel: CPU1 is up
May 20 13:36:03 Xperia10III kernel: Detected VIPT I-cache on CPU2
May 20 13:36:03 Xperia10III kernel: arch_timer: CPU2: Trapping CNTVCT access
May 20 13:36:03 Xperia10III kernel: CPU2: Booted secondary processor 0x0000000200 [0x51df805e]
May 20 13:36:03 Xperia10III kernel: CPU2 is up
May 20 13:36:03 Xperia10III kernel: Detected VIPT I-cache on CPU3
May 20 13:36:03 Xperia10III kernel: arch_timer: CPU3: Trapping CNTVCT access
May 20 13:36:03 Xperia10III kernel: CPU3: Booted secondary processor 0x0000000300 [0x51df805e]
May 20 13:36:03 Xperia10III kernel: CPU3 is up
May 20 13:36:03 Xperia10III kernel: Detected VIPT I-cache on CPU4
May 20 13:36:03 Xperia10III kernel: arch_timer: CPU4: Trapping CNTVCT access
May 20 13:36:03 Xperia10III kernel: CPU4: Booted secondary processor 0x0000000400 [0x51df805e]
May 20 13:36:03 Xperia10III kernel: CPU4 is up
May 20 13:36:03 Xperia10III kernel: Detected VIPT I-cache on CPU5
May 20 13:36:03 Xperia10III kernel: arch_timer: CPU5: Trapping CNTVCT access
May 20 13:36:03 Xperia10III kernel: CPU5: Booted secondary processor 0x0000000500 [0x51df805e]
May 20 13:36:03 Xperia10III kernel: CPU5 is up
May 20 13:36:03 Xperia10III kernel: Detected PIPT I-cache on CPU6
May 20 13:36:03 Xperia10III kernel: arch_timer: CPU6: Trapping CNTVCT access
May 20 13:36:03 Xperia10III kernel: CPU6: Booted secondary processor 0x0000000600 [0x411fd0d0]
May 20 13:36:03 Xperia10III kernel: CPU6 is up
May 20 13:36:03 Xperia10III kernel: Detected PIPT I-cache on CPU7
May 20 13:36:03 Xperia10III kernel: arch_timer: CPU7: Trapping CNTVCT access
May 20 13:36:03 Xperia10III kernel: CPU7: Booted secondary processor 0x0000000700 [0x411fd0d0]
May 20 13:36:03 Xperia10III kernel: CPU7 is up
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4b9b6bd61][13:36:03.039727] wlan: [0:E:QDF] htc_rx_completion_handler: 442: Received initial wake up
May 20 13:36:03 Xperia10III kernel: no screen_state.
May 20 13:36:03 Xperia10III kernel: [kworke][0x4b9b82863][13:36:03.044567] wlan: [12043:I:HDD] wlan_hdd_bus_resume: 1280: starting bus resume
May 20 13:36:03 Xperia10III kernel: [kworke][0x4b9b82b71][13:36:03.044608] wlan: [12043:I:PMO] pmo_core_psoc_send_host_wakeup_ind_to_fw: 1219: Host wakeup indication sent to fw
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4b9b83f42][13:36:03.044872] wlan: [0:F:WMA] WLAN triggered wakeup: PATTERN_MATCH_FOUND (9), vdev: 0 (STA)
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4b9b843c5][13:36:03.044932] wlan: [0:F:WMA] WLAN wake reason counters:
May 20 13:36:03 Xperia10III kernel: [kworke][0x4b9b84451][13:36:03.044939] wlan: [12043:I:HDD] wlan_hdd_bus_resume: 1345: bus resume succeeded
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4b9b844cf][13:36:03.044946] wlan: [0:F:WMA] uc:1 bc:0 v4_mc:0 v6_mc:0 ra:0 ns:0 na:0 icmp:0 icmpv6:0
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4b9b845b1][13:36:03.044958] wlan: [0:F:WMA] assoc:0 disassoc:0 assoc_resp:0 reassoc:0 reassoc_resp:0 auth:0 deauth:0 action:0
