4.2 / XA2 Plus - phone periodically loses access to mobile data - requires a restart to fix things
REPRODUCIBILITY (% or how often): Daily
BUILD ID = OS VERSION (Settings > About product): 4.2
HARDWARE (XA2, X10, X10 II, …): XA2 Plus
UI LANGUAGE: EN (GB)
REGRESSION: (compared to previous public release: Yes, No, ?): No, happened on 4.1 too
In the house on wifi - no problems noticed > leave the house - try browser and get no connection > check top bar and see no “3G” present > try clicking on Mobile Data “Sim 1” but just spins then stops > so i opt to restart phone - at which point mobile data is enabled again > Wait for cycle to repeat…
Possibly being on wifi first, as the SFOS then de-prioritises Mobile Data, but this is speculation.
  1. Leave wifi signal
  2. Then check if 3G is still showing
  3. Try to reconnect Mobile Data
If Mobile Data is lost, i’d expect to be able to re-enable it by selecting the Sim card as SFOS UI prompts user to do
Mobile Data lost, and unable to reconnect as choosing sim just causes SFOS UI to sandtimer then return to previous state.
N/A
Used to happen from time to time, but now on an regular basis. Even if I only use mobile data, the connection is easily lost. I have to restart my phone several times a day when I am out and about having to rely on my mobile data. My phone XA2; 4.2
This problem has not changed since the upgrade to 4.3.
