BUILD ID = OS VERSION (Settings > About product): 4.3.0, 4.4.0
HARDWARE (XA2, X10, X10 II, …): XA2
UI LANGUAGE:
Every time I come out from work, Android apps cannot access mobile data. This happens after the phone has been connected to the workplace WLAN, which is a mesh WLAN with MAC-level access control requiring a one-time login to enable the device MAC.
This only appears to happen in the above conditions, i. e. after accessing my workplace WLAN.
- Come to my workplace.
- Get a login to the mobile phone WLAN.
- Stay some 8-9 hours at work.
- Get out and try to get mobile connectivity from an Android app.
Mobile data connection is working.
Mobile data connection does not work. Restarting Android support restores connection.