May 20 13:36:03 Xperia10III kernel: [kworke][0x4b9b846b9][13:36:03.044971] wlan: [12048:I:HDD] hdd_resume_wlan: 1302: WLAN being resumed by OS
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4b9b8470d][13:36:03.044976] wlan: [0:F:WMA] pno_match:0 pno_complete:0 gscan:0 low_rssi:0 rssi_breach:0 oem:0 scan_11d:0
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4b9b84ae7][13:36:03.045027] wlan: [0:I:WMA] wma_wow_parse_data_pkt: 2172: Src_mac: 2c:3a:fd:f7:77:f2, Dst_mac: 3c:01:ef:f5:c8:39
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4b9b84f42][13:36:03.045085] wlan: [0:I:WMA] WOW Wakeup: IPV6 TCP Packet rcvd
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4b9b851cd][13:36:03.045119] wlan: [0:I:WMA] Pkt_len: 40, src_port: 40059, dst_port: 80
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4b9b853aa][13:36:03.045144] wlan: [0:F:WMA] WLAN wake reason counters:
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4b9b85598][13:36:03.045170] wlan: [0:F:WMA] uc:2 bc:0 v4_mc:0 v6_mc:0 ra:0 ns:0 na:0 icmp:0 icmpv6:0
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4b9b8570d][13:36:03.045189] wlan: [0:F:WMA] assoc:0 disassoc:0 assoc_resp:0 reassoc:0 reassoc_resp:0 auth:0 deauth:0 action:0
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4b9b85a18][13:36:03.045230] wlan: [0:F:WMA] pno_match:0 pno_complete:0 gscan:0 low_rssi:0 rssi_breach:0 oem:0 scan_11d:0
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4b9b863b5][13:36:03.045358] wlan: [0:I:HTT] htt_get_first_packet_after_wow_wakeup: First packet after WOW Wakeup rcvd
***************** HERE SEEMS TO BEGIN THE WAKING UP (why, I do not know) ***************************
May 20 13:36:03 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_resume:enter
May 20 13:36:03 Xperia10III kernel: OOM killer enabled.
May 20 13:36:03 Xperia10III kernel: Restarting tasks ...
May 20 13:36:03 Xperia10III kernel: i2c_pmic 2-0009: ignoring dependency for device, assuming no driver
May 20 13:36:03 Xperia10III kernel: done.
May 20 13:36:03 Xperia10III kernel: PM: suspend exit
May 20 13:36:03 Xperia10III kernel: PM: suspend entry (deep)
May 20 13:36:03 Xperia10III kernel: PM: Syncing filesystems ... done.
May 20 13:36:03 Xperia10III kernel: Freezing user space processes ... (elapsed 0.005 seconds) done.
May 20 13:36:03 Xperia10III kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
May 20 13:36:03 Xperia10III kernel: [kworke][0x4b9fc66b0][13:36:03.277504] wlan: [9997:I:HDD] hdd_suspend_wlan: 1244: WLAN being suspended by OS
May 20 13:36:03 Xperia10III kernel: [kworke][0x4b9fc9049][13:36:03.278059] wlan: [9997:I:PMO] pmo_core_is_wow_applicable: 319: lpass enabled, enabling wow
May 20 13:36:03 Xperia10III kernel: [kworke][0x4ba06e55f][13:36:03.313327] wlan: [12043:I:HDD] __wlan_hdd_bus_suspend: 1066: starting bus suspend
May 20 13:36:03 Xperia10III kernel: [kworke][0x4ba06e776][13:36:03.313355] wlan: [12043:I:PMO] pmo_core_enable_wow_in_fw: 813: Prevent link down, non-drv wow is enabled
May 20 13:36:03 Xperia10III kernel: [kworke][0x4ba06e79f][13:36:03.313357] wlan: [12043:I:PMO] pmo_core_enable_wow_in_fw: 817: system suspend wow
May 20 13:36:03 Xperia10III kernel: [kworke][0x4ba06e81a][13:36:03.313363] wlan: [12043:I:WMI] send_wow_enable_cmd_tlv: 1831: suspend type: WOW_IFACE_PAUSE_DISABLED flag is 0x20
May 20 13:36:03 Xperia10III kernel: [kworke][0x4ba0cf507][13:36:03.334016] wlan: [12043:I:HDD] __wlan_hdd_bus_suspend: 1142: bus suspend succeeded
May 20 13:36:03 Xperia10III kernel: dpm_run_callback(): platform_pm_suspend+0x0/0x6c returns -11
May 20 13:36:03 Xperia10III kernel: PM: Device soc:bu520x1nvx failed to suspend: error -11
May 20 13:36:03 Xperia10III kernel: PM: Some devices failed to suspend, or early wake event detected
May 20 13:36:03 Xperia10III kernel: [kworke][0x4ba0e160a][13:36:03.337869] wlan: [12043:I:HDD] wlan_hdd_bus_resume: 1280: starting bus resume
May 20 13:36:03 Xperia10III kernel: [kworke][0x4ba0e2017][13:36:03.338003] wlan: [12043:I:PMO] pmo_core_psoc_send_host_wakeup_ind_to_fw: 1219: Host wakeup indication sent to fw
May 20 13:36:03 Xperia10III kernel: [soft_i][0x4ba0e30df][13:36:03.338227] wlan: [0:F:WMA] Non-WLAN triggered wakeup: UNSPECIFIED (-1)
May 20 13:36:03 Xperia10III kernel: [kworke][0x4ba0e3a7c][13:36:03.338355] wlan: [12043:I:HDD] wlan_hdd_bus_resume: 1345: bus resume succeeded
May 20 13:36:03 Xperia10III kernel: [kworke][0x4ba0e3e33][13:36:03.338404] wlan: [12046:I:HDD] hdd_resume_wlan: 1302: WLAN being resumed by OS
May 20 13:36:03 Xperia10III kernel: Restarting tasks ... done.
**-------->>>> SCREEN SWITCH ON**
May 20 13:36:03 Xperia10III mce[1862]: tklock.c: tklock_lidpolicy_rethink(): display state req: ON
May 20 13:36:03 Xperia10III mce[1862]: modules/display.c: mdy_display_state_leave(): current display state = POWER_UP
May 20 13:36:03 Xperia10III lipstick[6055]: [D] unknown:0 - unsleepDisplay
May 20 13:36:03 Xperia10III kernel: [drm:dsi_display_set_mode] [msm-dsi-info]: mdp_transfer_time_us=15666 us
May 20 13:36:03 Xperia10III kernel: [drm:dsi_display_set_mode] [msm-dsi-info]: hactive= 1080,vactive= 2520,fps=60
May 20 13:36:03 Xperia10III kernel: [drm:dsi_ctrl_isr_configure] [msm-dsi-info]: dsi-ctrl-0: IRQ 385 registered
May 20 13:36:03 Xperia10III kernel: dsi_panel_driver_touch_pinctrl_set_state: invalid 'somc_ts_int_active' pinstate
May 20 13:36:03 Xperia10III kernel: @@@@ panel power on @@@@
May 20 13:36:03 Xperia10III kernel: somc_panel_color_manager: somc_panel_inject_crtc_overrides (786): Override: Already have original funcs! Is setup called twice??
May 20 13:36:03 Xperia10III kernel: somc_panel_color_manager: somc_panel_pcc_setup (884): Cannot read uv data: missing command
May 20 13:36:03 Xperia10III kernel: somc_panel_color_manager: somc_panel_pcc_setup (888): u,v is flashed 0.
May 20 13:36:03 Xperia10III kernel: somc_panel_color_manager: somc_panel_colormgr_apply_calibrations: Couldn't apply PCC calibration
May 20 13:36:03 Xperia10III kernel: somc_panel_color_manager: somc_panel_colormgr_apply_calibrations: Cannot send HSIC calibration
May 20 13:36:03 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_dsi_panel_notifier_cb: power up
May 20 13:36:03 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_start_device
May 20 13:36:03 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pinctrl_configure: ACTIVE
May 20 13:36:03 Xperia10III kernel: (NULL device *): deviceless supply vdd not found, using dummy regulator
May 20 13:36:03 Xperia10III kernel: (NULL device *): deviceless supply avdd not found, using dummy regulator
May 20 13:36:03 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_power: on: avdd:on, dvdd:on
May 20 13:36:03 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_wait_for_ready: 09, 00, 10, 00, 00, 00, 00, 00 [0]
May 20 13:36:03 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_start_device: cover open, not send cmd
May 20 13:36:03 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_set_grip_type: re-init grip(0), edh:0, edg:0, lan:0
May 20 13:36:03 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_read_event: STATUS 1d 61 2 2 3 0 0 0
May 20 13:36:04 Xperia10III mce[1862]: modules/display.c: mdy_display_state_enter(): current display state = ON
May 20 13:36:04 Xperia10III kernel: pn544_dev_ioctl :enter cmd = 1074063617, arg = 0
May 20 13:36:04 Xperia10III kernel: pn544_dev_ioctl power off
May 20 13:36:04 Xperia10III kernel: pn544_dev_ioctl :exit cmd = 1074063617, arg = 0
May 20 13:36:04 Xperia10III kernel: pn544_dev_ioctl :enter cmd = 1074063617, arg = 1
May 20 13:36:04 Xperia10III kernel: pn544_dev_ioctl power on
May 20 13:36:04 Xperia10III kernel: pn544_dev_ioctl :exit cmd = 1074063617, arg = 1
May 20 13:36:04 Xperia10III kernel: i2c_geni 880000.i2c: i2c error :-107
May 20 13:36:04 Xperia10III kernel: pn544_dev_write : i2c_master_send returned -107
May 20 13:36:04 Xperia10III droid-hal-init: processing action (ril.ecclist=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:6)
May 20 13:36:04 Xperia10III droid-hal-init: processing action (ril.ecclist1=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:10)
May 20 13:36:05 Xperia10III kernel: [schedu][0x4bc162eb7][13:36:05.113131] wlan: [6840:I:OSIF] scan start scan id 41068
May 20 13:36:05 Xperia10III kernel: binder: 7522 RLIMIT_NICE not set
May 20 13:36:08 Xperia10III kernel: binder: 7522 RLIMIT_NICE not set
May 20 13:36:08 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
May 20 13:36:09 Xperia10III kernel: [schedu][0x4c0fba917][13:36:09.391670] wlan: [6840:I:OSIF] vdev 0, scan id 41068 type COMPLETED(1) reason COMPLETED(1) scan found 16 bss
May 20 13:36:10 Xperia10III kernel: [schedu][0x4c1cf6706][13:36:10.114416] wlan: [6840:I:OSIF] scan start scan id 41069
May 20 13:36:11 Xperia10III kernel: binder: 7522 RLIMIT_NICE not set
May 20 13:36:14 Xperia10III mce[1862]: modules/display.c: mdy_blanking_off_cb(): display state req: LPM_ON
May 20 13:36:14 Xperia10III mce[1862]: modules/display.c: mdy_display_state_leave(): current display state = POWER_DOWN
**----------->>> SCREEN SWITCHED OFF**
May 20 13:36:14 Xperia10III sensorfwd[3383]: virtual bool HybrisAdaptor::setInterval(unsigned int, int) setInterval not ok
May 20 13:36:14 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
May 20 13:36:14 Xperia10III lipstick[6055]: [D] unknown:0 - sleepDisplay
May 20 13:36:14 Xperia10III mce[1862]: tklock.c: tklock_dbus_notification_end_cb(): notification end from name=:1.70 owner=:1.70 pid=6055 uid=100000 gid=996 priv=1 cmd=/usr/bin/lipstick -plugin evdevtouch -plugin evdevmouse -plugin
May 20 13:36:14 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_dsi_panel_notifier_cb: power down
May 20 13:36:14 Xperia10III kernel: (NULL device *): deviceless supply vdd not found, using dummy regulator
May 20 13:36:14 Xperia10III kernel: (NULL device *): deviceless supply avdd not found, using dummy regulator
May 20 13:36:14 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_power: off: avdd:on, dvdd:on
May 20 13:36:14 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pinctrl_configure: SUSPEND
May 20 13:36:14 Xperia10III kernel: Entering OFF state from 0
May 20 13:36:14 Xperia10III kernel: AOD mode OFF
May 20 13:36:14 Xperia10III kernel: pn544_dev_ioctl :enter cmd = 1074063617, arg = 0
May 20 13:36:14 Xperia10III kernel: pn544_dev_ioctl power off
May 20 13:36:14 Xperia10III kernel: pn544_dev_ioctl :exit cmd = 1074063617, arg = 0
May 20 13:36:14 Xperia10III kernel: binder: 7522 RLIMIT_NICE not set
May 20 13:36:14 Xperia10III kernel: @@@@ panel power off @@@@
May 20 13:36:14 Xperia10III mce[1862]: modules/display.c: mdy_display_state_enter(): current display state = OFF
May 20 13:36:14 Xperia10III mce[1862]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: UNDEF -> OPEN
May 20 13:36:14 Xperia10III kernel: [schedu][0x4c6f5c06f][13:36:14.614381] wlan: [6840:I:OSIF] vdev 0, scan id 41069 type COMPLETED(1) reason COMPLETED(1) scan found 10 bss
May 20 13:36:14 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x42e08
May 20 13:36:17 Xperia10III kernel: binder: 7522 RLIMIT_NICE not set
May 20 13:36:20 Xperia10III kernel: [schedu][0x4cd41431a][13:36:20.115003] wlan: [6840:I:OSIF] scan start scan id 41070
May 20 13:36:20 Xperia10III kernel: binder: 7522 RLIMIT_NICE not set
May 20 13:36:21 Xperia10III healthd: battery l=64 v=4005 t=34.7 h=2 st=3 c=-208 fc=0 cc=0 chg=
May 20 13:36:21 Xperia10III kernel: binder: 7426 RLIMIT_NICE not set
May 20 13:36:21 Xperia10III kernel: binder: 7535 RLIMIT_NICE not set
May 20 13:36:21 Xperia10III healthd: battery l=64 v=3988 t=34.7 h=2 st=3 c=-208 fc=0 cc=0 chg=
May 20 13:36:22 Xperia10III mce[1862]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: OPEN -> UNDEF
May 20 13:36:22 Xperia10III kernel: PM: suspend entry (deep)
**---------->>>> SOMETHING WITH PROXIMITY SENSOR??**
May 20 13:36:23 Xperia10III kernel: PM: Syncing filesystems ... done.
May 20 13:36:23 Xperia10III kernel: Freezing user space processes ... (elapsed 0.010 seconds) done.
May 20 13:36:23 Xperia10III kernel: OOM killer disabled.
May 20 13:36:23 Xperia10III kernel: Freezing remaining freezable tasks ... (elapsed 0.003 seconds) done.
May 20 13:36:23 Xperia10III kernel: Suspending console(s) (use no_console_suspend to debug)
May 20 13:36:23 Xperia10III kernel: [schedu][0x4cf8de2da][13:36:22.124173] wlan: [6840:I:OSIF] vdev 0, scan id 41070 type COMPLETED(1) reason CANCELLED(2) scan found 14 bss
May 20 13:36:23 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_suspend:enter
May 20 13:36:23 Xperia10III kernel: [kworke][0x4cf9c9c7c][13:36:22.174435] wlan: [368:I:HDD] hdd_suspend_wlan: 1244: WLAN being suspended by OS
May 20 13:36:23 Xperia10III kernel: [kworke][0x4cf9cbf20][13:36:22.174897] wlan: [368:I:PMO] pmo_core_is_wow_applicable: 319: lpass enabled, enabling wow
May 20 13:36:23 Xperia10III kernel: [kworke][0x4cf9cd6a3][13:36:22.175210] wlan: [282:I:HDD] __wlan_hdd_bus_suspend: 1066: starting bus suspend
May 20 13:36:23 Xperia10III kernel: [kworke][0x4cf9cdb91][13:36:22.175276] wlan: [282:I:PMO] pmo_core_enable_wow_in_fw: 813: Prevent link down, non-drv wow is enabled
May 20 13:36:23 Xperia10III kernel: [kworke][0x4cf9cdc2c][13:36:22.175284] wlan: [282:I:PMO] pmo_core_enable_wow_in_fw: 817: system suspend wow
May 20 13:36:23 Xperia10III kernel: [kworke][0x4cf9cdecf][13:36:22.175319] wlan: [282:I:WMI] send_wow_enable_cmd_tlv: 1831: suspend type: WOW_IFACE_PAUSE_DISABLED flag is 0x20
May 20 13:36:23 Xperia10III kernel: [kworke][0x4cfa02459][13:36:22.186486] wlan: [282:I:HDD] __wlan_hdd_bus_suspend: 1142: bus suspend succeeded
May 20 13:36:23 Xperia10III kernel: Disabling non-boot CPUs ...
May 20 13:36:23 Xperia10III kernel: irq_migrate_all_off_this_cpu: 46 callbacks suppressed
May 20 13:36:23 Xperia10III kernel: IRQ 5: no longer affine to CPU1
May 20 13:36:23 Xperia10III kernel: IRQ 10: no longer affine to CPU1
May 20 13:36:23 Xperia10III kernel: IRQ 113: no longer affine to CPU1
May 20 13:36:23 Xperia10III kernel: IRQ 267: no longer affine to CPU1
May 20 13:36:23 Xperia10III kernel: CPU1: shutdown
May 20 13:36:23 Xperia10III kernel: psci: CPU1 killed (polled 1 ms)
May 20 13:36:23 Xperia10III kernel: CPU2: shutdown
May 20 13:36:23 Xperia10III kernel: psci: CPU2 killed (polled 1 ms)
May 20 13:36:23 Xperia10III kernel: CPU3: shutdown
May 20 13:36:23 Xperia10III kernel: psci: CPU3 killed (polled 0 ms)
May 20 13:36:23 Xperia10III kernel: CPU4: shutdown
May 20 13:36:23 Xperia10III kernel: psci: CPU4 killed (polled 0 ms)
May 20 13:36:23 Xperia10III kernel: CPU5: shutdown
May 20 13:36:23 Xperia10III kernel: psci: CPU5 killed (polled 1 ms)
May 20 13:36:23 Xperia10III kernel: CPU6: shutdown
May 20 13:36:23 Xperia10III kernel: psci: CPU6 killed (polled 1 ms)
May 20 13:36:23 Xperia10III kernel: CPU7: shutdown
May 20 13:36:23 Xperia10III kernel: psci: CPU7 killed (polled 0 ms)
May 20 13:36:23 Xperia10III kernel: suspend ns:    1061297919747        suspend cycles:      20664192292
May 20 13:36:23 Xperia10III kernel: resume cycles:      20690590666
May 20 13:36:23 Xperia10III kernel: Enabling non-boot CPUs ...
May 20 13:36:23 Xperia10III kernel: Detected VIPT I-cache on CPU1
May 20 13:36:23 Xperia10III kernel: arch_timer: CPU1: Trapping CNTVCT access
May 20 13:36:23 Xperia10III kernel: CPU1: Booted secondary processor 0x0000000100 [0x51df805e]
May 20 13:36:23 Xperia10III kernel: CPU1 is up
May 20 13:36:23 Xperia10III kernel: Detected VIPT I-cache on CPU2
May 20 13:36:23 Xperia10III kernel: arch_timer: CPU2: Trapping CNTVCT access
May 20 13:36:23 Xperia10III kernel: CPU2: Booted secondary processor 0x0000000200 [0x51df805e]
May 20 13:36:23 Xperia10III kernel: CPU2 is up
May 20 13:36:23 Xperia10III kernel: Detected VIPT I-cache on CPU3
May 20 13:36:23 Xperia10III kernel: arch_timer: CPU3: Trapping CNTVCT access
May 20 13:36:23 Xperia10III kernel: CPU3: Booted secondary processor 0x0000000300 [0x51df805e]
May 20 13:36:23 Xperia10III kernel: CPU3 is up
May 20 13:36:23 Xperia10III kernel: Detected VIPT I-cache on CPU4
May 20 13:36:23 Xperia10III kernel: arch_timer: CPU4: Trapping CNTVCT access
May 20 13:36:23 Xperia10III kernel: CPU4: Booted secondary processor 0x0000000400 [0x51df805e]
May 20 13:36:23 Xperia10III kernel: CPU4 is up
May 20 13:36:23 Xperia10III kernel: Detected VIPT I-cache on CPU5
May 20 13:36:23 Xperia10III kernel: arch_timer: CPU5: Trapping CNTVCT access
May 20 13:36:23 Xperia10III kernel: CPU5: Booted secondary processor 0x0000000500 [0x51df805e]
May 20 13:36:23 Xperia10III kernel: CPU5 is up
May 20 13:36:23 Xperia10III kernel: Detected PIPT I-cache on CPU6
May 20 13:36:23 Xperia10III kernel: arch_timer: CPU6: Trapping CNTVCT access
May 20 13:36:23 Xperia10III kernel: CPU6: Booted secondary processor 0x0000000600 [0x411fd0d0]
May 20 13:36:23 Xperia10III kernel: CPU6 is up
May 20 13:36:23 Xperia10III kernel: Detected PIPT I-cache on CPU7
May 20 13:36:23 Xperia10III kernel: arch_timer: CPU7: Trapping CNTVCT access
May 20 13:36:23 Xperia10III kernel: CPU7: Booted secondary processor 0x0000000700 [0x411fd0d0]
May 20 13:36:23 Xperia10III kernel: CPU7 is up
May 20 13:36:23 Xperia10III kernel: no screen_state.
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d145c47f][13:36:23.625635] wlan: [282:I:HDD] wlan_hdd_bus_resume: 1280: starting bus resume
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d145c753][13:36:23.625673] wlan: [282:I:PMO] pmo_core_psoc_send_host_wakeup_ind_to_fw: 1219: Host wakeup indication sent to fw
May 20 13:36:23 Xperia10III kernel: [soft_i][0x4d147124c][13:36:23.630086] wlan: [0:F:WMA] Non-WLAN triggered wakeup: UNSPECIFIED (-1)
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d147197f][13:36:23.630182] wlan: [282:I:HDD] wlan_hdd_bus_resume: 1345: bus resume succeeded
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d14726fc][13:36:23.630362] wlan: [12046:I:HDD] hdd_resume_wlan: 1302: WLAN being resumed by OS
May 20 13:36:23 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_resume:enter
May 20 13:36:23 Xperia10III kernel: OOM killer enabled.
May 20 13:36:23 Xperia10III kernel: Restarting tasks ...
May 20 13:36:23 Xperia10III kernel: i2c_pmic 2-0009: ignoring dependency for device, assuming no driver
May 20 13:36:23 Xperia10III kernel: done.
May 20 13:36:23 Xperia10III kernel: PM: suspend exit
May 20 13:36:23 Xperia10III kernel: PM: suspend entry (deep)
May 20 13:36:23 Xperia10III kernel: Freezing user space processes ... (elapsed 0.004 seconds) done.
May 20 13:36:23 Xperia10III kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d1518982][13:36:23.665809] wlan: [292:I:HDD] hdd_suspend_wlan: 1244: WLAN being suspended by OS
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d151b29f][13:36:23.666357] wlan: [292:I:PMO] pmo_core_is_wow_applicable: 319: lpass enabled, enabling wow
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d15943aa][13:36:23.692184] wlan: [282:I:HDD] __wlan_hdd_bus_suspend: 1066: starting bus suspend
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d15945c0][13:36:23.692212] wlan: [282:I:PMO] pmo_core_enable_wow_in_fw: 813: Prevent link down, non-drv wow is enabled
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d15945e7][13:36:23.692214] wlan: [282:I:PMO] pmo_core_enable_wow_in_fw: 817: system suspend wow
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d1594676][13:36:23.692221] wlan: [282:I:WMI] send_wow_enable_cmd_tlv: 1831: suspend type: WOW_IFACE_PAUSE_DISABLED flag is 0x20
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d159a864][13:36:23.693527] wlan: [282:I:HDD] __wlan_hdd_bus_suspend: 1142: bus suspend succeeded
May 20 13:36:23 Xperia10III kernel: dpm_run_callback(): platform_pm_suspend+0x0/0x6c returns -11
May 20 13:36:23 Xperia10III kernel: PM: Device soc:bu520x1nvx failed to suspend: error -11
May 20 13:36:23 Xperia10III kernel: PM: Some devices failed to suspend, or early wake event detected
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d15a18e7][13:36:23.695027] wlan: [282:I:HDD] wlan_hdd_bus_resume: 1280: starting bus resume
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d15a1ad1][13:36:23.695053] wlan: [282:I:PMO] pmo_core_psoc_send_host_wakeup_ind_to_fw: 1219: Host wakeup indication sent to fw
May 20 13:36:23 Xperia10III kernel: [soft_i][0x4d15a2811][13:36:23.695229] wlan: [0:F:WMA] Non-WLAN triggered wakeup: UNSPECIFIED (-1)
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d15a2c61][13:36:23.695287] wlan: [282:I:HDD] wlan_hdd_bus_resume: 1345: bus resume succeeded
May 20 13:36:23 Xperia10III kernel: [kworke][0x4d15a2ea1][13:36:23.695317] wlan: [368:I:HDD] hdd_resume_wlan: 1302: WLAN being resumed by OS
May 20 13:36:23 Xperia10III kernel: Restarting tasks ... done.
May 20 13:36:24 Xperia10III mce[1862]: tklock.c: tklock_lidpolicy_rethink(): display state req: ON
May 20 13:36:24 Xperia10III mce[1862]: modules/display.c: mdy_display_state_leave(): current display state = POWER_UP
May 20 13:36:24 Xperia10III lipstick[6055]: [D] unknown:0 - unsleepDisplay
May 20 13:36:24 Xperia10III kernel: [drm:dsi_display_set_mode] [msm-dsi-info]: mdp_transfer_time_us=15666 us
May 20 13:36:24 Xperia10III kernel: [drm:dsi_display_set_mode] [msm-dsi-info]: hactive= 1080,vactive= 2520,fps=60
May 20 13:36:24 Xperia10III kernel: [drm:dsi_ctrl_isr_configure] [msm-dsi-info]: dsi-ctrl-0: IRQ 385 registered
May 20 13:36:24 Xperia10III kernel: dsi_panel_driver_touch_pinctrl_set_state: invalid 'somc_ts_int_active' pinstate
May 20 13:36:24 Xperia10III kernel: @@@@ panel power on @@@@
May 20 13:36:24 Xperia10III kernel: somc_panel_color_manager: somc_panel_inject_crtc_overrides (786): Override: Already have original funcs! Is setup called twice??
May 20 13:36:24 Xperia10III kernel: somc_panel_color_manager: somc_panel_pcc_setup (884): Cannot read uv data: missing command
^C
May this be this the reason?
For reference, this sounds simlar:
Indeed, but in my case there is neither sound nor “notification bubble”
SOLVED!!
When originally flashing SFOSX, I had previously downgraded to Android 11 (62.0.A.3.109).
This seems to be sometimes problematic.
I followed the following sequence → Sony Xperia III - Android 12 - #23 by d.geelen
And the bug seems to be gone…!
In my “case” it was the case that cause the problem :slight_smile:
I have an aftermarket flip-case from Xperia 10 II, so probably its magnet causing these phantom wakes for Xperia 10 III (with flap fully flipped open). As soon as I removed the case, 10 III stopped waking up.
Xperia 10 III doesn’t have hall sensor enabled (even in stock Android), probably because it’s flaky, and they may have disabled it altogether in later Android OTAs.
BTW that aftermarket magnet placement was off, thus useless even for 10 II if you wanted wake-on-flip to work.
I’m glad you got to the bottom of this @lupastro. Just to keep things clear for other users, I’ve marked your post as the solution and also tagged the report with “fixed” (probably “resolved” would be better, but “fixed” is the closest we have to that). I hope that’s all okay, but let me know otherwise.
